Which was causing the following fault code:
000665 - Boost Pressure Regulation P0299 - 002 - Control Range Not Reached
The diaphragm was badly torn and obviously that was causing the issue.
I replaced the torn DV with new GFB DV+ last week. The response on the gas pedal and acceleration is much better than before. However, now I have a new fault code which comes up all the time:
008801 - Boost Pressure Control Valve (N249) P2261 - 008 - Mechanical Malfunction - Intermittent
Why would this be happening after replacing the DV with DV+ and what could be the problem? Any ideas, what to log or look for?
I have full VCDS version.
