Results 1 to 16 of 16
    Established Member Two Rings PB4UGO's Avatar
    Oct 12 2010
    '14 A6 TDI - Previous RS4, 4.2 allroad, A4, A5
    Earth
    Lightbulb C7 A6 TDI Oil Change for the DIY'er
    Not everyone will agree with Audi Care's 10k interval approach to oil changes. This means either paying your servicing dealer (or indy) to execute an oil change, or do it yourself. I opted for the latter today and figured some of y'all might as well.
    The Oil, Filter and drain plug self-crushing washer were all ordered from EuropaParts (EuropaParts.com: Online shopping for Audi and Volkswagen parts, fluids, tools, and accessories). Quick, easy and no issues of any kind. I'll order from them again.
    Step one -
    Remove the TDI engine cover and say hello to awesomeness! I had removed the rear plastic cover for cleaning, you do NOT need to remove it for an oil change.
    Step two -
    Remove the oil cap and filter -
    Step three -
    Lift the car and notice how much detail Audi put into the under-body aerodynamics. The oil drain plug is under there!
    Step four -
    14 screws removed. It was a combination of the four large ones, three small ones and seven of the one-turn style things.
    This panel overlaps the front bumper tray cover and the transmission cover. It will drop out with little effort needed, but not fall.
    Of note, getting it back in takes a bit more effort to ensure that the overlaps are correct front to back.
    Step five -
    Hello oil pan!!
    Step six -
    Remove drain plug. Make sure the crush washer is (1) attached to the drain plug, (2) removed from the bottom of the oil pan or (3) fell into the oil catch pan. DO NOT DOUBLE STACK new and old!!
    Don't forget to put the drain plug back in and tighten to standard. The tightening was easy with a simple ratchet, no torque wrench needed. You'll feel it stop.
    Step seven -
    Replace the covers on the under-side. Again, make sure the panel edges overlap correctly front to back!! Tighten all screws and lower the car.
    Step eight -
    Oil filter gasket...don't forget to replace it. Peels right off. Lube the new one (it comes with the OEM filter) and replace.
    Step nine -
    Nipple down and towards the driver side of the car. Replace cap and tighten, like the drain plug, it will stop on its own.
    Step ten -
    Add oil.
    I started with 6.5 quarts and started the car. After I shut it off and let it settle a bit, it showed "OK." Drove home and checked again, and added ~.3 quarts more. This matches what the owners manual says is capacity, 6.8 quarts with filter.
    Step eleven -
    Check the oil level in the MMI.
    Step twelve -
    Have cold beer.
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    I don't have a TDI, but kudos on a very useful write-up for those who do.
    l Previous: 2013 S6 l Oolong Gray/Black l APR STG 2 l MILLTEK NON-RES l APR Downpipes l
    l 2019 e-Tron Prestige l Manhattan Gray/Black l XPEL Stealth Wrap l Vossen HF-3 Gloss Black l
    l 2022 Tesla Model S Plaid l Midnight Silver Metallic/Black l XPEL Stealth Wrap l
    l 2025 Rivian R1S Tri l Midnight/Dark Mountain l XPEL Stealth Wrap l
    Oct 12 2010
    Earth
    Quote Originally Posted by Brooklyn View Post
    The process should be similar for the 3.0T's as well. Don't y'all get a dipstick??
    Account Terminated Four Rings
    Mar 11 2014
    Dallas/TX
    Great write up brother. Especially the end btw through the dipstick we can do a top end oil change too. I am gonna do that after 4K miles .
    Veteran Member Three Rings 13allroad's Avatar
    Sep 26 2013
    2018 BMW x2 xdrive
    PHX, AZ
    Thank you for the post. I purchased the audi car when I got the car but will be changing at 5k intervals due to the high levels of dirt/dust in the air here in Phoenix, AZ. Somehow, the audi car for a a6tdi is the exact same price as the 3.0T a6, not sure how its the same price as the diesel cost more money in basic service, oil/ad blue, etc. Having removed the bottom cover mutiple times on my past allroad has moved me toward buying an oil extractor thus avoiding lifting the vehicle.
    I see you went with the Castro oil, did you get any of the additives?
    Current: Quantum Gray Metallic SQ5 / JB4 / Carbon Mirror covers
    Old:
    2014 A6 tdi prestige, HRE FF01 wrapped in Conti, black optic, sport package, LED package, RS7 Pedal Kit, 034 Trans mount, Alu Kreuz, Eurocode sway bars/end links, rear spoiler, Vag Com Mods, piggy back tune.
    2013 allroad tuned and modded.
    Weekend rider - 2015 BMW R Nine t - custom
    Oct 12 2010
    Earth
    Quote Originally Posted by 13allroad View Post
    With no dipstick on the TDI's, how are you going to use an extractor?? I don't think you can use an extractor though the filler neck...can you?
    No additives, don't really see a need. My TDI is running excellent and returning exceptional fuel mileage. Why mess with it?
    Sep 26 2013
    2018 BMW x2 xdrive
    PHX, AZ
    Extractor through the filler neck? Can anyone clarify, suggestions?
    Yeah I am not sure either.
    Old:
    Veteran Member Three Rings jrsAudiA6's Avatar
    Oct 11 2011
    2018 A5 SB
    Riverside, California
    Now, I do not have a TDI, but the oil dipstick did not come with my 3.0T A6. However, the tube for the dipstick is still present and just has a plug in it. I know have the oil dipstick and have use a fluid extractor thru the dipstick tube to extract the oil. It works great. Not sure if the TDI engine has the oil dipstick tube but if it does than that is what you use suck the oil thru when changing the oil with an extractor. So much simpler and that is how the dealers do oil changes, at least on the 3.0T engines.
    2018 A5 SB Matador Red Premium Plus
    2012 A6 Garnet Red, Prestige Pkg, Innovation Pkg, B&O, 20" Sport Pkg, H&R RSS + Coilover, Alcon Mono6/380mm front brakes, S6 rear rotors(356x22mm)/caliper carriers.
    034 DL fr suspension arms, 034 Track DL engine mounts, Eurocode Front and Rear sway bars & Alu Kreuz front brace, 034 ECU/TCU tune, DP PR 3.11, JHM Hx
    CTX 50% Tint F. S. Windows, CTX 30% Tint R. & R. S. Windows, 3M Pro PPF, hood, L & R fenders, AWE Exhaust w/o down pipes
    Established Member Two Rings /dev/null's Avatar
    Oct 26 2013
    '15 A4 Prem Plus // '16 A // ' '19 BMW 540i // '15 A3 // Honda Lawnmower :)
    North of Philadelphia, PA
    Sum Bitch! - I JUST did a oil change on my wifed A6 TDI on the 11th! I spent at least an hour Goggling where the darn filter was (eventually found it), but otherwise found the car extremely easy to work under (I use ramps). I ended up ordering a couple of filter sockets from Europaparts as well - forget the sizes (one for the A4, the other for the A6) as they are VERY low-profile and great UNDER the A4.
    Nice write-up on how to do it... wish I looked here FIRST, it would have saved me some time.
    Junior Member Two Rings
    Aug 14 2013
    Raleigh, NC
    Nice job, good pics. Step 8 - that's an o-ring, not a gasket. And I'd suggest tightening the oil drain plug and filter housing to spec, whatever that is. Tightening "until it stops" may not be quite enough.
    It's always a good idea to check for leaks after a DIY oil change just in case you didn't tighten everything down quite enough.
    Active Member Three Rings a4magnet's Avatar
    Dec 18 2011
    BMW M4
    Sweden
    Does anyone know the specs to tighten everything?
    Veteran Member Three Rings tenspeed's Avatar
    Dec 12 2011
    Honeoye NY
    Dip stick tube plug
    The part numbers for Audi C7 dipsticks:
    2.0 T: 06J115611E
    3.0 T: 06E115611H
    3.0 TDI: 059115 611AB
    Veteran Member Three Rings redrocker55's Avatar
    Feb 21 2010
    St Louis, MO (USA)
    Quote Originally Posted by a4magnet View Post
    Usually drain plugs are in the 22-28 lb range. Check your owners manual...it should be listed in the oil section/specifications. It should say 'oil drain plug torque'.
    The oil filter is hand tightened...once it is snug turn it another 1/4-1/2 turn and you are good to go. It has to be firm...but not Baja 1000 tight.
    2016 S6 Prestige, Misano Red Pearl, Driver Assist, B and O, Sport Pkg, Carbon Atlas, Black Headliner,
    Alu Kreuz, 034 Motor Sport DSG Insert, RS7 Intake Box, APR Stage 1 w/ Dongle
    Sold 2010 S4 Brilliant Red DSG with Prestige Pkg
    Sold 2008 VW GTI DSG
    Veteran Member Three Rings AdrianLee's Avatar
    Jul 19 2011
    2016 A7 3.0T & 2016 Q5 3.0T (Wife's Daily)
    SW Michigan
    30 Nm for oil drain plug
    25 Nm for oil filter cap
    C7.5 A7, APR Stage 2, APR Heat Exchanger, Fluidamper, AWE Exhaust, Eurocode Swaybars, RS7 Airbox, Trans Tune
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    All pics broken
    OP, would you mind updating this thread?
    Really need this info....
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Aug 17 2017
    Birmingham, AL
    Hate to bring up an old thread...but just wanted to say what a nice write-up you did on this. Thanks for taking the time...it is much appreciated!
