Results 1 to 20 of 20
    Apr 02 2013
    Toronto, Ontario, Canada
    Anybody try brake pads from TEXTAR ????
    looking to change my brake pads for the winter andsaw ECS had all four for 122 with sensor. has anyone tried them out.
    Established Member Two Rings evergreek's Avatar
    Dec 05 2012
    Miami, FL
    Textar are OEM, I have used them. It's just like the stock ones.
    Apr 02 2013
    so still alot of brake dust? just like stock
    Veteran Member Four Rings Docwyte's Avatar
    Feb 02 2005
    '03 911 Turbo, '15 Cayenne Diesel
    I just put in the Textars. Realize that any "dustless" pad is going to have crappy intial brake torque. I've used Textars in the past and found that while they do dust, they dust less than the OEM pads. The dust isn't corrosive and easily wipes off with a wet rag/sponge while washing the car.
    Totally worth it to have a set of brake pads that feel like they'll actually stop the car. Oh yeah, they're also quiet.
    '15 Porsche Cayenne Diesel ** Wifes DD
    '03 Porsche 911 Turbo 6 MT **
    '18 Land Cruiser ** My DD
    '17 KTM 690 "Adv"
    Senior Member Three Rings Sukks2bu's Avatar
    Mar 12 2013
    Milton Ontario
    How does the textars match up with esc geomet drilled and sloted rotors?
    2010 AUDI S4 DSG DRIVE SELECT UNITRONIC STAGE 2+
    Aug 15 2014
    textar makes excellent pads. they are one of porsche oem suppliers. I ran them on my m3 and was very impressed with the amount of bite in them. I'd buy them again
    Registered User Four Rings Sales@DriveAuto's Avatar
    Apr 13 2012
    Clifton/Mountainside, NJ
    They're an OE supplier without the OE price tag. Nothing to worry about - they're solid.
    Veteran Member Four Rings shadycrew31's Avatar
    May 27 2013
    West Chester, PA
    Same dust levels as stock...
    Mar 12 2013
    Milton Ontario
    Do they fit like stock? Reason I ask is, I've had cross drilled slotted rotors before, and if the pads are not an exact fit, they make a clicking noise when just driving around. Drove me so nuts, I sold the car and bought an audi.
    Happy ending
    Feb 02 2005
    That shouldn't ever happen unless your caliper pad retaining clips were bad.
    No issues with pad fitment here.
    '17 KTM 690 "Adv"
    May 27 2013
    West Chester, PA
    Quote Originally Posted by Docwyte View Post
    Mine make a squeaking noise when I turn the wheel. I most likely reversed the retaining clip, sadly I am too lazy to fix it.
    Veteran Member Four Rings audistealth's Avatar
    Mar 04 2012
    2012 Audi S4, 2017 Explorer Sport
    It looks like TRW is the OE supplier, not Textar. Unless this is an incorrect image on the ecstuning website.
    Source:
    http://www.ecstuning.com/Audi-B8_S4-...ads/ES2763650/
    Picture 2:
    /// 2012 S4
    RocEuro Intake | AWE/GIAC Stage 2 | 19" Titanium Rotor Wheels 10mm H&R spacers | RS5 BBK & ECS 2pc front/rear wave rotors | Renn RS-51 19x8.5 20.5lbs | JHM LW/HD Pulley | MMI 3G+ rev. G and controls retrofit | vagcom stuff | Jokerz ported coated supercharger | KW V1
    Mid-Atlantic Forum (MD/DC/VA)
    Established Member Two Rings budda's Avatar
    Mar 10 2010
    2000 S4 6M GT25 SOLD, 1990 Accord H22 GT35R w/JRZ RS Pro's, 2013 S4 GONE, 2016 S6
    I installed Textar pads with Zimmermann cross drilled rotors today.. quite and same pedal feel as stock
    Mar 12 2013
    Milton Ontario
    Quote Originally Posted by budda View Post
    Where did you get them from and how much if you don't mind me asking? Did you do the install yourself.
    Mar 12 2013
    Milton Ontario
    Why don't people recommend genuine audi parts.com
    Are they god to deal with.
    Seems like they have cheaper prices than the dealership for Oem parts.
    Feb 02 2005
    OEM pads from genuine audi parts were a little over $100 for the set. I got ECS slotted rotors and textar pads from my local shop for around $300 combined. Spent around 1.5 hours installing them myself in my garage.
    '17 KTM 690 "Adv"
    Mar 10 2010
    Quote Originally Posted by Sukks2bu View Post
    I got them through Worldpac, $131ea rotor and $60 for the pads....wholesale prices
    May 11 2011
    I got textar pads with Zimmerman disks and they feel like oem.
    Veteran Member Four Rings integroid's Avatar
    Mar 01 2013
    Atlanta, GA
    How is the dust ?
    2024 RS3 Kemora Gray
    Mar 10 2010
    Quote Originally Posted by integroid View Post
    How is the dust ?
    Same as stock pads
