Results 1 to 30 of 30
    Veteran Member Three Rings Markie93's Avatar
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    Just bought a 2005 A6, 4.2L V8, Quattro. What should I know??
    Hey guys,
    As said in the title, I just bought a 2005 Audi A6. Its all wheel drive, has 93,000 miles on the 4.2L V8.
    My previous car was an 06 A4, 2.0T quattro.
    Just wondering if anyone has any positive/negative reviews, maintenance I should do first (Timing belt, spark plugs, coil packs), common problems, mods, vag com tips, or anything else I should know about this car.
    Thanks,
    Jake
    Aug 25 2010
    Nice car! Looks very clean
    Senior Member Three Rings gregory.fazekas's Avatar
    Mar 09 2013
    2002 Audi Allroad, 2011 A6, 2004 B6 S4, 2015 Range Rover Evogue
    Lavallette / New Jersey
    the 4.2 engine has some known timing chain issues, at least with the s4 engine. Im not sure if its the same with the a6 4.2. If you don't hear any chain rattle, assume its good. Plugs are prob due to be replaced, as well as the cabin filters and air filters. Mod wise, exhaust is the best place to start. However, people have reported great gains with gutting the pre cats and leaving the main cats in the down pipes. Don't waste your money with a tune before getting an exhaust, and if you are going to go with a tune, go JHM. I would also recommend putting the JHM intake spacers, I did this mod on my buddies s4, and picked up a few mpg. Other then that, check all the fluids, do an oil change every 3000 miles, especially with this car, and drive it.
    Current:
    2009 S5 6mt in Phantom Pearl Black
    FBO 2007 e92 335i 6mt m-sport
    FBO 2008 e92 335xi 6mt
    FBO 2008 e90 335xi 6mt
    Fully Bolted Nissan 350z 6mt
    B6 Stage 2+ A4 5mt
    Oct 03 2007
    New York
    Not sure if the A6 is plagued by the timing chain woes of the 4.2 S4 (B6/B7) - but if you hear that rattle on start-up, you should take a look into it. The tensioners break from heat and stress and will ultimately lead to massive engine failure. On the S4's it is around the 100K mark...
    Nice looking car.
    AKA: Eightx3
    Senior Member Three Rings FormulaElement's Avatar
    Jul 02 2013
    406, MT
    The 05-06 a6's are plagued with the tensioner problems as well...
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    v8a6: Thank you! I bought it from a dealership and they had it all detailed and everything.
    Everyone else: Thank for the great input. I will have to look into these things. I plan to do a timing belt change, water pump, thermostat, tensioners and any other hardware either this winter or next summer.
    I checked the spark plugs, and the coil packs. Looks like they have been recently changed by someone else. Highest revision Bosch Audi spark plugs and current revision "T" on the coil packs. I did a diagnostics scan with my vag com and it said there was a misfire in cylinder 5 and 7. I heard these build up alot of carbon and wondering what steps I should take to taking better care of this.
    From the 4 comments I had, 3 were recommending to look at the tensioners, so I may be doing that soon. I'll probably wait on any mods until this summer.
    So this thing has "I think" a 2g MMI plus (red screen by tach and speedometer). Anyone know of a way to update it? I also have a NAV button, but when it's pressed, it says, "NAV NOT INSTALLED". Would be interested in knowing what it would take to get the navigation going. CD changer and nav cd? cables?
    Thanks again for your help guys.
    Jake
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    If I took a video of the start up would you guys be willing to tell me what you hear, if anything? I am not really sure what it is supposed to sound like.
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    Hereis a video of my engine strting up:
    Veteran Member Four Rings Kevin1's Avatar
    Oct 19 2008
    Long Island
    Take a look at what happened with my 05 4.2 at higher miles. This should give you an idea of what to look for.
    Miles Service
    884 Miles Warranty
    1) MMI hardware replaced
    5,283 Miles Warranty
    1) 5,000 mile service
    10,152 Miles $126.53
    1) Oil Change
    14,775 Miles Warranty
    1) 15,000 mile service
    2) tighten front passenger seat
    3) tighten air vent outlets
    4) update airbag software
    5) tighten dashboard
    6) update MMI software
    20,059 Miles $112.74
    1) Oil Change
    2) tighten dashboard
    20,685 Miles Warranty
    1) Replaced pollen filter door
    2) Replace tire pressure sensor
    3) Replace Mmi control knob
    24,727 Miles Warranty
    1) 25,000 mile service
    3) replace windshield wiper blades
    28,506 Miles $204.97
    1) Brake fluid flush
    2) Repair front passenger seat frame
    3) Replace license plate light bulb
    4) Update MMI software
    5) Repair ski sack
    6) oil change
    28,620 Miles Warranty
    1) Replace all 8 coil packs
    2) Replace throttle control valve
    29,806 Miles Warranty
    1) replace fuel door cover
    2) update airbag software
    32,254 Miles Warranty
    1) Replace front brake pads
    2) clean HVAC drains
    3) replace pollen filter
    33,926 Miles Warranty
    1) Replace rear brake pads
    2) Replace fuel filter
    3) Lube steering column
    4) Tighten dashboard
    5) 35,000 mile service
    36,129 Miles Warranty
    1) Update fuel gauge software
    2) Replaced power steering hose clamp
    36,739 Miles Warranty
    1) Replace interior light in driver's footwell
    37,715 Miles Warranty
    1) Update airbag software
    40,759 Miles Combination Warranty/$341.74
    1) Transmission fluid flush
    2) Replace fluids in differentials
    3) oil change
    44,754 Miles Warranty
    1) Replace steering column
    2) convert front brake pads
    3) 45,000 mile service
    49,419 Miles Warranty
    1) Replace head cover gasket
    2) Oil Change
    50,283 Miles Warranty
    1) Replaced rear sunshade motor
    54,659 Miles combination warranty/$891.32
    1) coolant system flush
    2) replace coolant temperature sensor
    3) replace fog lamp
    4) replace trunk latch
    5) 55,000 mile service
    56,440 Miles combination warranty/$110.29
    1) update ECU module
    2) replace tire air pressure sensors
    3) replace windshield wipers
    60,168 Miles combination warranty/$241.49
    1) oil change
    2) brake fluid flush
    3) replace rear seat air bag ignitor
    61,040 Miles $1,186.67
    1) replace front brake pads and rotors
    2) replace rear brake pads and rotors
    65,209 Miles combination warranty/$323.54
    1) 65,000 mile service
    3) replace parktronic speaker
    65,635 Miles $435.50
    1) replace thermostat
    66,553 Miles $168.85
    1) Replace light bar in front passenger door
    66,848 Miles $268.20
    1) Replace wood trim on driver's front door
    69,020 Miles $123.55
    1) Oil change
    70,741 Miles $287.34
    1) Replace rear right tail light assembly
    2) Clear air bag codes
    75,099 Miles $761.88
    1) 75,000 mile service
    75,762 Miles Warranty
    1) replace center rear seat air bag sensor
    2) replace rear seat bracket
    80,187 Miles $1,223.61
    1) oil change
    2) flush transmission fluid
    3) replace brake fluid
    85,450 Miles $320.44
    1) 85,000 mile service
    87,879 Miles Warranty
    1) replace rear seat air bag sensor connector
    2) readapt tilt wheel steering column
    90,746 Miles $826.97
    1) oil change
    2) replace oil pressure sensor
    3) re-adapt steering column
    4) replace rear brake pads and rotors
    93,793 Miles combination warranty/$315.09
    2) replace front brake pads
    95,964 Miles $720.33
    1) 95,000 mile service
    2) replace battery
    100,600 Miles $1,529.52
    1) oil change
    2) replace all 8 coil packs
    3) replace fuel filter
    4) replace brake fluid
    5) coolant flush
    6) replace supplemental rear passenger air bag
    103,924 Miles $1,191.74
    1) 105,000 mile service
    2) replace passenger tailight assembly
    3) replace right side motor mount
    110,515 Miles $2,277.12
    1) oil change
    2) replace all 4 upper and lower control arms and tie rod ends
    3) replace both side sway bar links
    115,704 Miles $861.73
    1) 115,000 mile service
    2) 4 wheel alignment
    3) replaced left side license plate bulb
    4) replaced passenger side running light
    120,490 Miles $1,105.50
    1) oil change
    2) replace transmission fluid
    3) replace differential fluids
    124,683 Miles $2,303.08
    1) 125,000 mile service
    2) replaced front brake pads and rotors
    3) replaced rear brake pads
    4) replaced satellite radio module
    5) replaced battery
    127,496 Miles $552.87
    1) replaced rear passenger window regulator
    2) replace passenger sider amber light bulb
    133,383 Miles $1,516.17
    1) replace jet pump valve
    2) replace engine temperature sensor
    3) replace both radiator hoses
    4) coolant flush
    5) brake fluid flush
    6) 135,000 mile service
    133,600 Miles combination warranty?$502.96
    1) replace right side combi valve
    2) replace passenger side adaptive headlight assembly
    133,714 Miles $225.52
    1) fuel injection service
    134,585 Miles $1,977.74
    1) replace vacuum line under manifold
    2) replace temperature sensor
    3) replace driver side adaptive headlight assembly
    135,880 Miles $493.54
    1) replaced thermostat
    2) bled coolant system
    3) replaced rear passenger side seat latch
    137,015 Miles $1,540.46
    1) replace drivers air bag
    2) replace wiper blades
    138,250 Miles $849.93
    1) replaced radiator
    138,682 Miles $9,116
    1) oil change
    2) replace torque converter
    3) replace timing chains
    4) replace timing chain guides
    5) replace timing chain tensioners
    138,939 Miles Warranty
    1) replace intake manifold
    2) replace all coil packs
    3) replace all fuel injectors
    4) replace fuel distributor rail
    5) replace front heated oxygen sensor
    6) replace combi-valve
    19 years and 320,000 miles behind the wheel of an Audi
    2022 A6 55 3.0 Prestige with Luxury Package and Black Optic Sport Package (all options). Daytona Gray Pearl Effect. Sarder Brown Interior. (July 2022 - presesent)
    RIP Audis
    2015 A6 TDI Prestige All Options except B&O - (August 2014 - July 2022) (146,179 miles)
    2005 A6 4.2 Prestige All Options - (February 2005 - August 2014) (141,179 miles)
    Sep 22 2014
    Fort Wayne, IN
    Quote Originally Posted by Markie93 View Post
    Not to rain on your parade, but just wanted to make sure you're aware that to do the timing chains on the 4.2, the motor has to come out. It's a very time consuming involved project. Not something that can be done by your average DIY'er. Now you may be able to do it by dropping the transmission instead, but either way, something's got to come out to get to the chains.
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    Is it in the back of the engine?
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    So is it a timing belt, or a timing chain? I've seen some people just take the front off and expose a timing belt and I've also heard and seen people talk about a timing chain in the rear. How do I know which I have? What a Bentley service manual be of any help?
    Veteran Member Three Rings Storm33's Avatar
    May 13 2008
    Cape Coral, FL
    You have a timing chain. Your startup video sounds like there may be a bit of rattle in the tensioners, but it doesn't seem bad. My B6 S4 had about the same 1/2-second rattle on startup and didn't seem to get worse over the time that I owned it, so you may have some time before you need to worry about it.
    There was another thread on here recently about upgrading 2G -> 3G; the verdict seemed to be live with 2G or buy a newer model with 3G. Apparently it's cheaper than upgrading the hardware in your 2G vehicle.
    Nice looking A6, by the way - congrats!
    2011 Q7 TDI Prestige S-Line, Orca Black / Black
    2012 Q7 TDI Premium Plus (Sold back to Audi), Mugello Blue / Limestone
    2010 C6.5 S6 Prestige (Guh-bye!), Phantom Black / Black; RS6 Grille
    2009 B8 S5 (R.I.P.), Silver / Black; Nav, Tech, ADS, B&O; MTM Catback, H&R OE, RS5 Grille
    2005 B6 S4 MT6 (Sold), Silver / Black, RS4 Sways
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    Thanks a ton! So I am guessing the tensioners, and chains are in the rear of the engine?
    Veteran Member Four Rings Dutch_A6's Avatar
    Aug 19 2012
    GMC Terrain
    Belleville, IL
    Correct, in their over-engineering wisdom Audi believes the parts are good for life and so put it in the most difficult place in case something actually does go wrong it will be a major service to fix.
    Black 2012 A7 Prestige
    Zito ZF01 wheels
    EPL stage 2 tune
    Tinted marker lights
    Roc Euro intake
    AWE touring exhaust
    APR CPS
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    Are there any DIY for the tensioner/chain change? WOuld the Bentley Service Manual help with this?
    Are there any recommendations as to what to change while its all out? I know of my A4 (back when just removing the entire front end was enough), I changed the Timing belt, tensioners, water pump, thermostat, and seals. Would I be changing all of the chains, looks like there are more than 1?
    Jul 02 2013
    406, MT
    I would get a bentley manual, check over in the S4 forums as well to see more engine specific things to check/do while your doing the timing chain guides and tensioners. I suggest going with JHM intermediate kit as the only thing its missing form the full are the chains themselves and the electrical adjusts. I haven't heard of either of those ever going bad in these cars though.. Heres a link, JHM Intermediate Kit
    You should be good for a while, maybe even replace the oil check valves to hold you over longer. Im at 111k and haven't had any problems.
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    Thank you so much
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    Anything else guys? Thanks again for all your input!!
    Jul 02 2013
    406, MT
    I would tint your windows!
    In all honesty you should be good if you trans fluid is fresh, the only thing besides the timing chain tensioners and adjusters is the AC pump.
    It's good to change it before it fails because the fail safe doesn't like to break and it causes the system to shred itself when it fails and gets metal shavings all through your AC system... Theres just about no way to get them all out unless you change all of the lines.
    Veteran Member Four Rings c@@kieMonsta's Avatar
    May 17 2009
    Idaho
    I would highly recommend replacing the fuel filter also. Its a $30 piece that takes 10 minutes to replace. It's another one of those things that is claimed to be a "lifetime" part but honestly should be replaced once a year or so.
    Current:
    2019 Ford Expedition
    2009 3.0T A6 Avant w/Prestige package, Side Assist, and Cold Weather package
    2016 2.7 EcoBoost Ford F-150 XLT SCREW
    2007 3.2 A4 Deep Sea Blue Avant
    2006 A6 Arctic White Avant
    2002 1.8t A4 Sedan
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    Hmm... I will definitely be inspecting the AC. Thanks for the info. I would like to tint the windows, but here in Michigan, we can't tint the front which kinda sucks.
    The fuel filter would also be something easy to do I guess. I'll look into that as well.
    Thanks guys!
    Feb 06 2013
    CA
    Thanks guys!
    Here's the write-up for the fuel filter change on your 4.2. It's quite easy, especially with a lift ;)
    http://www.audizine.com/forum/showth...=1#post9902420
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    Sweet! Thanks Sun dance!
    much appreciated
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    Wow, actually a lot of good info on that thread. Please excuse my little known knowledge on this subject, but what exactly does the carbon cleaning entail? I'm sure mine has some carbon buildup. Ill do more reading but figured it wouldn't hurt to ask.
    Jul 02 2013
    406, MT
    Your car doesn't have carbon problems. Only the FSI (Direct Injection) Motors have carbon issues.
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    I thought the 4.2L's were "Fuel stratified injection", are they not? I have had a small misfire in cylinder 5 and 7 (already has new splugs and coil packs) wondered in injectors were clogged...
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    I am still new to all the terminology...
    May 17 2009
    Idaho
    Your 4.2 is the 40V V8 carried over from the previous C5 generation. The "new" 4.2 32V with FSI didn't show up until '07 in our cars.
    Current:
    2002 1.8t A4 Sedan
    Feb 23 2013
    2013 Audi A4
    Cleveland, WI
    Ohh... Interesting.
