I use whatever is OEM-specified. I think it's those NGK PFR6U11G platinum plugs you mentioned, that are supposed to last 40-80k miles. I did a calculation to compare the cost of much-cheaper-per-plug coppers, versus the OEM platinum. Turns out they cost about the same, the only difference being you have to rip apart the engine every 2 weeks to change the coppers (exageration) because they require changing every 5k miles (this is the general consensus, I hear using them longer results in poor engine performance and misfires). Whereas with the platinums, you install them, and forget about it for the next 5 years...
Not only do I like not working on the car, but I don't imagine the constant torque stress applied to the female threads of the cylinder head (IE: spark plug holes) is good for it, and I don't want to do a heli-coil or time-sert repair there, especially if I don't need to. Nor do I want the shavings that come with such a thing, to fall onto the piston top...
I'm not sure what coil-packs I have. I had the coil-pack recall done last year, where the dealer (for free) put new updated ones in, to replace the old recalled coils that caused the car to run poorly.
I am curious to know if there is any benefit to running other model coil-packs on this car.
Sjorge, why re-gap every 5k mi? I would guess that if our engines ran on diesel fuel, which explodes (unlike gasoline, which ignites and combusts), the pressure/force would put the plugs out of gap over time. Should we all re-gap plugs every so often? Damn, I just put mine back in...
Originally Posted by
MikTip
Well one one you 3.0L drivers pull the trigger on a set of R8 coils and be the test mule. Then report back here with ya findings!
Man that be like 2 hunnit dollaz right thur! Aint no joke!
SlickFix
From what I can tell from my initial research, the R8 plugs allow more spark and a bigger gap(.40?). I'm not really sure if this creates improved detonation or a smoother idle. But the 1.8 guys love them. Hopefully one of the bored 1.8 guys running R8 coils will see this thread and jump in to educate us.
I know the PO had some of the coil packs changed around 2009, but not all. For all I know, some could still be original.
