Results 1 to 8 of 8
    Veteran Member Three Rings sempaipaul's Avatar
    Dec 21 2007
    several Porsches
    Gaithersburg MD
    best brake fluid?
    Guys,
    Just picked up an 03 RS6 and want to change out the fluid. What do you all recommend?
    Thanks,
    Paul
    Garage: 03' RS6 (FOR SALE); 16' 328i xDrive Wagon (FOR SALE); 13' X3 M-Sport; 05' Cayenne Turbo, 01' 911 Turbo
    I will admit I am partial to Amsoil. I run it in all of my cars and motorcycles for all the fluids.
    Using Tapatalk
    Veteran Member Three Rings suth31's Avatar
    May 16 2014
    2002 A6 2.7T 6-speed, 2003 350Z supercharged 6-speed, 2001 Hayabusa, 1995 Bronco
    massena, ny
    I use ATE Super Blue brake fluid. it is DOT4, high boiling point, relatively easy to find and reasonably priced, but the best thing is you know when you are completely bled as your new fluid will come out blue. It makes it pretty easy. I think ATE also has the same fluid without the dye - it was made for alternating colors between races basically. And it makes the fluid level A LOT easier to see in the audi - for some reason you cant see the regular stuff in the A6 reservoir.
    Dec 21 2007
    several Porsches
    Gaithersburg MD
    Quote Originally Posted by suth31 View Post
    Sounds good.
    How much fluid do you guys think i'll need to bleed the entire brake system?
    Thanks,
    Paul
    May 16 2014
    massena, ny
    i believe ATE only comes in the liter cans. one liter might do, but I usually purchase mine in pairs.
    May 06 2014
    2015 Ford Mustang Ecoboost, 2011 Nissan Armada SL, 2015 Buick LaCrosse E-assist
    Beloit, Wisconsin
    I just got done flushing out my whole system, only took .75L
    I use whatever brand DOT4 the local parts store has though, it's good enough for what I do.
    May 16 2014
    massena, ny
    those front rs6 calipers may take more fluid since its going to be pushing 6 pistons in total and on both sides of the rotor. i know my rotora 6 piston calipers on my 350z take a lot of fluid. should be safe with 1 liter. but like i said, i usually get them in pairs. better safe then sorry
    Established Member Two Rings CAL4.2's Avatar
    May 21 2014
    2001 Mustang GT 5-Speed
    I used ATE Typ 200. Only needed 1 liter.
