Hi everyone. I've been drooling over APR's numbers since they officially announced yesterday and I know this question is going to be going through a lot of B8 owners' heads'. Has anyone investigated retrofitting the B8.5 intake manifold onto the B8 cars? As far as I can tell it should be a pretty straightforward swap to put in the components:
- B8.5 metal intake manifold w/ alcohol sensor + fuel injector
- New fuel line to the 5th injector
- New ECU + component recoding so they don't go into protection mode
The real problem is going to be figuring out how to wire the fuel injector and alcohol sensor so they can communicate with the ECU. Not saying it's cheap, but the APR stage II numbers are near enough to stage III that it could be worth it - specially if you happen to find the bits at the wreckers yard.
