Results 1 to 30 of 30
    Oct 02 2014
    Chicago
    Slow acceleration from a stop.
    My 06 A4 2.0T quarto has been very slow when accelerating from a stop. Like it hesitates for a few seconds then takes off. I have a code but its a coolant P2181 code. Any ideas? Could it be transmission related?
    Thanks
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    Quote Originally Posted by Sublime69 View Post
    My 06 A4 2.0T quarto has been very slow when accelerating from a stop... Any ideas?
    It's a 2.0T A4
    Seriously though I would just chaulk it up to lag unless you've noticed a sudden change. Are you on a stock tune?
    Deactivated Four Rings
    Aug 30 2013
    2014 Toyota Highlander Limited, 1999 Mercury Grand Marquis GS-HPP
    Panama City Beach, FL
    How long have you had the car? When's the last time you changed spark plugs, air filter, checked MAF, etc? Do you have a Quattro or FWD (I only ask because if you have FWD then you have a CVT, and that transmission is slow from a dead stop)?
    Oct 02 2014
    Chicago
    I just got the car. Its a quattro and has about 117K on it. Its bone stock and i just did a tune up on it. Now plugs and coils. It seems to bog out for a second, like i let off the gas. Its weird. I heard these cars have carbon build up problems. What can i do about that? Seafoam?
    Aug 30 2013
    Did you go OEM for coils and plugs? Was it sluggish before you replaced them? Have you scanned for codes with VAGCOM (not the generic OBDII scanner)? Changed the air filter yet, or looked to see if it's really dirty?
    Veteran Member Four Rings A-BlacK_MambA-4's Avatar
    Jan 22 2011
    '05.5 A4 2.0T Tip Revo Stage 2; Wifes 2013 Chevy Cruze
    Ohio
    Quattro Tip or 6mt? If Tip it's normal. Try flipping over to sport mode and shifting yourself to see if that remedies your problem. I hate when mine does it.
    -JOEL
    The Real Black Mamba
    Veteran Member Four Rings dalmation53's Avatar
    Aug 19 2013
    Miami
    Treat cvt like manual. Like rev it until 1k rpms and then accelerate. Cvts go into neutral when brake applied. That causes a hesitation. Normal for cvt. Rev an go! Problem solved.
    Ivan
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Guys, as stated in his original post he's Quattro.
    OP, was it dealer or private purchase? Has it been like this since you bought it? I'd ask for service records at least you'll what it needs. Also, take care of that coolant code. Believe it or not it can hinder the performance of your car. Start from there. You mentioned tune-up but what else did they do? Things I would check/replace (in order) if not done during tune-up:
    -Diverter Valve (updated piston style)
    -N80 Purge Valve
    -Air Filter
    -Spark Plugs
    -Fuel Filter
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Oct 02 2014
    Chicago
    Ok thanks guys! Its an automatic trans. I bought the car for suuuuuper cheap from a neighbor because the guy though it needed a motor. He said he took it to a show and they told him it needed a new cam. When i got it it ran like crap. Misfired like crazy. So i put new plugs in (ac delco) i went with cheaper plugs at the time because i wasn't sure what i was going to do with the car. It helped a bit but still still misfired. So i found out there was a cylinder 3 misfire so i replaced that one coil and it ran great. Just sluggish off the line. I also just changed the cam fowler and it was worn but not broke or missing any pieces. That's when i decided to keep the car. Just trying to see if there's anything else I can do. I know it needs a new air filter. When i tool it apart it looked like a birds nest in the upper plastic intake pipe(where the screen is).
    Whats with this diverter valve? Is it essentially a blow-of valve? also, is the fuel filter easy to change? Where is it located?
    Thanks again guys!
    Aug 30 2013
    Search, search, search. Tech procedures are in the Tech section.
    Oct 09 2007
    Miele S7
    Thanks again guys!
    Get rid of those AC Delco and replace with OEM plugs from Audi (no need to gap), your car will love you...and get all the things I mentioned replaced. Yes, DV is aka Blow-Off Valve. The N80 is super super easy to replace sitting right on top.
    Oct 02 2014
    Chicago
    Ok ill get the plugs. I thought the DV was under the car?? Guess i was looking at a different year a4.
    Oct 02 2014
    Chicago
    Also, what about the coils? I replaced the one with a $23 one from advanced auto. Should i replae the others and does the brand make a big difference?
    Aug 30 2013
    OEM coil packs only. The aftermarket ones are complete shit. The DV is under the car. Check out the tech board or search via google for diverter valve on a B7.
    Oct 02 2014
    Chicago
    Ok. Now what about the DV? Can that be aftermarket?
    Aug 30 2013
    Only if you get a DV+, otherwise stick with OEM. There are quite a few threads regarding DVs - check them out.
    Aug 19 2013
    Miami
    Quote Originally Posted by 80sGuy View Post
    -N80 Purge Valve
    -Air Filter
    -Spark Plugs
    -Fuel Filter
    He said he was quarto not "quattro"
    Ivan
    Veteran Member Four Rings Biged243's Avatar
    Mar 27 2013
    Vr6 gti
    Metro Detroit Michigan
    Make sure the gap is right. Even if it is pre gapped you need to check. You can buy oem or r8 coil packs just as cheap as what you paid from multiple vendors from the forum. Go with the gfb diverter valve. Also get a tune.
    What ever makes sense go with the opposite and you got it
    Mar 27 2013
    Vr6 gti
    Carbon build up you have to scrap off, or media blast. Seafoam doesn't do much of anything because we have direct injection. Check your PVC valve.
    Veteran Member Three Rings Aim high's Avatar
    Jun 12 2014
    Va
    I'm sorry but I'm stage 2 apr with a tip Quattro and in first gear with the pedal floored from a stop its like the car yawns... Then hold on to your nutsack. It's turbo lag at its finest. Does the same thing happen when your in second gear with a slight amount of throttle applied then full throttle? I doubt it. All turbos no matter how small will have a lag time and that's why you experience the immediate lag off initial throttle. It sucks.. But once the turbo spools it's so sweet. Fuck linear power!! Haha
    2015 S4 dsg ibis white, tech package, sport diff, b&o, 19" stockers, chipwerke S set to c1
    Jun 12 2014
    Va
    P.s. If it's a coolant code you're throwing get it checked out IMMEDIATELY
    Mar 27 2013
    Vr6 gti
    Quote Originally Posted by Aim high View Post
    Lol just brake torque it off take off. Problem helped, not solved.
    Jun 12 2014
    Va
    ^^^ yea this helps everything but your drivetrain haha.. But biged243 is right. It's a problem of building boost before you let go of the brake. If you do it right then you'll take off pretty damn quick but this process is also very stressful to the drivetrain
    Oct 02 2014
    Chicago
    Ok so I called audi and there are some recalls on my car. A PCV recall and some intake manifold flap thing. Can this be the cause? Also, where is the coolant temp sensor located? I am going to replace it and see if that is what is causing the coolant code.
    Oct 02 2014
    Chicago
    Quote Originally Posted by Biged243 View Post
    How do you scrap off the carbon build up?
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    Coolant temp sensor is in the back of the engine in the left side. You can reach it from the top. There's a DIY on here for that too. Super easy to replace.
    Since you'll be losing some Coolant be SURE you only put the g13 from audi in. Is the Coolant you have in there now redish?
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Oct 02 2014
    Chicago
    Quote Originally Posted by JDillon15 View Post
    Yes it is redish.
    Aug 30 2013
    You will lose a lot of coolant, so have something handy under the coolant sensor to catch/divert the coolant to a bucket.
    Veteran Member Three Rings audihere06's Avatar
    Nov 11 2013
    Charlotte NC
    If the temp sensor doesn't fix the code its probably the thermostat. If your looking to fight the pcv issue as well as carbon buildup, I highly recommend the 034 motorsports PCV delete/catch can. You will get used to the way the car drives. Drive it in manual mode i think you will like how it drives compared to D.
    Mar 27 2013
    Vr6 gti
    Not hard to search for but here it is
    http://www.audizine.com/forum/showth...e-walkthrough*
