Hi folks.
I’ve bought my second A8 a few weeks back, a 2006 3.0 TDI with sport suspension. Unfortunately it seems like it got the smallest brakes witch have been delivered on the D3. According to my research the front brake rotors fitted on the D3 are either 321mm, 323mm, 360mm and 385mm, while the rear rotors are 280mm, 310mm and 335mm. Without measuring closely on the rotors, it looks like from outside the rim that I’ve got 321mm in the front and 280mm in the back. Using 19 inch wheels for summer and 18 inch for winter, it obviously gives room for bigger rotors.
After studying the parts needed to upsize the brakes, it raises some questions.
1. How big rotors with accompanying caliper fit under 18 inch rims?
2. The calipers in the front have different part numbers according to rotor size, while in the back it doesn’t. Is it really necessary to have "the right" caliper according to the rotor size in the front?
Help and experience are much appreciated!
