Results 1 to 22 of 22
    Veteran Member Four Rings JKnight41's Avatar
    Oct 11 2012
    Southern Illinois
    Axle removal tools
    Gonna be replacing my drivers side axle with one from ECS this week. I need to buy the tools today, but am not near the car. Could anyone tell me the specific size you need for the main axle bolt, and the bolts that mount it to the transmission?
    Any help is appreciated. Thanks.
    -00 Hibiscus S4 Sedan (FOR SALE)
    -09 Audi S5 / SOLD
    -01 Audi S4 Avant / SOLD
    -04 Audi S4 / SOLD
    -00 Audi S4 Stage 2 / SOLD
    Veteran Member Four Rings s vier's Avatar
    Dec 10 2006
    Midwest
    17mm ALLEN socket for the hub bolt
    12mm triple square or "spline" bolts on the tranny flange. 90% sure on that size.
    2015 Suzuka RS5 Black Optics
    Wings
    Carbs
    Titaniums
    Oct 11 2012
    Southern Illinois
    Thank you sir
    -09 Audi S5 / SOLD
    -04 Audi S4 / SOLD
    Veteran Member Three Rings mkemk3's Avatar
    Oct 11 2010
    Central MA
    If you have an OEM axle chances are you will need a large allen to removeb the shoulder bolt from the hub. I'd pop the lug cover off and have a look.
    Avants do it better!
    Dec 10 2006
    Midwest
    Quote Originally Posted by mkemk3 View Post
    Correct. 17mm as stated below. EDIT: I was thinking Allen but didn't write it. Previous post adjusted.
    Make sure your wheel is on the ground when you try to crack that baby loose. I needed an 8 foot breaker bar. It is a "torque to yield" bolt as well. That means one time use. Get a new one.
    Wings
    Carbs
    Titaniums
    Aug 04 2013
    Pennsylvania
    I thought it was a 14?
    In any case, you'd be better off just having a good set of hex bits and triple squares. I've been using a large hex bit set I got from autozone for like 40 bucks without issue for years.
    I have also seen new axles come with regular hex head axle bolts that are like 32mm or something
    Oct 11 2012
    Southern Illinois
    I do have all the correct tools at home, but not at school. Since I won't be home soon, I just wanted to get some for now.
    -09 Audi S5 / SOLD
    -04 Audi S4 / SOLD
    Veteran Member Four Rings Austonwerner4's Avatar
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    My axle bolts are 21mm I believe.
    Single Turbo on it's Way
    PM me for 17z and 18z Caliper Needs
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    most likely youll need a 17mm allen and the 13 mm triple sqaure. and i cant remember what size allen to get those heat sheilds off cause just dont even put them back on.
    Mine - Silver 01.5 S4 stage 2 - st - apr - ssac - apikol
    Wife - Imola 00 S4 stage 2 - st - ssac - podi - usp - 034
    Ours - Silver 92 S4 custom coilovers - 3 inch exhaust - ak motorsports
    Indigo Pearl 92 Coupe
    White 07 Q7
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    Quote Originally Posted by APR-S4 View Post
    14mm for the rear.. OP didn't say front or rear so hard to know. :)
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
    Oct 11 2012
    Southern Illinois
    Quote Originally Posted by Timtheguru View Post
    This is true! It is drivers side. I ordered a set of hex, and triple star sockets to keep in my car. Thanks all for the quick responses.
    -09 Audi S5 / SOLD
    -04 Audi S4 / SOLD
    Dec 30 2009
    Quote Originally Posted by JKnight41 View Post
    So is it front or rear on the driver side? lol
    2001.5 S4 Sedan
    2018 Q5 2.0t
    Veteran Member Four Rings Shhmaudi's Avatar
    Nov 16 2009
    Ducati 1299 panigale, Raptor, Tesla Y, MK2 TTRS
    Sandy eggo
    Its a 12mm triple square for the inter bolts that go to the trans flange.. 17mm are the front axle bolt through the hub. I used the jack handle sleeved over as an extension to my breaker bar to get that sucker loose. I have broke a couple 1/2in bits before trying to get one of those bitches off..
    Old: 1.8T Stg 3, Noggy stg 3, Silvaro tag 3 B5 |JHM Trans W/Carbon Syncros 4:1 diff|Tial 770|I.E Rods|Built 2.8 Heads W/ supertech RS4 intake, Y pipe, manifold etc...
    Current: 2013 TTRS Nimbus grey| HRE FF01| 034 RSB w/endlinks| 034 CF intake| 034 dogbone mount & CNC shifter bushings| Miltek DP custom 3in exhaust| Autotech HPFP| AEM 3-1 gauge|Schroth racing belts| S3 shifter| Revised injectors| Ceramic coated/ PPF
    Aug 04 2013
    Pennsylvania
    Also, to each their own but I think it's a good idea to put the axle heat shield back on. It takes hardly any time and I've heard that without it the inner boots will tear more easily/quickly
    Nov 16 2009
    Sandy eggo
    Lol I havent ran mine at all during my stage 3 career(3 yrs running)....I also have free lifetime replacement axles.. Havent had any issues with over 30+ launches on em as well
    Oct 11 2012
    Southern Illinois
    Broke 2 1/2 inch drive bits trying to get it off. Soaked in PB last night. Tapped on it to break it loose. Still it's not budging. It's fucking intense. Gotta order some new ones. Maybe next week will be better.
    -09 Audi S5 / SOLD
    -04 Audi S4 / SOLD
    Senior Member Three Rings t28sentra's Avatar
    Nov 18 2007
    B8.5 Allroad ,B6 S4, B5 S4 (Imola - Sold), B6 A4 USP , B5 A4 Sold, Laser B5 S4, Jeep Wrangler (Sold)
    Toledo, OH
    Snapon sells a 3/8" drive triple square for Porches and Audi axels.
    B8.5 Allroad (APR K04 E85), B6 S4 (JHM Goodies), B5 S4 Imola Avant (JHM RS6-R), Touareg V10 TDI, B6 A4 USP (REVO Stage 3) SOLD, B5 S4 (EPL Stage 3 on Meth) SOLD
    Feb 21 2011
    WA
    You do have someone on the brakes as well, right? Even on the ground it is smart to have someone stand on the brakes to break the shoulder bolts.
    Dec 05 2007
    For future reference, NAPA sells the 12mm triple square if anybody needs one some day and is in a jam.
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    A trick I use to get the outer axle bolt off is to get a nice long breaker bar. And put a jack under the breaker bar and jack the breaker bar up to break the axle nut loose. Works for me every time when I'm removing Audi outer axle bolts.
    Aug 04 2013
    Pennsylvania
    I generally just use a breaker bar with someone on the brakes. If your bits are breaking maybe get some better bits? lol not much else you can do. I suppose if it really isn't happening you could maybe grind the head off of the bolt or cut it off with a torch
    Oct 11 2012
    Southern Illinois
    Both were snap on bits. Ha. I will try more this week
    -09 Audi S5 / SOLD
    -04 Audi S4 / SOLD
