Results 1 to 26 of 26
    Veteran Member Four Rings UkuRiSh's Avatar
    Jan 09 2010
    New York
    Oil Catch can for 2.7 Engine.
    Is it good way to do Oil Catch Can the way I did?
    Everything is pitched down.
    2013 AUDI S5 4.0T SWAP 9.7@145mph < Press @svarog_performance < last test updates
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Depends on what you mean by the part that goes to the cold air intake.
    Usually a sealed can is used when it goes back to the ypipe or you could be drawing in unmetered air.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Jan 09 2010
    New York
    Quote Originally Posted by zillarob View Post
    I meant connect hose from oil catchcan to intake pipe right before the turbo.
    Nov 16 2010
    WetSide, WA
    If in front of the maf, prob not ideal due to stuff contaminating the sensor.
    If behind the maf, it will be able to draw unmetered air through the filter on the catch can.
    Jan 09 2010
    New York
    My line will be after sensor. This is my plan 50-60% clean air through filter and 30-50% from oil catch can! Boosted engine should create vacuum in oil catch can which should help lower crankcase pressure and valve cover.
    Nov 16 2010
    WetSide, WA
    Unmeterd air is a bad thing.
    You might be able to put something like a ping pong ball inside the filter to stop this.
    Under normal vac, it would be sealed. If excessive psi builds, it would let it vta.
    Jan 09 2010
    New York
    Yes you right , thanks a lot. Someone post on my thread this link! looks like good idea.
    http://vibrantperformance.com/catalo...oducts_id=1243
    Nov 16 2010
    WetSide, WA
    Looks like a nice piece, but seems like it should be rotated 180deg to me?
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    How was your previous PCV system setup. I'm wondering if my catch tank setup will be good and not cause any issues. I'll be able to show pics soon.
    Veteran Member Four Rings ilyafil's Avatar
    Nov 03 2011
    Bay Area , CA
    No, that way is correct. The Venturi effect.
    "Basically the B7 is the girl you bring home to mom, and the B5 is her slutty sister."
    For Sale: Neuspeed Sport Springs
    Veteran Member Four Rings bobkatkat's Avatar
    Jun 07 2012
    North of the 49th parallel
    OP, You should either just vent to atmosphere or just put a line back to the intake past the MAF. Your lines to the catch can are really. really long, and the placement out in front will keep the separator cool which may not function as well in colder weather and with short runs (based on your sick build that probably does not matter). Have you considered just moving the can just behind the secondary firewall?
    That venturi diagram looks correct for one with the whistle style slot in the side. If it was just a angle cut then it would be better to be rotated 180 and more vertical.
    Jan 09 2010
    New York
    After little over a week and I drained my oil catch can. First was water and then milky oil, all together was about 20-25% liquid in my oil catch can.
    Aug 22 2014
    California
    Is a catch can really that beneficial?
    Nov 16 2010
    WetSide, WA
    You see that nasty crap in the pics? You want that in your oil pan?
    Jun 07 2012
    Damn that is a lot for just one week! Hard to tell from pics but how many oz do you think you built up over that short period of time?
    Jan 09 2010
    New York
    Quote Originally Posted by bobkatkat View Post
    I don't know how many oz but most of it was water 65-70% and 30-35% of milky. It was less than one third of it. Vacuum line is not connected yet that's could be and I think to install another separator for vacuum line. I don't want this carp in my turbo and intake piping.
    Jan 09 2010
    New York
    Ok just ordered this! I think connect another line to intake manifold with check valve! That way I can stop that stinky oil burn smell in my car at idle.
    Jan 09 2010
    New York
    Also add this as well
    May 09 2012
    Virginia
    Where did you get that catch can?
    Jan 09 2010
    New York
    Quote Originally Posted by jbain2 View Post
    This is air oil separate sell by JEGS $52 cheap
    •Maximum Pressure: 150 psi
    •Clear polycarbonate bowl for easy viewing and durability
    •Serviceable 20 micron element
    •Twist/turn drain
    JEGS Performance Products 52205 - JEGS Air Oil Separator http://www.jegs.com/i/JEGS/555/52205...FUsV7AodP1EAqw
    Nov 16 2010
    WetSide, WA
    That thing may be too small to do much.
    Jan 09 2010
    New York
    little more then this guy had.
    Nov 16 2010
    WetSide, WA
    When they say stuff like 1/4" npt and 3/8" fittings, seems a bit on the small side to me.
    May 09 2012
    Virginia
    That's what I was thinking. Isn't the consensus to run 5/8" hose?
    Nov 16 2010
    WetSide, WA
    5/8 is what I use. Nice to be able to reuse the connectors.
    May 09 2012
    Virginia
    That's my plan. Picked up an extra spider hose.
    OP what size line are you using. Did you decide on how to route things and where you were going to put your separator?
