What I used was an additive which is Liqui Moly Ceratec. "CERA TEC is a high-tech ceramic wear protection product for all motor oils. CERA TEC reduces friction and wear due to ceramic compounds that withstand extremely high chemical and thermal loads. Prevents direct metal-to-metal contact, thus increasing the engine service life. The low-friction effect reduces fuel consumption in gasoline and diesel engines." Im pretty sure you guys are super familiar with Liqui Moly and their fabulous witchcraft which proved to work.
After doing research and reviewing what might cause the nasty start up, I encountered this post in Audizine which talks about the possible cause of start up rattle is the check valve being stucked open, therefore, oil in the upper part of the engine will drip back down to the oil pan without retaining it. This will cause a wait time for the oil to travel back to the top of the engine to lubricate itself. I too almost bought the kit to change my check valve but I got laid off on the same day I bought it so i canceled my order.
So I was thinking, if oil drips back down to the oil pan, is there a way to keep some lubricant to attach itself to metal parts even though the engine is off for a long time? I started to research about oil additives and ceramic compounds which prevents metal to metal contact. And i found that Liqui Moly Ceratec provides protection up to 50,000 km. I was amazed how Ceratec can stay in the engine for that long even with continuous oil changes. If Ceramic compound stays in the engine for that long, it must be attaching itself to parts which adds a coating of protection in the engine. Its been a week now with 90% city driving in San Francisco, CA which has so may dam hills that causes extreme loads in low rpm. Ceratec has held up and still minimized the sound of start up as well as engine sound.
How I prepare my setup for Liqui Moly Ceratec:
1. Engine flushing using Lubro-Moly Pro-Line Engine Flush ( some people may think that this will damage the engine even more but I took the risk. It made my engine rev so much smoother and rev happy!
2. Do an oil change! ( I used mobil 1 0w-40. This oil is great but ive been burning oil like crazy so im switching to Redline 5w-40 on the next oil change to slow down the burning)
3. Since our engine requires 9.5 L of oil, leave 600 ml of room for Ceratec. ( You will have to buy two bottles. 1 bottle contains 300ml)
4. Warm up the engine and let it circulate!( you will probably notice a difference in a second start up)
Conclusion: I am not saying this cured my start up rattle but it did however minimize my start up rattle quite a bit! Some people may disagree of using additives and what not. Correct me if im wrong im always happy to learn new things. You can try this out and let us know your results after a few days/ weeks/ months! I will also keep updating my results in another week to see how it held up. Thank you!
