Trying to diagnose my ECL light in my 2001 b5
Rear O2 coded out, both Fronts are New universal Bosch.
New Epic Tuning Tune
Im very new to VAGCOM
How does one use Vag-com to test the harness up to where the sensors connect? Wiring harness passes my visual inspection, no flaws in wiring externally.
How can I use Vag-com to test MAF, FPR, and the o2s.
Im having a hard time finding what blocks to measure and what values to expect for normal opperation.
These are the codes I pulled.
17524 - Oxygen (Lambda) Sensor Heating; B1 S1
P1116 - 35-00 - Open Circuit
16518 - Oxygen (Lambda) Sensor B1 S1
P0134 - 35-00 - No Activity
16534 - Oxygen (Lambda) Sensor B2 S1
P0150 - 35-10 - Malfunction in Circuit - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 -
16688 - Cylinder 4
P0304 - 35-00 - Misfire Detected
16687 - Cylinder 3
P0303 - 35-00 - Misfire Detected
16689 - Cylinder 5
P0305 - 35-00 - Misfire Detected
16839 - EVAP System
P0455 - 35-00 - Large Leak Detected
17964 - Charge Pressure Control
P1556 - 35-00 - Negative Deviation
Readiness: 0110 0100
Thanks in advance
