Results 1 to 10 of 10
    Feb 22 2010
    Madrid, SPAIN
    Cool Replacing the Bose subwoofer on my A3 8P
    Hi there!
    Last week I replaced the Bose subwoofer for a good one. I knew that bass was the weak point of this system. I've used a high quality custom made enclosure by RadioWorld (UK) and installed a Sundown SD-8 sub and a SAE-600D from the same manufacturer. The result is awesome.
    The Bose subwoofer is pretty hilarious:
    The custom made enclosure bought to Rw-online.co.uk
    Impressive build quality:
    Since there isn't an official distributor of SA gear in Spain, I had to buy it directly from woofersetc.com
    Good price at Euros exchange and fast shipping from LA to Madrid (just one week):
    This sub is a beast for a 8" cone. It really delivers power in a wide range. If it's well tuned the overall system is very balanced for all kind of music (I listen mostly rock)
    Hope you like it!
    g.
    Feb 22 2010
    Madrid, SPAIN
    Some pictures of the car that I've completely painted after almost 9 years
    Jan 08 2011
    phx, az
    did you just hook it up to the existing speaker wire?
    Feb 22 2010
    Madrid, SPAIN
    Quote Originally Posted by jumalian View Post
    Yes, the signal is taken directly to the wire that went to the original sub.
    In the UK forum of audi-sport some users asked me to be more specific. I'll try to have a little diagram to help you out if you want to do something like this
    Audi A3 2.0TDI S-tronic S-Line Lava Grey || 182.000km
    RNS-E 2010 | SDS | BT | Bose | Bi-xenon | Sunroof | Tempomat | Parktronic | Winter package
    RS6 steering | Alu pedals | 2010 S-tronic knob | Votex side skirts
    Original 18" 20-spokes wheels
    Bilstein Sprint (B8) + H&R
    Kit 3.2 brakes (30x345mm)
    Turbo Dynamics MDX481 Stage 2 Hybrid Turbo
    Milltek downpipe
    Jan 08 2011
    phx, az
    Quote Originally Posted by galanot View Post
    absolutely! i'd definitely want to check it out. thanks!
    Active Member One Ring QuattroA3's Avatar
    Aug 30 2014
    Mountain view
    I'm interested too
    Feb 22 2010
    Madrid, SPAIN
    Hello,
    Well, no diagrams, I'm sorry. I'll try to explain: the original wire to the Bose sub has been directly plugged to the "High level" connector of the amplifier (the white one in the picture below). As you probable know, not every gear features this kind of connector.
    The amplifier has a dedicated wired knob to control the bass intensity but it's also controlled by the bass leve found in the RNS-E head unit.
    I hope that helps! =)
    Milltek downpipe
    Jan 08 2011
    phx, az
    thanks, that should help. where's the amp mounted?
    Feb 22 2010
    Madrid, SPAIN
    The amp is mounted behind the back left panel, below the speaker. We had to cut a little bit to get the amp inside, but went smooth and had enough space. Note that there are smaller amps out there.
    Just a tip regarding the connections: the original Bose amp give power separately : 1. to the front speakers (central, tweeters and front door units) and 2. to the rear speakers and subwoofer. Now this amp is feeding the same except the sub that was removed. In fact, the new amp takes the signal from the old one (that was used to feed the original sub).
    Milltek downpipe
    Active Member One Ring JayAIII's Avatar
    Sep 28 2014
    Seattle WA
    How many watts did it have?
