Edit: that's with "or" without. Gotta stop posting using my phone.
For those of you tracking your cars which produces better lap times, leaving ASR on or turning off (only first lvl of stability control switched off)? Also, do you see more tire wear with it off?
I used to think turning off was faster as the rear will rotate out a little. Now however I'm not sure. I thought allowing the rear to slide produced a more rear wheel drive attitude thru corners and thus overall higher speeds. But now I'm thinking all it does (turning ASR off) is cause the car to push thru the natural under steer the car has. Using ASR then actually maximizes Corning speeds by allowing for different wheel speeds, which counteracts push. It doesn't feel like a rear wheel drive car because the car doesn't 'sit' on the outside rear tire like I was taught to expect when maximizing cornering speed. You would then control rotation with the throttle.
If correct this means when cornering our AWD cars one should not point the nose at the apex upon turn in as they would in a RWD car. Rather one should drive around the corner rather than at the corner.
