Results 1 to 18 of 18
    Oct 07 2008
    Nogaro B5 S4 Avant
    Venice
    Looking for Shops - Engine Rebuilds, Valve Jobs, Upgrade Cylinder Heads, Machine Shop
    Hi guys,
    I checked out the list of recommended repair shops but there weren't any that were strictly machine shops that build engines.
    Are there any that you recommend in the Greater LA area? Westside Los Angeles is preferred but will drive for quality work.
    I believe the Cylinder Heads on my B5 S4 need a valve job/rebuild so someone that has Audi experience is preferred.
    Thanks for the help!
    Gabe
    Veteran Member Four Rings singleframe's Avatar
    Apr 24 2010
    2007 Phantom Black RS4, VW eGolf
    Venice Beach baby!!! 🌞
    not Westside but heard great things about Wicked Motorsports!
    http://www.yelp.com/biz/wicked-motorsports-van-nuys
    IG @myRS4 | 2007 RS4 | Phantom Black | Milltek'ed | KW H.A.S. kitted | Rotiformed (SPF DDT 19X10 +25) | PSSed 275/30/19 | LED DRL'ed | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | Apikol rear-diff mounted | K&N Filtered | Ziza lit | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded | window trim matte black vinyl wrapped
    Active Member One Ring s4master1's Avatar
    Nov 18 2004
    11 S550, 08 A5 3.2, 06 S4, 06 A6, 13 RSV4,01 A6 2.8
    santa monica CA
    What's wrong with your heads ?
    Eurotech motors
    Audi specialist
    Oct 07 2008
    Nogaro B5 S4 Avant
    Venice
    Quote Originally Posted by s4master1 View Post
    Timing belt skipped a tooth or two and I don't know why yet. More info is in this thread:
    http://www.audizine.com/forum/showth...verage-misfire
    Veteran Member Four Rings AudiB5owner's Avatar
    Sep 08 2011
    B5 A4 1.8T AWM FWD
    Los Angeles, CA
    JL Automotive. I had my head rebuilt by one of his mechanics when my T belt went. Excellent work. I'm sure JL Automotive, WMS, or Eurowurx can help you out.
    B5 A4 1.8T FWD
    Veteran Member Four Rings Slave IV's Avatar
    Aug 28 2008
    MkV R32, C5 allroad
    CA
    Besides the mentioned places, I plan on talking to Cosworth about it when the time comes. They are local and the main company did develop the modified version of our engine in the RS4.
    Buy my B5 S4 Body panels!
    The dollar bill is nature's suicide note
    Veteran Member Four Rings jballou's Avatar
    Mar 19 2005
    Corona, SOCAL
    Quote Originally Posted by Slave IV View Post
    If you are willing to wait... Had a client leave his car at my house while he was having Cosworth port and build his heads. Took 13 weeks, meanwhile his car sat at my house..
    2000 Audi S4 Stage 3,000 Million +
    Some crap just thrown together, puzzlingly making more power....
    YouTube Channel: http://www.youtube.com/user/jsballou
    Aug 28 2008
    MkV R32, C5 allroad
    CA
    I just waited three years for my bodywork to finish. 13 weeks sounds like a breeze and I'm just happy to know Cosworth is available to do the work. Thanks!
    Veteran Member Four Rings johnnybravo!'s Avatar
    Feb 20 2006
    323 EASTLOS, CALIFAS
    Quote Originally Posted by AudiB5owner View Post
    Jose @ JL Automotive ..talk about a guy who not only is an excellent VAG mechanic(works on all cars really) but his honesty/integrity is something to admire.. this guy doesn't charge enough for all work he does and the extras he includes.. good work..good peoples
    SRM K24 - Bosch 1000cc - Rods - 2.8 Cams- RR STG 4 clutch - AA-built 01E+4:1 - OS Giken LSD - ER IC's - JHM SS - SRM DPs - Vibrant 3" - Vast W/M - RS4 Y-Pipe - ASP MAF - APR Bi-Pipe - Ohlins MS Coilovers - AP Racing BBK - 034 Rear Sway
    C7 A7 Silver- Jackal STG 2+E40 Shane Horning ported s/c Merc HX- Pierburg 100-3 - Eibach Springs- OZ 20" UL wheels/Michelin PS4s- Eurocode Sway Bar- Borla- IE Intake
    Audi. Truth in Understeering.
    Veteran Member Four Rings A6C5V842's Avatar
    May 11 2010
    PNW
    Max,
    Talk to me before you speak to Cosworth. Some history there . . . .
    Glyn - with a "y"!
    Nemo - Manual!
    Email me
    Theory can get you killed. Skill and observation are your only way out
    Senior Member Three Rings discoverdeath's Avatar
    Aug 15 2010
    anahiem
    When I was rebuilding my b5 s4 I sent my heads to Heads Above The Rest, I want to say they are in the Fullerton area. I had them washed up and checked for cracks, sure enough I had a crack in the cylinder 2 exhaust port. Bunch of guys i work with sent stuff out there with out issue.
    Oct 07 2008
    Nogaro B5 S4 Avant
    Venice
    Thanks for all the recommendations! I hope that this thread can be useful for others as well.
    Turns out, I don't believe any valves were bent. The symptoms I had were caused by both head gaskets burning out between the cylinders. I am still planning on getting the heads cleaned and checked for cracks.
    I reached out to Mike at WMS since he is the closest and he wanted to do the whole engine swap or rebuild instead of just doing the engine. I reached out again once I found out the real problem and am hoping he would be willing to do this check/clean for me.
    Aug 28 2008
    MkV R32, C5 allroad
    CA
    Thank Glyn! I'd definitely be talking to you about it before I did anything. Still a long ways off for me though.
    Veteran Member Four Rings skiracerblah's Avatar
    Jan 03 2011
    Evo X MR : 290whp, 313 lbs/torque @ 24psi; Evo IX : 383whp, 383 lbs/torque @ 28psi E85
    San Fernando Valley, CA
    i thought Cosworth USA shut down in SoCal....They're still running
    Sorry for newbie questions, this is my 1st Audi
    Current: Phantom Black '2011 S4 S-Tronic Premium Plus, Sports Rear Diff, JL Audio subwoofer upgrade, Milltek Resonated Exhaust
    Old cars:
    Evo X MR-Touring stock, but tuned by RRE: 290whp, 313 lbs/torque @ 24psi 91 octane
    Evo IX tuned by RRE: 383whp, 383 lbs/torque @ 28psi E85 ethanol fuel
    Aug 28 2008
    MkV R32, C5 allroad
    CA
    Quote Originally Posted by skiracerblah View Post
    Is that a question that you answered yourself or are you asking if they are still running? I haven't looked into it besides knowing they used to have a location in SoCal (Torrance, I think). I hope that's still the case when the time comes for me otherwise, I guess I'll be keeping track of this thread for other options.
    Jan 03 2011
    Oh, i was asking if it was still running, forgot to input question mark. As far as i know, that facility shut down. I just Google'd it and it appears they did shut down their operations in the USA...
    Whom does GMG use or they do it in house?
    Old cars:
    Aug 28 2008
    MkV R32, C5 allroad
    CA
    Oh, well that sucks...Their main website still says this:
    Cosworth is headquartered in Northampton with additional facilities in Cambridge and Exeter in the UK and Torrance, Indianapolis and Mooresville in the USA.
    Not sure who GMG uses but if I can't get Cosworth, I'll just see who Jose at Euro-Tech recommends for me and that's what I would do before I did anything anyways.
    Oct 07 2008
    Nogaro B5 S4 Avant
    Venice
    For an update, I ended up using Engler Bros on Pico in Santa Monica.
    http://www.englerbros.com/
    Nice small shop that is on the Westside and has quick turn around. They used to do engine blocks but don't anymore as the guy retired. They did, however, do a great job with my heads.
