Results 1 to 18 of 18
    Sep 21 2014
    2001 b5 a4 1.8l awm quartro, 2014 corolla s plus, 2013 corolla s
    anderson south carolina
    O2 spacer for test pipe???
    ok im bout to start building my exhaust probably going to go 3in straight piped with test pipe but I don't want a cel im thinking about using a o2 spacer I know they are not guarantied but I just want to know what yall have had the best luck with and yes I know I can just get it tuned and get the o2 deleted but im just not at that point in my build yet
    Veteran Member Four Rings jeffrey146's Avatar
    Feb 19 2012
    04 S4 nogaro avant MTQ, 2013 CT200H F sport, 93 EG hatch
    Draper, Utah
    Do not use a spacer for anything but to pass inspection. your ECU uses the second 02 sensor. you need to get it tuned out to prevent a CEL.
    CHECK OUT MY BUILD THREAD!!!
    Noggy S4 Avant MT B6
    OZ superleggera 3, Pilot SS , 034 (Trio, adjustable uppers, Zero gap snub, rear sway with endlinks) APR full exhaust with drilled cats, H&R Coilovers, Red rear diff mount, JHM (NO2,Center diff, rear LSD and stage 4 kevlar clutch with LWFW)
    ...BBK coming soon
    Veteran Member Four Rings pbcrazy's Avatar
    Feb 06 2013
    VA
    Grammar. And search (using grammar)
    98.5 Audi A4 1.8T Quattro | 5 Speed | AEB | Laser Red
    | FrankenTurbo F21L | United Motorsports Stage 3 | 630cc Injectors | 3" MAF | ICM Delete w/FSI Coils | Scorpion 2.5" Catback/RAI 3" Test Pipe | Forge 007 | 034 Silicone PCV | Alzor 349 | FMIC | ECS RA4 LWFW/S4 Clutch/S4 P.Plate | AEM | Krauto | etc.
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    I have a gutted cat with the secondary 02 spaces out using a 45 degree spacer. Runs just fine. I get a light once in a while but I passed my emissions test with the light off. I was laughing the whole way through.
    Sep 21 2014
    so sounds like if I put a test pipe and put a spacer on post cat o2 I should be good
    Oct 10 2013
    State College PA
    NEVER put a spacer on the first o2 sensor. The second one is fine.
    Dec 22 2013
    MA
    I have a 90 degree one like this http://www.amazon.com/Degree-Angled-.../dp/B00B1U6I54 mainly because I have a b6 test pipe and the rear o2 bung is in the wrong spot. Don't have the rear o2 tuned out and I've never had a CEL
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    Quote Originally Posted by jeffrey146 View Post
    Please tell me why. Because I don't believe you.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Feb 19 2012
    Draper, Utah
    Quote Originally Posted by Avant Nate View Post
    I've heard from a few people that the ecu uses the post o2 sensors and that it can fuck things up
    ...BBK coming soon
    Sep 21 2014
    well that makes sense kinda if the ecu doesn't use the pre cat o2 then what is the point but ok I reckon when I get my test pipe JHM spacer for the post cat o2 by the way nice slipping in with the advertisement for 30 bucks cant beat that
    Veteran Member Three Rings Koldham's Avatar
    Aug 12 2012
    Walnut Grove, Georgia
    Quote Originally Posted by gearhead9992 View Post
    except with the $2.99 autozone ones.
    1997 A4 1.8QTM AEB Pearl DD
    Deer Strikes:0 HELLASTOCK...ish WTB: pearl white body panels.
    1973 Ford Maverick Project Car(first car)
    200 I6 -> 302 V8, 3spd column shift, 8.8 with traklock. Bright Ass Orange.
    Sep 21 2014
    true
    Feb 06 2013
    VA
    People say it does but I've never seen proof of this, If it does it doesn't use it for much in terms of fueling. Lots of people (including myself) run with spacers with 0 problems, and since I have a wideband I can assure you AFR values are just fine with a spacer.
    Oct 10 2013
    State College PA
    Spend real money on the spacer. The 3$ ones from autozone aren't big enough for the sensor.
    Feb 06 2013
    VA
    Quote Originally Posted by Davdraco1 View Post
    You could always buy 2 for $6 and stack them.
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    tbis thread is funny
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Oct 10 2013
    State College PA
    I tried that, but I had to drill out one of them so the sensor would fit in, drilled the lower threads right out. Went and bought a 30$ one meant for o2 sensors and it works beautifully.
