Results 1 to 23 of 23
    Dec 07 2009
    East Coast
    Project Atlas
    I picked up one out of a handful(literally) B6 S4s in Atlas Gray. Yeah you heard it right Atlas Gray B6 S4, they do exist out there in the wild. I happened to be one lucky guy(out of very few).
    Now a little lesson on the color itself and rarity of Atlas Gray B6 S4s. Atlas Gray is mostly known as B6 A4 Avant color. It was an option in a factory line up of colors for 2002 B6 A4 sedans and only a special order for same year B6 A4 Avants. For the following years 2003 through 2005, Audi decided to switch it up. Meaning, it was never offered for A4 sedans again as an option, unless you ponny up and special order it, for A4 Avants though it became an optional color choice and hence quite a popular one at that time. Now on the other hand, Atlas Gray was never an optional exterior color choice for B6 S4s both sedans nor avants. Therefore the only way you could get your B6 S4 in this color is by special ordering it and paying up some extra on top. IIRC $2500. According to AOA, only five Atlas Gray B6 S4s were ever made for and sold in US market. Here's the breakdown:
    MY2004: 2 Manual Sedans, 1 Manual Avant
    MY2005: 1 Manual Sedan(mine), 1 Automatic Sedan
    So technically mine is one of a kind or one out four sedans, one out of four manuals, one out of five Atlas Gray B6 S4s ever built for the US market. Now the true unicorn ladies and gentleman, to me at least, is the only Atlas Gray B6 S4 Avant! One of a kind anyway you look at it. Current owner is one lucky fella to have such a rarity in his stable.
    The priority of this build thread is as follows:
    1. Maintenance
      First and foremost, I'll be catching up to all of the maintenance that is overdue along with some preventative stuff, so I could sleep at night.
    2. Handling
    3. Performance
      I'll be going all the way with this beast, but one step at a time.
    4. Aesthetics
      All of the cosmetic mods will be squeezed in here and there in between the above three stages, except for an expensive stuff, which will be left for the very last. At least that's the master plan, but you never know when a great deal comes along that's hard to pass.
    I'll be documenting every single change of my car as it happens with lots of pictures, part #s, reviews, etc... Hopefully this thread will be as exciting for you to follow as it is for me to build my dream B6 S4, perhaps daunting at times, but mostly fun :) Keep in mind, I'm not here to gain approval of the masses, however constructive criticism and suggestions are always welcome. Furthermore whenever someone finds any of the information I put into this thread useful in some way or another and has a positive feedback, it's always welcome like an icing on a cake ;)
    The car will not only be a garage queen, but will also be taken through different kinds of performance measurement methods to asses real world performance gains from each and all of the modifications.
    Subject:
    2005 Audi S4 sedan Quattro MT6
    4.2L V8 DOHV 40V
    340 hp @ 7000rpm
    302 lb.-ft. @ 3,500rpm
    GVWR 2230kg/4916lbs
    Atlas Gray Metallic Exterior
    Black Nappa Leather Interior
    6-Speed Manual Transmission
    Premium Package:
    • Glass Sunroof (W/Power, Tilt, Slide)
    • Homelink (R) Remote Transmitter
    • Auto-Dimming Interior Mirror W/Compass
    • Auto-Dimming Exterior Mirrors
    • Memory For Driver Side Seat Adjustment
    • Memory For Driver Side Mirror Position
    • Light Sensor Package
    Premium Audio Package:
    • Bose(R) Premium Sound System
    • XM(R) Satellite Radio
    Heated Front Seats
    Power Rear & Manual Rear Side Sunshades
    Carbon Fiber Interior Trim
    E0A = No special edition
    7A0 = Without CD changer/CD player
    4UB = Air bag for NAR
    6XL = Exterior mirrors: with memory function, automatically dimming, electrically foldable/adjustable/heated
    5SG = Left exterior mirror: flat
    5RW = Right exterior mirror: convex (US) large viewing field
    1KE = Disc brakes, rear
    J1U = Battery 450 A (95 Ah)
    1LJ = Disc brakes, front
    1BD = Suspension/shock absorption for special sports design
    3FE = Electric slide/tilt sunroof with sun screen/sunblind
    5MK = Decorative inserts, carbon weave
    7X0 = Without park distance control
    4R4 = Power windows with comfort operation andcircuit breaker
    F0A = No special purpose vehicle, standard equipment
    8GH = Alternator 190 A
    0G1 = Gearshift lever
    0YM = Weight range 12 installation control only, no requirement forecast
    0JL = Weight category front axle weight range 11
    T79 = 8-cylinder gasoline engine 4.2 L unit 079.C (aluminum)
    3NZ = Rear seat bench unsplit, backrest split folding
    8EH = Bi-functional headlight with gas discharge lamp, for driving on the right(US design)
    U1B = Instrument insert with mph speedometer, clock, tachometer and trip odometer
    X9A = National sales program USA
    1N3 = Speed-related variable steering assist (Servotronic)
    2PL = Leather trimmed sports steering wheel for air bag system with "S" badge
    8Q3 = Automatic headlight-range adjustment dynamic (self-adjusting while driving)
    9Q4 = Multi-function display/on-board computerwith check control
    8Z6 = Hot country
    D5E = 8-cyl. gasoline engine 4.2 L/253 kW 40V multi-point injection base engine is T79
    7Q0 = Without navigation device
    CS1 = Alloy wheels 8J x 18
    7K0 = Without tire pressure warning light
    4X3 = Side air bag front with curtain air bag
    2K4 = Standard bumpers
    6R2 = Leather gearshift boot
    3L4 = Electric seat adjustment for both front seats, drivers seat with memory system
    4KC = Side and rear windows in heat-insulatingglass
    3Y5 = Electrically operated roll-up sun screenfor rear window and mechanically operated for side windows
    4K8 = Radio remote controlled central locking operated from inside, front and rear and separate trunk release "SZV"
    5D2 = Carrier frequency 315 MHz
    1SA = Without additional front underbody guard
    0GM = Emission standard LEV 1
    Q1E = RECARO sports seats, front
    4GP = Windshield in heat-insulating glass withsunshield and viewing window for vehicleidentification number
    Extras from PO:
    • Audi all-weather sport floor mats
    • Kenwood DDX712 head unit w/navigation
    • S4 brake caliper clips
    • Front Euro License Plate Bracket
    • Tinted windows
    • F&R red painted brake calipers
    • SS brake lines
    • F&R drilled&slotted rotors
    • Miro-111 19x9.5 ET40 on 245/35/19 Goodyear Eagle GT
    Since everyone here loves pictures, and so without further delay:
    Driving back home from Augusta, GA the day I purchased this gem
    Couple of reflection shots of the Miro 111s as well as assistant perpetrator
    Forget the B8, keep the V8!
    Dec 07 2009
    East Coast
    And some pictures before it's first wash:
    Dec 07 2009
    East Coast
    I. Maintenance
    Overall assessment of the S4 is it needs lots of TLC!!! I'm very anal regarding cleanliness and overall condition of my cars, so to average person it's probably in a normal used condition
    PPI performed by myself and with the help of Gerald Jones Audi for the compression and leakdown tests, which came out great by the way! No engine ticking or other abnormal sounds/noises during operation and no smoking from the tailpipes. Pretty much clean bill of mechanical health. I was quite pleased with that.
    Clean title and body has no paintwork, except for the rear bumper, verified myself via paint meter. Exterior has a few very light scratches and a couple of light dings without any paint damage. No massive amount of rockchips as well from highway use, only found a handful on the front facia. Half rolled front fenders(literally), whoever did it, did it halfass way. So here's what I'll be doing in the near future: full detail, PDR, fix previous poor attempt at fender rolling as well as regular and preventative maintenance items.
    Also this needs to be noted, it is one of the late built B6 S4s (09/22/04), I could tell by the obvious build date, as well as plastic mirror housings(instead of aluminum) and bright silver intake manifold just like on all of the B7s instead of gunmetal on 2004 and early build 2005 B6s.
    Mileage at PPI 73372
    Compression Test:
    CYL #1=145 #2=150 #3=145 #4=140 #5=145 #6=145 #7=145 #8=140
    Leakdown Test: 2% on all cylinders
    To Do List:
    Coolant Expansion Tank
    Coolant Flush w/OEM G13 or Motul - not sure which one yet, thoughts?
    Spark Plugs
    Fuel Filter
    PCV
    Valve Cover Gaskets
    Valve Covers to be stripped and powdercoated
    Completed:
    • Battery cover (OEM) p# 8E1 819 421
    • Battery (OEM) p# 000 915 105 DK
    • Engine oil&filter change with Mobil1 0W-40 Euro Formula and OEM filter.
    • Air intake filter (OEM) p# 079 133 843 A
    • Cabin air filter (OEM) p# 8E0 819 439
    • B7 RS4 jack pad kit (ECS) p# ES#2598405
    Dec 07 2009
    East Coast
    II. Handling
    Reserved3
    Dec 07 2009
    East Coast
    III. Performance
    Reserved4
    Dec 07 2009
    East Coast
    IV. Aesthetics
    Exterior:
    • Mirro 111 19x9.5et40
    • B7 S4 brake caliper anti-rattle clips
    • Aluminum exterior mirror caps
    Interior:
    • Silver alcantara Recaro seats
    • RNS-E euro version
    • XM/Sirius module (RNS-E compatible)
    • B7 glovebox w/CD-changer
    • B7 beltline buttons with chrome accent strip
    • B6 USP steering wheel
    • B6 USP shift knob
    • B6 USP e-brake handle
    Jun 18 2010
    2004 Boxster S Special 1953 Edition
    East of Cincinnati
    Reserved6
    For Sale
    Old Geezer, formerly known as Stud Muffin
    Dec 07 2009
    East Coast
    Quote Originally Posted by QIKRNU View Post
    Reserved6
    For Sale
    Yeah maybe not... lol This rare gem is staying with me for the rest of it's journey. On the other hand, it's funny you should mention this as I'm in the process of selling my other S4 hah
    Senior Member Three Rings discoverdeath's Avatar
    Aug 15 2010
    anahiem
    Seriously a sexy combination. I love that color on the avants that frequent my area, on a sedan most specific an s4 for that matter.... Would kind of be my forever toy. Never let go of that car man.
    Veteran Member Three Rings Whatset's Avatar
    Dec 02 2008
    Jeep & a Vespa
    Left of center
    Nice pickup dude! Congrats
    Dec 07 2009
    East Coast
    Quote Originally Posted by discoverdeath View Post
    Thanks! I believe so too Definitely last destination for this S4, this one is a keeper! I actually almost purchased one of the manual '04s back in the late 2012 from Audi in California, but someone beat me to it. That one had less miles, alcantara interior and was just in an immaculate untouched condition, not to mention the price was really great. It went to the new owner in St.Louis. He got one hell of a deal.
    Maybe some St.Louis members spotted the car I'm talking about and will chime in???
    Quote Originally Posted by Whatset View Post
    Thanks man! How's that S2K build going?
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    Atlas Grey DOES look better on the S than the A; good grab!
    2015 B8 SQ5
    Click Here
    Past
    Dec 02 2008
    Jeep & a Vespa
    Left of center
    S2k is still coming along, much slower now. Just had my front fenders re done and got the headlight blanks made.
    My crew members are pushing me to enter Super Lap Battle (GTA) - I'm not gonna
    Newer pics in here https://www.facebook.com/poornslow
    Veteran Member Four Rings quattroism25's Avatar
    Jun 04 2007
    Exiled in Utah
    Nice acquisition.
    Daytona Grey S7
    MORO BLUE JHM modded V8 Sold
    Dec 07 2009
    East Coast
    Everything looks better on the S Atlas Gray and Quartz Gray are truly understated colors. Now if only I could find an RS4 in Quartz
    Man you're building a beast hehe Keep up the good work
    Quote Originally Posted by quattroism25 View Post
    Nice acquisition.
    Dec 07 2009
    East Coast
    Well decided to do an oil report on that overdue Castrol Syntec 5W-40 that the dealer service department used and according to car records, seems like it's the only oil it's ever been filled up with. For 7,625miles on that Castrol, doesn't seem so bad. Blackstone Labs suggested for me to run it a little longer, but I decided against that and went with Mobil1 0W-40 European Formula. So we'll see how it goes.
    Dec 07 2009
    East Coast
    Also, went out and ordered four of these bad boys from Northern Tool, three days later and they're at my local store ready for the pick up:
    28 1/8" ground clearance should be more than enough to make things comfortable and double locking feature just for the peace of mind
    Dec 07 2009
    East Coast
    Well after quite a few miles and a little over four and half fun&reliable years together, had to say good bye to my first four ringed V8. It's been quite a journey to say the least. The car performed flawlessly and never let me down or left me stranded. Here's a quick picture timeline.
    After it's first major detail, all nice and clean.
    It's first winter and couldn't handle it any better than it did. Got out of it without an effort.
    Obligatory gas station pic with some minor frost biting.
    Do two S4s make it an S8?
    And the way the new owner picked it up. Probably cleaner than when it was new ;)
    BTW those are 245/40 tires, nice and meaty.
    Active Member Two Rings ONEFASTS4's Avatar
    Nov 06 2012
    2007 VW GTI, 2005 Audi S4, 1983 VW Rabbit, 2012 VW Jetta
    Augusta GA
    Hey just wanted to check on the car and see how it's doing. Guess you are doing what I expected. Taking great care of it. I did not even realize that the fenders were rolled. Looks good. Good luck with build.
    65 FORD GALAXIE 500XL CONVERTABLE
    83 VW RABBIT
    2007 VW GTI STAGE 3
    2012 VW JETTA (WIFE'S CAR)
    2005 AUDI B6 S4
    Dec 07 2009
    East Coast
    Quote Originally Posted by ONEFASTS4 View Post
    Hey thanks Jeff! What's going on with you bud, long time no speak. Yeah it's going at slow and steady pace, but going nonetheless. I've been quite preoccupied lately and haven't posted updates, but I'll catch up to that in a bit. How's that Stage 3 of yours coming along?
    Nov 06 2012
    Augusta GA
    Well let's see where to start. A few months after you bought the S4 I blew the motor at the 1/2 mile drag race. November last year clutch went out. December the turbo blew out in me so new motor clutch and turbo. She runs vreat all while dealing with my daughter being diagnosed with high risk stage 4 neuroblastoma cancer.
    83 VW RABBIT
    2007 VW GTI STAGE 3
    2005 AUDI B6 S4
    Dec 07 2009
    East Coast
    Truly sorry to hear that man, I'm not even going to touch on car stuff as that could be fixed, replaced, bought, etc...PMd ya
    Senior Member Three Rings Der Typ's Avatar
    Mar 04 2015
    Clawson, MI
    Hey Mr. Wrong! Nice addition to your previous lineup.
    Looks like we both got our hands on a nice S4 V8 around the same time. I bought my first one last year beginning of November. All I can say: I FRICKIN' LOVE IT!!!
    Last destination for my baby, as well.
    I will be following your project, since I am going to have some work done on mine as well. Control arms next month, then a fender swap due to rust and then a coilover. Probably in that order, too.
    Good luck with your V8!!!
