Results 1 to 8 of 8
    Veteran Member Three Rings vincent9993's Avatar
    Apr 02 2007
    Dune Buggy
    St-Leonard
    Reset "Service Due!" with VCDS Vag-Com [Fixed]
    I was trying to reset a Service Due! on an Audi S4 B8 and using the SRI Reset was not clearing the code. I had to manually reset Channel 53 & 55 to 0
    17-Instruments
    10-Adaptation
    Channel 53 [Distance since inspection]-> 0
    Channel 55 [Time since Inspection]-> 0
    When I ran the SRI Reset, both these values remained at 155 and 280 respectively.
    Not sure if this is a bug in VCDS or if it has to do with the fact that this is a Canadian car but I thought I'd share if anyone else is having issues.
    Now:2015 Phantom Black / Magma Red S4 Prem, MT6, ADS, Nav, Carbon trim
    - WeatherTech DigitalFit mats
    - Winter wheesl: 18x8 RS4 reps 245/40R18 Gislaved NordFrost
    I have Vag-Com
    Past: B5 A4 2.8, B6 A4 3.0, B7 A4 3.2, B8 S4
    Senior Member Two Rings IceSilverS4's Avatar
    Jan 06 2014
    2012 Audi S4, 2013 Tiguan R-Line
    Blainville, QC, Canada
    Did you do the SRI reset (Canadian only) on the selection list ?
    I did last night and all is well.
    Sold - 2012 Audi S4 - Ice Silver - Magma Red
    Apr 02 2007
    Dune Buggy
    St-Leonard
    I had not seen that but Ross-Tech told me the same thing. User error on my part in this case.
    I have Vag-Com
    Established Member Two Rings fignewton's Avatar
    Dec 08 2012
    2005 Chevy Avalanche Z71
    Broad Run/VA/mid-Atlantic
    Hmmm. I did an oil change Fri night. I reset the oil reminder in the "car" menu and then also used VAG SRI reset and did a full scan on Sat. This morning, the car told me "service due" again. Guess I'll have to retry.
    Current- 2024 Daytona Grey Black Optics SQ5 Prestige, Sport pkg, sport exhaust, 21" wheels, 034 sway bars
    Previous- 2018 Daytona Grey Prestige, 21" wheels
    2014 S4 Monsoon Grey, Premium, Black Optics, sport diff, black napa, B&O, Nav, Alu Kreuz, Michelin AS3s, tint, Eurocode intake
    2010 S4 Ibis White
    2002 TT 225, Aviator Grey, lots of mods
    Nov 03 2009
    UK
    I did a delivery (I think it was) reset to reset the inspection reminder.
    Ibis White 2012 Black Edition Audi S4 with Nav package, Black Napa, B&O, 19" rotors.
    Forge pulley with Unicorn Stage 2 and DSG map.
    Active Member Two Rings mungo513's Avatar
    May 14 2013
    Bridgewater, MA
    I could not get the service due! to reset. Tried both the SRI resets and Instruments/Adaption and resetting that value to 0. Only setting 53 and 55 did the service due reminder go away. I did update to v14.1 and that didn't matter.
    2018 SQ5 Prestige | Billet Silver Metallic
    2011 S4 | APR Stage 2 | Quartz Grey Metallic (long gone...)
    Veteran Member Four Rings Moose201's Avatar
    Aug 26 2012
    2013 S4 Ibis 6MT
    Quote Originally Posted by mungo513 View Post
    Did you use the selection list on the Operation drop-down menu (after you clicked the "Perform SRI" button)?
    www.coldwartourist.com - Exploring ruins & relics of The Cold War
    Prior: 2006 S2000, 2005 S4, 2004 Mazdaspeed Miata, 1999 M3
    Dec 08 2012
    OK, bringing this back up in case some have missed it. My son and I both have 2014s and could not get VCDS to actually change the "service due". This is where VCDS is not very clear.
    After digging a bunch, my son got it figured out on his car, and I did it this morning successfully. The post above is correct, but you have to know what you are looking for.
    When you start VCDS, you will see the "reset SRI" button. When I clicked this, it immediately started running through the modules. When it finishes, it says "done, go back" as your option. When I started, I was looking for the "Operation" menu at the top, but the first time you click "reset SRI" it was not there. The second time I clicked it, it was. Then, select "Reset USA", and I used the default settings and ran it. This time, it completed the reset and told me so at the end. Then, select "done, go back." I'll check again later, but I don't think that you can see the "Operation" pulldown from the main menu screen where you first see the "reset SRI" button.
    2010 S4 Ibis White
