Results 1 to 21 of 21
Thread: key slot
    Nov 24 2012
    13 S4 / 10 Acura TL
    Atlanta, GA
    key slot
    Does inserting key in the key slot charge the remote battery , I have advanced key and today got replace key battery message and want to know if I insert the key in that slot will it charge the battery
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    No it does not charge the battery. There is a battery button you press to open the key, you can access it by removing the emergency key from your main key.
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Veteran Member Four Rings Leor604's Avatar
    May 25 2010
    Vancouver
    Yeah, replace the battery (CR 2032) but don't worry if it dies in the meantime. Even if the battery is totally dead you can use the physical key in the drivers door and insert the fob into the dash slot to start the car. The battery is only for the remote/keyless functions.
    Feb 08 2013
    2017 Corvette Z06; 2007 Ford F-150; 2004 Honda RC51
    Sammamish, WA
    Not to hijack the thread, but if the key dies does it retain its programming or does it have to be reprogrammed? Sorry OP.
    2013 Premium +, Monsoon Gray, S tronic, sport diff, B&O, 19" RS4 reps, black on black interior, carbon inlays
    Mods planned: seeing doctor tomorrow about a lead foot prosthetic
    May 22 2008
    2013 Audi S4 IceSilver MMI/SD/DSG/AK
    Bay Area
    It maintains its programming. I have replaced 3 in the last 3 weeks, you can get a 5 pack of batteries on amazon for like 4 bucks shipped. Takes like 10 seconds to swap just take the key out and then use the same method to remove the inner plastic part. It has a rubber seal so it takes a bit more of a pull just make sure you are pushing the black button.
    Ice Silver S4 Black Int. Sport Diff DSG, B&O, Nav, Advanced Key
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Quote Originally Posted by mcoomer View Post
    well side note. Sometimes if you have 2 keys and only use one and not use the other for like 8 months or so. I have seen them loose programming or being pushed out since the system doesn't see it being used. Don't know if it will happen on audi's I was told this when I bought the car just use the 2nd key from time to time. Ive seen this happen on Mitsu's with the advanced keyless loose programming from someone not using the key for 6 months or more.
    Active Member Four Rings SwankPeRFection's Avatar
    Aug 05 2013
    N/A
    Quote Originally Posted by chaos2984 View Post
    No such thing. What could happen is if you take your car in for service and they do a reset of the internal modules to default for some stupid reason. That resets the key pairing and when you get home, the other key doesn't work. If they don't ever do that, no problems. Basically, the shit that resets your VAGCOM settings could also cause your spare keys not to work depending on what the idiot mechanic did.
    Oct 20 2008
    Denver
    Quote Originally Posted by boss2k View Post
    seriously?
    Nov 24 2012
    13 S4 / 10 Acura TL
    Atlanta, GA
    Thanks everyone for their replies
    2016 M3 MT/AW/Black
    Sold --2013 S4 MT/Glacier white/ Black interior/Premium Plus/ MMI/ Sports diff/ B&O/advanced key/ 19inch wheels/Carbon inlays/ supercharged badges/Euro Code Meisterwerk Shifter/ AWE exhaust with stock downpipes
    2010 Acura TL / Paladium silver/ black interior
    Nov 24 2012
    13 S4 / 10 Acura TL
    Atlanta, GA
    Quote Originally Posted by AudiTFSI3o3 View Post
    seriously?
    seriously what ??
    2016 M3 MT/AW/Black
    Established Member Two Rings S4am's Avatar
    Mar 12 2008
    pasadena, ca
    i was told by the dealership to bring in the key fob, and they would replace the battery for free.
    Dec 16 2008
    Delmarva
    My car claims there are 3 keys programmed for the car. I have two. How do I remove the ghost third?
    Jan 07 2014
    Chicago area, IL
    seriously what ??
    I think it would be cool tech to recharge in the key slot. But can they make a battery that small that is rechargeable?
    May 25 2010
    Vancouver
    My BMW (2001) key recharged while in the slot, but that was a physical key with buttons on it which you had to put in the slot to start the car. I use to swap keys occasionally to keep them both charged up.
    Not sure if the keyless entry BMW fobs work this way.
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Quote Originally Posted by chichum View Post
    Do they count the valet key in glove box?
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Sep 05 2012
    Quote Originally Posted by sacandagaD View Post
    Yes it includes the plastic spare "emergency" key (it's not really a valet key.)
    2013 S4 Premium Package (Canada; like US Prestige) / Phantom Black Pearl ext / Nappa Black&Magma int / B&O, Nav, S-tronic DSG, Sport Diff, Michelin Pilot Sport 4 S wrapped around scuffed up 19" potato peelers / 3M See-through brassiere // GIAC/AWE Stage 2 + TCU tune - CTSTurbo Intake // Winter mode: 18" Nokian Hakkapaleno? R2 on RTX Ingolstadt gunmetal wheels (B7 RS4 knockoffs)
    Jul 02 2013
    Quote Originally Posted by moose_head View Post
    Lol sorry, valet would never touch my car while I am alive.
    Nov 24 2012
    13 S4 / 10 Acura TL
    Atlanta, GA
    Quote Originally Posted by Notfast View Post
    My BMW key would get charged and it did not have comfort access, i had to plug the key in that slot and hit start/stop button.
    2016 M3 MT/AW/Black
    Senior Member Three Rings 11move's Avatar
    Nov 25 2007
    The third is your Valet key
    Sep 05 2012
    If you give the valet the plastic key, you've just given him access to the trunk and glove box. For valet mode, you take the metal key out of the clip thing, push the valet mode button inside the glovebox, manually lock the glove box and rear seats and then give the guy the clip thing only. Yes it can start the car like that.
    Jun 18 2013
    United States
    As others mentioned, it doesn't charge the key. With that said, I did learn if you leave your key in the car while parked in a garage it does drain the battery faster. The car "sees" in the key inside the car.
