Anything "better" will cause more vibration because it's not liquid filled... the 034 is your best bet if you don't want to remain stock. As far as the snub mount is concerned it fits in the stock location without any extra hardware.
034Motorsport Motor Mount Set (Street Density, Set of 2)
FREE SHIPPING (Continental USA)
We're proud to announce the availability of the 034Motorsport's Street Density motor mounts for B5, B6, B7, and C5 chassis Audi and B5 Chassis Volkswagen models! They are designed with performance in mind, and manufactured from high-durometer rubber for increased performance and durability, without sacrificing comfort.
These Street Density motor mounts are manufactured from 50 durometer rubber, which is approximately 10% stiffer than stock. Since the mounts are also void-free and solid-filled, the resulting mount is approximately 25% stiffer than stock, eliminating the slop associated with the factory mounts. The mount bases are made from steel, and are much stronger than the factory aluminum ones, to cope with the added stress of spirited driving.
The result is greatly reduced drivetrain slop, crisper shifting, and minimal wheel hop, without any significant increase in noise, vibration, or harshness (NVH) inside of the cabin. These mounts are a completely re-engineered performance solution, not just inserts for use with the factory mounts.
Features
- Manufactured from 50 durometer (Street Density) rubber with void-free construction
- Reduced drivetrain slop
- Decreased engine movement under load
- More direct power transfer
- Improved shifting feel
- Complete drop-in replacement of factory engine mounts
- Comes with protective sleeves
- Sold in pairs (one vehicle requires 2 mounts)
034Motorsport Engine Snub Mount (B6/B7/C5/C6)
This performance polyurethane snub mount fits most late-model Audi vehicles manufactured after 2002, and is designed to increase stabilization of the motor under acceleration. 1mm undersized for vibration free performance when no load is on the engine.
FITS THE FOLLOWING MODELS:
- 2002 - 2008 Audi A4 & S4 B6/B7
- 2000 - 2011 Audi A6 & S6 C5/C6
- 2001 - 2005 Audi allroad C5
