Next I needed to make the VCMS stuff work nice with the bin and car. This took me a while to figure out, particularly the ECU soft coding so I did not get errors.
I have a RossTech VAG-COM software and cable. I connected with the car and went to:
17- Instruments
Adaption -10
In the pulldown at the top choose (will fill this in later) which is Channel 60, set to 3073 (which removes the Transmission from the CAN Bus but still leaves allroad adaptive suspension active)
Then:
03-ABS Brakes
Login -11
Now because the bin I was using was already a manual bin I logged in with 07495 (this indicates Audi A6 (4B), PR-1LX brakes, 6/8/12 Cyl. Gasoline, Manual trans) as below:
0?xxx: Chassis
5 = Audi A8 (4D)
7 = Audi A6 (4B)
9 = Audi A4 (8D) / VW Passat (3B)
0x?xx: Brakes
3 = FNRG-60 (Teves/ATE) [PR-1LA/1LG]
4 = FN2/HP2 (Dual-Piston) [PR-1LX] & Brembo [PR-1ZL]
5 = FN3 (Teves/ATE) [PR-1LB/1LE/1LF/1LT/1ZC]
6 = C54 (Lucas) [PR-1LZ]
0xx?x: Engine
5 = 4/6/8 Cyl. Diesel
7 = 4/5 Cyl. Gasoline
9 = 6/8/12 Cyl. Gasoline
0xxx?: Transmission
3 = Manual with Low Range (only Audi A6 Allroad)
5 = Manual
7 = Automatic (01L/01N/01V)
9 = Multitronic (01J)
Once logged in :
Coding -07
set to 06395 (this sets Audi A6(4B), PR-1lx, 6/8/12 Cyl. Gasoline, manual)
0?xxx: Chassis
4 = Audi A4 (8D) / VW Passat (3B)
6 = Audi A6 (4B)
8 = Audi A8 (4D)
0x?xx: Brakes
1 = C54 (Lucas) [PR-1LZ]
2 = FN3 (Teves/ATE) [PR-1LB/1LE/1LF/1LT/1ZC]
3 = FN2/HP2 (Dual-Piston) [PR-1LX] & Brembo [PR-1ZL]
4 = FNRG-60 (Teves/ATE) [PR-1LA/1LG]
0xx?x: Engine
0xxx?: Transmission
5 = Manual
Here is where I was going in circles using the wrong coding.......
01-Engine
Login -11 using 11463
Coding -07 use code 06711 (TLEV (USA), All-Wheel-Drive with ASR/ESP (with CAN-Bus), 6-Speed Manual Transmission,
Audi A4) I was using the ROSSTECH chart as below and could not get the coding to change It needs to reflect that the engine is an S4 NOT an A6 as I was originally doing
??xxx: Emissions
05 = Euro II/D3
06 = TLEV (USA)
07 = LEV (USA)
08 = GUS/China
10 = Euro III
11 = Euro IV/Japan
25 = South Africa
26 = Mexico/Taiwan
27 = Brasil
xx?xx: Powertrain
5 = Front-Wheel-Drive
6 = All-Wheel-Drive without ASR/ESP (with CAN-Bus)
7 = All-Wheel-Drive with ASR/ESP (with CAN-Bus)
8 = All-Wheel-Drive with Post-Switch Stage (Low Range - A6 Allroad only)
xxx?x: Transmission
1 = 6-Speed Manual Transmission
5 = 5-Speed Automatic Transmission (01V)
xxxx?: Vehicle
2 = Audi A6
5 = Audi A6 Allroad
I cleared all the error codes in engine, abs, ecu, and (I had codes in leveling that I had to clear).
Lastly set ECU Throttle Body Adaption after the total install is done (have not done this yet)
Turn the key on but do not start the car.
[Select]
[01 - Engine]
[Basic Settings - 04]
Group 060
[Go!]
It should say "Basic Settings: OFF" on the top of your screen.
Click [ON/OFF/Next] to turn on Basic Settings.
It should now say "Basic Settings: ON" on the top of your screen. Once you do this you will see the top right display say ADP RUN. The TB adaptation is being done as soon as you switched basic settings on. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds.
Click [ON/OFF/Next] to turn off Basic Settings.
It should now say "Basic Settings: OFF" on the top of your screen
Click the [Done, Go Back] button and you're all set.
Be sure not to touch the accelerator and make sure the engine is NOT running when you do this!
I also removed the tmu from under passenger floor in the black box.
Now all the coding should be done, whew......
