Results 1 to 13 of 13
    Established Member Two Rings Shaft2k's Avatar
    Oct 29 2011
    10' S4 Prestige, 10' Q5 Prem Plus (Wife's)
    Dublin, Ca
    255-45-20 stretch
    Tried searching but didn't find anything. Anyone know will a 255 45 20 tire fit a 20x10.5 et27 wheel???? I'm pretty sure some stretch may be needed, just don't want it to be too much.
    10' S4 Prestige Deep Sea Blue - 19" AG m510 wheels, H&R OE Springs, RS4 grill, clear bra, tint
    10' Q5 Prem Plus Black (wife's) - 22" Niche Surge wheels, RS grill, H&R sport springs, tint, Blacked out emblems and trim
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    It'll depend on the tire, and how much concern you have regarding warranty replacement coverage. FWIW, most tire websites publish full specs, usually in .pdf format, which include min and max wheel width. For a 255 I think you'll find a 9.5" max width spec to be most common.
    Personally, I'd go up to a 275mm tread width on a 10.5" wheel, but I know that's not what you're asking. Good luck with the decision.
    --Jerry || 2020 SQ7 Pr, GW/Black/BO (His); 2018 S5 Cab Pr, Daytona/Red (Hers)
    Suspension || H&R Springs - 29001-3; Bilstein B8 Dampers - 24-145985 (F) & 24-145992 (R)
    Wheels & Tires || BBS CI-R - CIR 0501 BPO, 20x10 ET25 Satin Black; Continental DWS06 275/40
    ...Formerly: '16 SQ5 '13 Q53.0T '12 Q5 3.2 '08&'06 A4 Avant 3.2.
    Jul 16 2014
    PacNorWest
    For what its worth I am going through picking out wheel/tire sets currently. I am going to order through getyourwheels.com as they are active on this site. I have been PM'ing them here and for the sets I am looking at 20x8.5 off set 32 or 20x10 offset 35 they recommended 255/45 rubber for each. I am leaning towards the 20x10 but actually going 275/40 which they said will work too. Most tires I have looked into on tirerack.com in 255/45 say max rim width is 9 or 9.5
    Veteran Member Three Rings Pepper SQ5's Avatar
    Aug 25 2012
    MD
    Quote Originally Posted by Shaft2k View Post
    In reality, it's going to depend on the brand of tire. I've run a 255/35/19 on an 11.5" wheel only because the tire ran very large. If the tires you're looking at run small or true, it's going to be a bit too much stretch for most peoples taste.
    255/35/19 on 19x11.5 -7
    Oct 29 2011
    Dublin, Ca
    I'm running 255 35 19 on 19x9.5 et 40 wheels on my s4, I'm fine with that amount of stretch as its minimal on the s4. This would be for the wife's q5 so it sounds like it might be a bit too much for the tire/vehicle....
    Jan 03 2007
    SF Bay Area, CA
    Not to be Captain Obvious, but we're not talking about a whole lot here...255mm is a hair over 10", so you're at less than .25" (or ~ 6mm per side) difference between tread width and wheel width. Given the 45-series profile, you're looking at 114mm (barely less than 4.5") of sidewall to play with. Will it fit? Unquestionably. Will it look good? Maybe. Will it have an effect on ride, handling, and load characteristics? Yes....as a function of the sidewall stiffness. Will you pop the bead on a pothole? Probably not, but the risk is a wee bit greater. Maybe hep C vs ebola, in less than pleasant terms.
    Now. Here I go generalizing, and I mean no offense to the fairer sex. But. This fitment does pretty much take the sidewall out of the equation when it comes to protecting the wheels from curb damage. Realistically, so would a 275/40 tire, so the dilemma is real no matter what. Between that and the variables above on ride and other dynamics.... Well, I love my wife dearly. If she drove a Q, I'd probably keep things stock, but if I did venture into the aftermarket, I'd be looking at 8.5" or 9" widths in a 20" fitment. Just my take.
    Oct 29 2011
    Dublin, Ca
    Thx for the info guys, I think Im going to stay with the 20x9 wheels I have now...........
    Mar 15 2012
    AUDI Q5 S-Line, VW Golf GTI ABT MK6, BMW 335ci E92
    Kuala Lumpur, Malaysia
    mine is 275/40/20 on a 10.5
    2010 AUDI Q5 2.0TFSI IBIS WHITE CARACTERE STAGE 2 REVO
    2008 AUDI A4 B7 S-LINE RED RIEGER STAGE 1 UNITRONIC
    2008 VW GOLF GTI MK5 CANDY WHITE STAGE 2 GIAC
    1991 BMW E30 318i
    Mar 13 2014
    Newcastle, England
    I run 255/30/22 on a 10.5J and its not much stretch at all
    Euro SQ5
    C6 Carbon Interior, Exterior and Engine Bay
    Custom yellow stitch and yellow seatbelts
    StillStatic/AH Exclusive Race H&R with custom Air bags (25" ground to fender)
    Aiflift 3P Management
    C6 Carbon Chassis mods
    DTUK Tuned 370Bhp 774Nm
    Rotiform DUS 22x10.5
    Established Member Two Rings Transfer's Avatar
    Mar 02 2014
    SQ5, E92 M3
    Quote Originally Posted by IanSQ5 View Post
    I call BS. Pics?
    2018 SQ5 - Ibis White - Prestige - S Sport - 21s - DAP - Black Nappa/Carbon
    Sep 21 2005
    A4/Corrado
    BC
    I had 245/40R20 on 10.5 wide wheels
    and also had 265/35R20 on 11 wide wheels
    :O:O
    Senior Member Two Rings big residual's Avatar
    Mar 30 2014
    Needs moar tire
    Mar 13 2014
    Newcastle, England
    Quote Originally Posted by Transfer View Post
    I call BS. Pics?
    Euro SQ5
