Results 1 to 23 of 23
    Stage 2 Banner Advertiser Four Rings Arin@APR's Avatar
    Aug 23 2008
    Auburn, AL
    APR Presents the B8.5 A4 / A5 / Q5 & C7 A6 2.0 TFSI VL (Flex/Non Flex) ECU Upgrade!
    APR is pleased to present the ultimate engine control unit (ECU) upgrade for the 2.0 TFSI engine with Audi Valve lift!
    Product Page: http://www.goapr.com/products/ecu_up..._long_b85.html
    APR’s ECU upgrade is available in octane-specific variations and is conveniently flashed to the vehicle’s factory ECU through the OBD-II port without any physical modification to the factory ECU. APR’s patented EMCS functionality puts the control of your engine’s operation at your fingertips and allows for additional features and options to be installed to your OEM ECU.
    The Bosch MED17 engine management system is responsible for proper operation of the engine during constantly changing environmental and load conditions. With built in compensational data for environmental variables and varying load conditions, the factory ECU is far more complex and intelligent than units found in other vehicle makes and marques.
    APR’s Calibration Engineers spent months calibrating the engine management system, including many hours of chassis dyno development. With a thorough understanding of the ECU’s torque structure, APR’s Calibration Engineers properly increased engine load to produce more power and torque from idle to redline. APR’s ECU Upgrade increases turbocharger boost pressure and optimizes cam timing, valve lift, ignition timing, lambda and more to produce higher output. Ethanol 'flex fuel' compatible engine variants can take advantage of automatic E85 map blending to add power simply by filling the tank. Using APR’s proprietary high-speed data logging suite, the calibration team closely monitored the effects of these changes to ensure a powerful ECU upgrade without derogating the engine’s drivability or reliability.
    APR’s ECU Upgrade will provide an excellent leap in power and torque while retaining OEM knock control sensitivity and other built in safety features. The result is safely achieved power, optimized for various fuel grades found around the world. We call it Performance Without Compromise!
    APR ECU Upgrade
    The APR Stage I ECU Upgrade is designed to work without requiring other changes to the vehicle’s hardware. With the ECU Upgrade alone, APR’s Calibration Experts measured higher peak figures of 284 horsepower and with 334 ft-lbs of torque 93 AKI octane fuel. Large gains were seen throughout the power band, including an additional 57 horsepower and 85 ft-lbs of torque. By adding E85 to the tank on the Ethanol compatible variants, automatic Ethanol map blending adds even more power, resulting in 85 horsepower and 135 ft-lbs of torque. The increase in power directly translates to an exceptionally quicker and more enjoyable vehicle.
    By simply adding an APR downpipe exhaust system, APR's Stage II software, a free upgrade to existing APR Stage I customers, takes performance even further. on 93 AKI fuel peak figures of 302 horsepower and 334 ft-lbs of torque were achieved. Again, by adding E85 on flex fuel compatible variant, 318 horsepower and 405 ft-lbs of torque was achieved!
    APR’s ECU upgrade is the best power per dollar modification for the new 2.0 TFSI engine and takes the vehicle’s performance to similar levels typically reserved for higher output, sporty models, without pushing the limits. With factory-like smoothness and drivability, APR’s ECU upgrade will fill the void in an otherwise excellent vehicle.
    Acceleration Enhancements:
    Beyond power and torque enhancements, APR’s Calibration Engineers were able to increase the acceleration rate of the vehicle through other calibrations changes. Ignition delay is reduced resulting in a more responsive pedal without altering overall throttle sensitivity. Furthermore, drivability was greatly improved by reducing the throttle lag commonly noticed at slow speeds and while reapplying throttle after decelerating.
    Increased Fuel Economy:
    APR’s Calibration Engineers paid close attention to several parameters directly related to fuel economy, especially while cruising at highway speeds. Depending on driving style and fuel quality, better miles per gallon may be achieved!
    Speed Limiter:
    APR’s ECU upgrade increases the vehicle's top speed limiter for blistering sprints around the track or across the Autobahn without the speed limiter shutting down the fun!
    Left Foot Braking / Brake Boosting:
    APR's Left Foot Braking feature allows more control over the vehicle’s throttle. The factory equipped vehicle's throttle input is disabled while pressing the accelerator and brake at the same time. Left Foot Braking, a common motorsport driving technique, allows the driver complete control over the vehicle’s throttle and braking system, which may give the vehicle the edge it needs at the track. As is with all features APR adds to the ECU, this feature may be removed upon request.
    Power Output
    Additional Power Graphs
    All Wheel Figures | Estimated Crank Figures | Absolute Gain over Stock - APR Stage 1 - 91 Octane
    All Wheel Figures | Estimated Crank Figures | Absolute Gain over Stock - APR Stage 1 - 93 Octane
    All Wheel Figures | Estimated Crank Figures | Absolute Gain over Stock - APR Stage 1 - 100 Octane
    All Wheel Figures | Estimated Crank Figures | Absolute Gain over Stock - APR Stage 1 - E85
    All Wheel Figures | Estimated Crank Figures | Absolute Gain over Stock - APR Stage 2 - 91 Octane
    All Wheel Figures | Estimated Crank Figures | Absolute Gain over Stock - APR Stage 2 - 93 Octane
    All Wheel Figures | Estimated Crank Figures | Absolute Gain over Stock - APR Stage 2 - 100 Octane
    All Wheel Figures | Estimated Crank Figures | Absolute Gain over Stock - APR Stage 2 - E85 Octane
    APR Stage I & II ECU Upgrade - Calibration Report
    230 HP & 271 FT-LBS of TQ - Stock 93 AKI As Measured by APR
    270 HP & 329 FT-LBS of TQ - +43 HP @ 5950 RPM & +77 FT-LBS of TQ @ 2700 RPM - APR STG 1 91 AKI / 95 RON
    297 HP & 329 FT-LBS of TQ - +70 HP @ 6000 RPM & +77 FT-LBS of TQ @ 3000 RPM - APR STG 2 91 AKI / 95 RON
    284 HP & 338 FT-LBS of TQ - +57 HP @ 6000 RPM & +85 FT-LBS of TQ @ 2650 RPM - APR STG 1 93 AKI / 98 RON
    302 HP & 343 FT-LBS of TQ - +76 HP @ 6000 RPM & +89 FT-LBS of TQ @ 3100 RPM - APR STG 2 93 AKI / 98 RON
    303 HP & 360 FT-LBS of TQ - +77 HP @ 6000 RPM & +107 FT-LBS of TQ @ 2750 RPM - APR STG 1 100 AKI / 104 RON
    309 HP & 377 FT-LBS of TQ - +83 HP @ 6000 RPM & +125 FT-LBS of TQ @ 2800 RPM - APR STG 2 100 AKI / 104 RON
    313 HP & 388 FT-LBS of TQ - +85 HP @ 5950 RPM & +134 FT-LBS of TQ @ 3050 RPM - APR STG 1 E85
    318 HP & 405 FT-LBS of TQ - +92 HP @ 6000 RPM & +153 FT-LBS of TQ @ 2900 RPM - APR STG 2 E85
    - E85 only supported on flex fuel supported models. These models have a silver metal intake manifold.
    - Max rev limit TCU controlled on automatic transmissions.
    - APR recommends and tuned with Sunoco GT 260 for 100 AKI mode and Sunoco GT 260 Plus for 104 AKI mode. Never use lower octane than specified by the mode.
    - Max increases are based on APR's actual measured stock values and not those reported by VW. | RON = ROW Fuel Grades | AKI = North American (RON+MON)/2 Fuel Grades.
    - Reported wheel figures measured on APR's in house Dynapack Dynamometer with a 2014 A5 (217hp) AWD with 8 speed tiptronic transmission, using SAEJ1349 correction and an average of multiple runs. Crank figures estimated based on the measured wheel figures. Results will vary depending upon environmental conditions, vehicle, transmission, vehicle health, operating conditions, temperatures, fuel grade, dyno type, dyno setup, and other modifications.
    Acceleration Figures
    0 - 60 MPH
    6.140 - Stock 6MT A4
    5.474 - APR Stage 1 93 6MT A4
    4.396 - APR Stage 1 E85 8 Speed Tiptronic A5
    0-62 MPH
    6.471 - Stock 6MT A4
    5.737 - APR Stage 1 93 6MT A4
    4.646- APR Stage 1 E85 8 Speed Tiptronic A5
    0-100 KPH
    6.492 - Stock 6MT A4
    5.901 - APR Stage 1 93 6MT A4
    4.663- APR Stage 1 E85 8 Speed Tiptronic A5
    0-100 MPH
    15.335 - Stock 6MT A4
    12.872 - APR Stage 1 93 6MT A4
    10.950- APR Stage 1 E85 8 Speed Tiptronic A5
    60-120 MPH
    18.816 - Stock 6MT A4
    13.533 - APR Stage 1 93 6MT A4
    12.570- APR Stage 1 E85 8 Speed Tiptronic A5
    62-124 MPH
    21.816 - Stock 6MT A4
    14.946 - APR Stage 1 93 6MT A4
    14.045- APR Stage 1 E85 8 Speed Tiptronic A5
    100-200 KPH
    21.618 - Stock 6MT A4
    15.115 - APR Stage 1 93 6MT A4
    14.104- APR Stage 1 E85 8 Speed Tiptronic A5
    60-130 MPH
    29.273 - Stock 6MT A4
    18.293 - APR Stage 1 93 6MT A4
    17.482- APR Stage 1 E85 8 Speed Tiptronic A5
    30-130 MPH
    33.921 - Stock 6MT A4
    22.472 - APR Stage 1 93 6MT A4
    20.854- APR Stage 1 E85 8 Speed Tiptronic A5
    -Data collected at the same location via a Racelogic P-Box with ESP/ASR off, Dynamic mode and Sport mode. Stock and Stage 1 collected using a 2014 A4 6MT and Stage 2 collected with a 2014 A4 8 speed Tiptronic. May not be comparable to data collected in other locations.
    APR EMCS Programs and Features
    APR’s patented EMCS, Enhanced Modular Chipping System, brings selectable programs and features to your factory ECU, all without the need to purchase external hardware. Other companies have attempted to imitate EMCS with clumsy external switching devices that only replace or multiply portions of a “base” calibration. However, EMCS has the ability to completely rewrite the entire operating map data, giving each map a complete set of calibration changes. APR’s EMCS features and programs modes are activated via your OEM cruise control buttons. Your cruise control will continue to function as normal.
    Program Switching:
    Program switching allows the user to cycle through up to four different engine calibrations and operating modes all without the need for external hardware.
    Stock Mode:
    By selecting stock mode, the ECU calibration is reset to the factory calibration. The engine will run exactly as it did before purchasing APR software.
    APR Performance Modes:
    APR's octane-specific calibrations are available for various premium and race fuels around the world. Each performance mode is a completely new calibration, altered specifically for the characteristics of the fuel quality selected.
    Valet Mode:
    APR's Valet Mode protects your vehicle from becoming an expensive toy for unauthorized individuals. By enabling Valet Mode, the vehicle's performance is extremely limited. Launch control is uneventful, the vehicles top speed is limited and the engine's redline is reduced.
    Fault Code Erase:
    Fault code erase allows the user to erase and reset engine related trouble codes and ECU adaptation data without using a specialty tool.
    Security Lockout:
    Security lockout prevents unauthorized individuals from using APR's EMCS functionality. When enabled, APR's EMCS features will appear completely invisible until a user specified 2 to 4-digit security code is entered.
    Anti-Theft:
    When activated, Anti-Theft prevents the engine from starting even if the factory key is used. The vehicle will be completely immobilized until a user specified 2 to 4-digit security code is entered.
    APR Mobile
    APR Mobile is a simple yet powerful tool designed to enhance the APR tuning experience.
    APR Mobile installs on smart phones, tablets and other devices and provides a wireless connection to the vehicle’s engine control unit or ECU. Once connected, the device can be used to access APR’s EMCS program switching features, read and clear fault codes and data log the ECU at high data rates not found on other commercially available tools. The app can also be used to access APR’s latest news articles, locate dealers in APR’s network and review previously saved data logging sessions.
    To learn more about APR Mobile, please visit our product page.
    Application Guide
    Audi A4 (B8.5)
    Audi A5 (B8.5)
    Audi Allroad (B8.5)
    Audi Q5
    Audi A6 (C7)
    Seat Exeo
    2.0 TFSI with Audi Valve lift. Supports both Flex Fuel (silver metal intake manifold engine) and non flex fuel engines.
    Prices:
    $599.00 - Single program (E85 program included on flex fuel variant vehicles at no additional charge)
    +$149.00 - Total of 2 programs
    +$219.00 - Total of 3 programs
    +$289.00 - Total of 4 programs
    +$59.00 - Security Lockout
    +$59.00 - Fault Code Erase
    +$199.00 - Security Lockout
    - Pricing applicable to the USA only. If outside of the USA, please contact an APR Dealer and Importer for pricing.
    - Please note, VAG issues many ECU part numbers and revisions throughout their vehicle lineup. As such, some ECU part numbers may be temporarily unavailable when new parts or revisions are released. If the vehicle’s ECU box code and revision is known, availability can be checked by calling APR, or visiting an APR dealer. Typical turnaround time for new ECU box code and revision is quick. Please contact APR for details.
    How to Purchase
    Locate an APR Dealer
    Use the APR Dealer Locater Tool to find an APR Dealer near you. The APR Dealer should have the ability to upgrade your ECU while you wait.
    Security, Warranty and Money Back Guarantee
    All APR ECU Upgrades are fully encrypted to prevent theft of our valuable and proprietary coding information by lesser companies.
    30 Day Money Back Guarantee:
    All APR ECU Upgrades include a 30-day money back guarantee with no questions asked. If for any reason the owners is dissatisfied with the APR ECU Upgrade, they may return to the place of purchase for a full refund, provided they are within the 30 day period from the time of the initial purchase. Labor or shipping charges are not included in the guarantee and are at the discretion of the place of install.
    Limited Lifetime Warranty:
    All APR ECU Upgrades include a limited lifetime warranty against defects in the software, and to provide free updates and reflashes as they become available. Labor or shipping charges are not included in the warranty and are at the discretion of the place of install.
    GoAPR.com | Facebook | YouTube | Twitter | Instagram
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    Oct 05 2014
    Houston, TX
    Do they make models of the Q5 Hybrid with support E85?
    Aug 23 2008
    Auburn, AL
    I honestly don't know. We haven't tuned the Hybrid models yet.
    Veteran Member Four Rings osideaudi's Avatar
    Jan 30 2012
    Maine
    Quote Originally Posted by DarianBx3 View Post
    a tuned hybrid...?
    Vic
    Future:
    '17 Audi S3 - Nano Grey
    Current:
    '16 BMW F83 M4 - Alpine White
    Previous:
    '16 Audi SQ5
    '11 Audi B8 S4
    '08 Audi TT
    Oct 05 2014
    Houston, TX
    Tuned engine + electric motor? Seems like a great deal to me.
    I want the 2.0 model of the Q5, and the hybrid has everything the TFSI only has, except more.
    Arin, you say yet. Does that mean there are plans? Simply curious.
    Aug 23 2008
    Auburn, AL
    Hopefully we can. We'll need a car though for development. I don't see us buying one any time soon.
    Oct 05 2014
    Houston, TX
    Alright, I'll just get the 2.0 TFSI then. Is there a E85 file for k04 in the works?
    Aug 23 2008
    Auburn, AL
    Not yet, but hopefully in the future.
    Active Member One Ring OSCORP's Avatar
    Sep 30 2014
    Audi Q5 2.0T
    Cartagena
    Hello Arin!
    I just got my 2015 Q5 2.0T and i am very interested in the APR mods, how do i know my engine its compatible with any of the options APR has? Sorry i am new to all this upgrades and tune ups.
    Thanks
    2015 Audi Q5 2.0T HRE FF01 20x9ET25 265/45r20
    Veteran Member Four Rings spijun's Avatar
    Oct 10 2010
    Audi Q5 2.0TFSI S tronic
    Sarajevo, BiH
    Quote Originally Posted by osideaudi View Post
    a tuned hybrid...?
    +1
    Aug 23 2008
    Auburn, AL
    Quote Originally Posted by OSCORP View Post
    Hello Arin!
    Thanks
    The 2015's are compatible.
    If you lift your engine cover and notice the intake manifold is silver, and made of metal, your car supports E85. If it's plastic, it doesn't.
    We may need to get your ECU here, in house first, if we don't have it on the server already since it's so new. When the APR dealer plugs in, they can see if that's the case or not.
    Sep 30 2014
    Audi Q5 2.0T
    Cartagena
    Hello Arin, and thanks for the response
    Ill take a shot without the cover and send it to you cos im not sure what to look for (embarrassed). Can you please give me your email and phone number and extension I can reach you?
    Thanks
    Aug 23 2008
    Auburn, AL
    Lift the engine cover (big plastic thing in the center of this photo):
    If the intake manifold is silver like this, you have a Flex Fuel model:
    If the intake manifold is black plastic like this, your model doesn't support flex fuel:
    Sep 30 2014
    Audi Q5 2.0T
    Cartagena
    Hi Arin! thanks for the pictures. Yeah mine looks like plastic, what would be the options I have left?
    (haven't been able to attach a picture)
    So my engine its Gen 3, ill wait till there's new software for it!
    thanks
    Oct 05 2014
    Houston, TX
    I believe you can still get the tune, you just won't be able to use the E85 file.
    Aug 23 2008
    Auburn, AL
    He actually has the new EA888 Gen 3 motor. It's not available in the USA yet. It's like the new MK7 GTI motor.
    Sep 20 2014
    North New Jersey
    Chiming in is it still possible to get the tune with plastic manifold and just run the 93 pump gas Arin ?? Thanks
    Oct 05 2014
    Houston, TX
    Yeah, on the APR product page it says with or without E85 support.
    Tell us how it goes if you get it!
    Aug 23 2008
    Auburn, AL
    Quote Originally Posted by Jlambe67 View Post
    Yes, that is correct!
    We have the following software available:
    Plastic Manifold:
    91 Octane Tune
    93 Octane Tune
    100 Octane Tune
    Metal Manifold:
    91 Octane Tune with Automatic Ethanol Blending
    93 Octane Tune with Automatic Ethanol Blending
    100 Octane Tune with Automatic Ethanol Blending
    Sep 20 2014
    North New Jersey
    Awesome thank you need a couple thousand more miles and it will be done
    Junior Member Two Rings
    May 25 2014
    Boston, MA
    This looks like a very interesting product - not having to split the ECU apart and all! However, am I correct to assume that with this software installed the car will throw a TD1 error code when tested at the dealer potentially voiding the warranty?
    Nov 17 2014
    '14 BMW 328i
    Socal
    Do you benefit or gain an increase in hp and torque With stage 1 even if you just use the reqular 91octane premium gasoline or you need to load it with higher octane or e85 to appreciate? I dont intend to race but i would like to improve my q5 performance for daily driving.
    Nov 17 2014
    '14 BMW 328i
    Socal
    Oooops...pardon my ignorance. I overlooked the available 91 octane tune
