Anyways just thought i would ask and see if its worth making templates or just a one off.
I was thinking under the 200.00 range trying for 150.00
Any demand for this
Current:
2009 S5 6mt in Phantom Pearl Black
FBO 2007 e92 335i 6mt m-sport
FBO 2008 e92 335xi 6mt
FBO 2008 e90 335xi 6mt
Fully Bolted Nissan 350z 6mt
B6 Stage 2+ A4 5mt
2012 A6 3.0T prestige | Midnight Blue Metallic | Nougat | ACC | Stock (gone)
2003 1.8t 5spd FW(trash) Quattro swap (in progress) | audiUP snub | Depo Ecodes | Mini H1 retro | 4300k | 07k FSI coils | BKR6E | de-badged | BC Type BR | Swift Springs | BBS LM Reps 18x9.5 | 25FTG F+R | Tasteful poke
2019 SQ5 Prestige
Current:
B6 Stage 2+ A4 5mt
2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
2014 VW Tiguan. (bone stock)
2004 A4 Ultrasport 6MT "Almost-Brilliant" Black
APR 1+
2003 A4 1.8T Quattro | 18" BBS CH | KW V3 | FT F21 Mixed Flow | MOTOZA| RA4 Stage 1 w/SMFW | Milltek | Uni HFC/3'' DP Combo | 3'' TIP w/MAF | 550cc | TR1.8 FMIC | USP F/R | H-Sport F/R Sway | APR Snub | RS4 Motor Mounts | Stern Trans Mount | Skid Plate | Solid Tie Rod Ends | Short Shifter | Euro Shift Knob | VMR Boost Gauge | S4 F/R Brakes | Tyrolsport Stiffening Kit | ECS S.S. Lines | Hawk HPS Pads | 034 PCV
04 B6 1.8t Quattro - Audi TT 225 injectors APR DV - ECS Fuel pressure gauge stock K03 at 18psi for now (Bigger turbo & 60lb ev14s scat Rods coming soon) ST Coilovers - OEM Front Control arm kit - OEM sway bar bushing - CX Racing FMIC - Mirro 18s wrapped in 225 45 18r N3000 - Carbon Fiber Interior trim - Podi steering column pod and gauge - Straight 3in CAT - TT TUNING STAINLESS DOWN PIPE -Magna Flow B6 dual 2 1/2in Exhaust - TUNED by Napoleon at 18psi.
-CP
2008 2.0t S-Line Ti 6MT Avant
2017 Q7 3.0t
Former USP CLUB MEMBER #136
-CP
2017 Q7 3.0t
Costco 92 Octane Gas - MANN Air Filter - 235/35/19 Tires w/ 36 PSI (cold) Tire Pressure - Grey Plastic Valve Stem Caps - 0° Front Toe - Rotella T6 5W-40 - 2 OEM B6 Keys - 18x8" Spare - Coin & Pen Filled Center Console - Rain-X on all 8 windows & Napa Cold Temp Washer Fluid - Bosch Wiper Blades (Valeo wipers suck big time!) - S4 Trunk Latch - Craftsman Tire Pump w/ Automatic PSI Shutoff - Belly Pan Delete (Weight Savings) - 3D Printed Rear Warning Triangle latch - 174,000 Miles & Counting
