Results 1 to 7 of 7
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    Question Engine Serial Number?
    Hey guys, I need to find out my engines unique serial number (long story as to why).
    Apparently it is a unique identifier like out VIN numbers and all our engines have it stamped or imprinted somewhere...and I'm not talking about those 3 letter codes likes BPG either.
    I am wondering if anyone knows where to find it on our engines OR if I can pull the unique code via vag-com or if I call my local dealer and provide my VIN like some people have suggested?
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Deactivated Four Rings
    Aug 30 2013
    2014 Toyota Highlander Limited, 1999 Mercury Grand Marquis GS-HPP
    Panama City Beach, FL
    There's a sticker on my engine that has BPG followed by a 6 digit number. Maybe the 6 digit number is the serial number of the engine...I'm not sure. I found two numbers stamped on the engine, but they look like part numbers and not serial numbers.
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Quote Originally Posted by kegobeer View Post
    That's the only thing it could be. No other serial on the engine
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    I've got this stamped right on the engine face, above the sticker you guys are mentioning.
    2008 A4 S-line 2.0T
    JHM Stage 2
    Jun 27 2011
    If anything it would be on the block though. That part above, that schweini posted is the timing cover and is a part that can easily be replaced (and is probably common given our awesome cam issues).
    However I have never heard of some sort of engine serial stamping or any way to find out if the engine is original...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    ahh, so that's what that is
    2008 A4 S-line 2.0T
    JHM Stage 2
    Aug 30 2013
    From what I've found Googling, the sticker I have with the engine code + 6 digit number is indeed the serial number. It's also (on at least one Audi direct injection engine) stamped on the engine block above the gearbox and under the thermostat.
