Car: 2000 Audi S4
Problem: Front Driver's inner CV Axle will not separate from transmission flange (6 triple square bolts have been removed)
I have a 2000 Audi S4 that I am attempting to remove the front driver's cv axle from. The outer end has been successfully removed from the upright/hub. The inner end will not separate from the transmission output flange. The 6 triple square bolts have been removed.
I have searched this and other forums but currently the only advice I have been able to find has been to use a BFH. I have attempted to persuade it out with a 4lb mini sledge, as well as with a chisel biting on the side of the hockey puck like end that mates with the flange. I attempted this until the point gear lube started leaking out of one of the bolt holes at which point I slopped and the leaking stopped as well (most likely compressed the seal to one side, with any luck it will still be ok).
Some background information. The Audi has been subjected to harsh, salty winters in Rochester New York from the previous owner and a harsh winter in Utah by me. Almost every bolt on the lower side of the body has either been seized or had the head snapped off upon trying to loosen it due to corrosion. I have had to cut quite a few off. I am in the process of cleaning her up so hopefully I won't have to deal with this again.
Any ideas on a more clever way of extracting this cv? I have air tools available. I would kill for a b6 style flange right about now. Here are a couple of the links to threads I have read through with similar issues.
http://www.audiworld.com/forums/audi...stuck-2166699/
http://forums.vwvortex.com/showthrea...n-Drive-Flange
http://forums.vwvortex.com/showthrea...e-Flange-Help!
Wish my underside looked like geeky's...
http://www.audizine.com/forum/showth...PDATED-Version
