Results 1 to 40 of 40
    Veteran Member Three Rings LawDawg's Avatar
    Feb 20 2008
    Naperville, IL
    Start button wear - is it wise to put some clear on a replacement?
    I'm going to replace my worn out start button. I was wondering if there is any wisdom to putting a couple coats of matte clear lacquer/acrylic/etc. on the button surface before I install it to make the replacement more durable? Or is this a completely stupid idea?
    Those with more knowledge of paints that I, please discuss.
    Current:
    '13 S6 Prestige [Oolong Grey Metallic, B&O, Innovation (HUD, Night, ACC, Active Lane/Side Assist., Top-view), Cold Weather, LEDs, 20"]
    Former:
    '11 S4 Prestige
    '05 A4 1.8T USP 6MT
    '01 A4 1.8T QMS
    '95 Dinan M3
    Jul 21 2014
    United States
    Your coating won't be better than Audi's.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Clear bra it! Or clear plastidip
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    i had problems with my silver one, got a red one, it seems to be holding up fine.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    May 06 2014
    Las Vegas, NV
    Quote Originally Posted by Dr GP View Post
    Great idea, although I wonder if there's a pre-cut clear adhesive sticker that can be used like a screen protector for a phone... any ideas?
    Veteran Member Four Rings Leor604's Avatar
    May 25 2010
    Vancouver
    Not really understanding how people are wearing out the start button.
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    Quote Originally Posted by Leor604 View Post
    fat fingers or they have sandpaper hands
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Senior Member Two Rings SpfldS4's Avatar
    Mar 04 2004
    2005.5 Audi S4
    Wilbraham, MA
    I thought I saw a post earlier this week of someone putting a phone protective film on their new red button.
    2010 Audi S4 S-tronic Prestige Sepang Blue | Sport Diff w/ ADS | GMG Sway Bar Kit | KW H.A.S Coilover | APR Stage 2+ w/ coolant system | 19" OEM RS4 Wheels | RS5 BBK | NAV | Black Nappa | Piano Black Trim | Black Optic | B&O | Advanced Key | 35% Tint | 3M Clear Bra | Audi exclusive
    Senior Member Two Rings HKIC's Avatar
    Nov 17 2008
    RI
    walmart sells the clear protective films for the phones. You can buy the products that you have to cut to size yourself and just cut the circle. I personally wouldn't use any type of clear paint on it.
    Aug 25 2008
    Boston, MA
    there was a dude who recently posted that he had the guys at malls who apply screen protectors to apply one to the start button.
    mine is also worn out and will be replacing mine with a red one. the newer red ones are designed better so the outer metal doesn't peel as easily especially on the letter 'N'
    OLD STYLE:
    NEW STYLE:
    you will notice that in the newer design the letters are segmented to ensure that the metal is one continuous piece, hence reducing the likelihood of peeling...
    Feb 20 2008
    Naperville, IL
    I love helpful posts like this.
    Active Member Four Rings SwankPeRFection's Avatar
    Aug 05 2013
    N/A
    No, but the new red ring version and you won't have a problem again. The original style kind are a POS.
    Veteran Member Four Rings promoda's Avatar
    May 26 2010
    2015%20Audi%20Q5%2C
    Montreal
    Is this an easy do yourself instal?
    Aug 12 2014
    Bexley, OH
    Has anyone had this replaced under warranty? My 13 is showing wear. I wonder if they'd replace it with the newer red ringed button under warranty.
    May 25 2010
    Vancouver
    Quote Originally Posted by LawDawg View Post
    Just wanting to understand what may be causing the problem, so myself and others may be able to avoid it. Some may find the knowledge to be helpful.
    Senior Member Two Rings shizzrock's Avatar
    Dec 12 2013
    Boston, MA
    Quote Originally Posted by Fife View Post
    Mine was wearing at 9k miles, they replaced it under warranty with the red ring. Lawdawg, if you're still under warranty try to get it replaced, the new one won't have that problem.
    2013 S4 Prestige w/Sports Diff, GIAC Stage 2 ECU, GIAC DSG, Alu Kreuz, Roc Euro Intake, Neuspeed RSE 52, Michelin PSS
    Veteran Member Three Rings BMWBig6's Avatar
    May 20 2008
    Georgia
    The problem's I've seen are not "premature wear" (of surface material wearing thin) but that the tiny acute triangles in the "A" and "N" are very sharp and can snag on things like micro-fiber towels. DO NOT EVER USE A MICRO FIBER TOWEL around the Start/Stop button. The fiber will snag and peel up the corners around the letters.
    2020 F-Pace SVR / 2016 GLE350 4MATIC
    Favorite Former Rides: 2015 Boxster GTS / 19 E450 Wagon / 2015 X1 M Sport / 11 F-150 Limited / 09 A4 Avant / 08 TT / 03 SVT Lightning / 01 SVT Lightning / 93 740iL / 90 535i / 86 944 Turbo / 83 944
    Dec 01 2010
    canada
    How difficult is it to replace and were do purchase one
    Established Member Two Rings JKrups06's Avatar
    Jul 01 2014
    Chicago IL
    I saw somewhere can't remember where but 60 bucks to get a red one I wish there was a diy for doing it. I need to replace mine
    May 25 2010
    Vancouver
    Quote Originally Posted by BMWBig6 View Post
    Thank you. That makes sense and is most helpful. Certainly understandable how the button could be damaged, but not clear how it could be "worn out".
    Senior Member Three Rings BrianV's Avatar
    Aug 09 2012
    2013 S6 Prestige - LED, 20s, Drivers Assistance
    Austin, TX
    My N was causing a problem, so much that it developed a point that when I'd press it, it could draw blood from my index finger. It got so bad I ended up just snipping the edge off so now my N is a bit strange looking, but at least it's flat and smooth.
    How hard are these to swap out?
    2013 Audi S6 (Ibis White) - Prestige, Driver Assistance Package, Full LED Headlights, 20" Wheels
    2016 Acura MDX (Graphite Luster) - SH-AWD, Advance
    Apr 11 2012
    A short how-to I wrote up
    Quote Originally Posted by will13k7 View Post
    Its an OEM Part from BKS Tuning, plug and play. Easy to install, the AC controls popped out using my finger in one the larger holes on the bottom, pulling outward. The shift boot just needs a simple pry tool, and the MMI controls pop out by pulling up swiftly from the area exposed by pulling up the shift boot, pulling up from the part closest to the armrest. Using a narrow pry tool, you push up on the wire clip's latch to pull out the connector, then push the button up firmly to pop it out. Push the new button in, re-install the connector, push the MMI controls back in, the AC controls, and finally the shift boot.
    Day Time Shots:
    Jun 05 2007
    Nashville, TN
    I just brought my 2013 in for the 15k service and asked them to replace it. They covered it under warranty, no questions asked, and they replaced it with the new red button.
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Quote Originally Posted by dzasta View Post
    I just ordered and installed the new style start button from BKS tuning. With the exchange rate it came to 69 shipped I believe and It got here from Germany in less than two weeks. Looks great, thanks all!
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Senior Member Three Rings 11move's Avatar
    Nov 25 2007
    Quote Originally Posted by fitzydude View Post
    How hard was it to replace? Anyone have a write up mine is peeling
    Jan 19 2016
    1997 BMW M3 w/ CES Stage IV Turbo, 1999 BMW M3 vert
    Orlando, FL
    The "N" in mine peeled after cleaning the interior with a micro fiber towel....it is a 2013 A4, so still a year under warranty....hopefully the dealer replaces it!
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    Quote Originally Posted by BMWManiac View Post
    Mine Is at dealer now, My N drew blood as well, I now have a red one as well, the red supercedes the old style so any replacement is automatically red.
    May 09 2012
    2013 s4, 2008 cbr1000rr
    United States
    Quote Originally Posted by B18b1ex View Post
    [IMG]via Imgflip Meme Maker[/IMG]
    Jul 02 2004
    FL
    Quote Originally Posted by DBL R View Post
    LOL, Got a new one. :)
    Veteran Member Three Rings VenturiRS's Avatar
    Dec 27 2008
    Quote Originally Posted by rtmeikle View Post
    Did you have wear? I just want a new one because it looks better (no wear).
    B8.5 Estoril Blue S4 | P+ | DSG | SD | ADS | B&O | CF | Nappa | Advance Key | CF Badges
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    Lotions and such will eat the finish.
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Sep 10 2012
    DFW
    Try and find a retractable badge clip that has an adhesive decal on it and use it. Stop by office supply and look for the one that says EASY
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Jan 22 2013
    '10 S4, '02 Subaru RSTI - EJ207 Swap, '75 BMW 530i Chump Car
    Same thing happened to me with my silver start button. Went to the dealership and asked about getting it replaced. They'll only do it up to the 1 year/20k mark.. interior trim warranty.
    They wanted $265 to replace it. No thanks. I'll order the $70USD part and do it myself in 20 mins.
    2010 Audi S4 || Meteor Grey Pearl || 6MT || Sport Diff || Nav || B&O Sound System || Advanced Key
    VMR 721 19x9.5 w/ Michelin PSS 265/35/19 || 034 Transmission and Rear Diff Mounts || CR-15 Brace
    The ex: 2002 Subaru RSTI || Midnight Black Pearl || JDM STI Swap - EJ207 || 6MT || ST Coilovers || Blouch Dom 1.5XTR Turbo, etc. || Airboy Tuned
    The racekar: 1975 BMW 530i || Classic BMW Paint Scheme || Caged || 5MT Swap || Body Roll
    Veteran Member Four Rings PitchS4's Avatar
    May 14 2007
    2021 SQ5 | 2019 Jeep GC Limited
    Northern VA
    cell phone screen cover
    Current:
    2021 SQ5
    Previous:
    2017 S3
    B8.5 SQ5
    B8 S4
    B6 S4
    B5 S4
    Senior Member Two Rings bgm130's Avatar
    Aug 19 2011
    Mahwah, NJ
    i have a perfectly good one sitting on my desk from my car. PM if you are interested.
    2016 C63S- ACM stage 1, VFF103, AWE, RWCarbon
    2012 s4 phantom black DSG, REVO stage 1+ , Awe exhaust with black diamond tips, strat intake, Eurocode sways and end links, Eurocode AK, 19"Stance sc5 wheels in black,rs4 grille, P3 vent gauge, facelift shift knob, Vag-commed, AWE coldfront(SOLD)
    check out my IG https://www.instagram.com/bgm130/
    Jun 05 2007
    Nashville, TN
    Quote Originally Posted by VenturiRS View Post
    They replaced it because the old one was peeling off. I wouldn't call it wear though. I think what happens is with the old design, when wiping the interior with a microfiber, the point in the "A" get snagged on the microfiber and peels up. It has nothing to do with lotion or anything like that.
    The new button is cut out differently, so there is no point on the "A" that isn't attached to the rest of the metal.
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    I just joined the club yesterday. No microfiber towel involved. It's been 10 degrees here in Philly and I was wearing gloves. The point of the 'N' caught and pulled up. Guess I'll be ordering the red-ringed button.
    Mar 22 2004
    NorCal
    Reviving old thread to give something back to the community. I bought off ebay $50, shipped from Lithuania, genuine Audi part, made in Britain, PN: 8K0905217C
    This trim guide really helped me: http://blog.ocarbon.com/2010/06/b8-a...removal-guide/
    It took me 30 mins as I was being very careful. I did not remove the shift boot and instead did some body contortion to see under, insert eyeglass screwdriver into button spring loaded clips while pushing bottom up with other hand.
    New S4 owner here (2010 DSG) and it is very pleasant inside with this worn button replaced.
    Jun 29 2015
    Danbury, CT
    Quote Originally Posted by maximus View Post
    Mine looks just like that, I really need to do this upgrade
    Active Member Two Rings glaciermetallic's Avatar
    Dec 06 2016
    Colorado
    Install on this is easy, did it two weeks ago replacing a worn silver for a new red one. AMAZON: Gear245 was the seller. I paid $53 for mine. The only hard part was shipping took 3-4 weeks, but it was worth it for me saving the money.
