Results 1 to 7 of 7
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    fsi coil packs for the bel valve cover
    So i have a bel engine im building and swapping out for my apb. I have the stock set of coils but found the fsi coils are much stronger.
    Does anyone know the part number for the fsi coils that are the shorter version to fit the bel valve covers.
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    i asked this same question not long ago. got replies like just go with the adapters and what not, not sure if anyone has gone this route, i intend on it ill find the part number i figured would work the best, was gonna buy one and test fit.
    heres what i got i think i referenced a part number in the thread, if you beat me to the test fit let me know, ill do the same.
    http://www.audizine.com/forum/showth...-covers-on-apb
    so much cleaner than the adapters route.
    Mine - Silver 01.5 S4 stage 2 - st - apr - ssac - apikol
    Wife - Imola 00 S4 stage 2 - st - ssac - podi - usp - 034
    Ours - Silver 92 S4 custom coilovers - 3 inch exhaust - ak motorsports
    Indigo Pearl 92 Coupe
    White 07 Q7
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    I work at a dealer so I'll just grab all the coils for Fsi and try lol
    i ordered a full set but i dont think they were fsi so ill be sending them back
    Jul 14 2014
    richmond va
    Short coils are from 1.8t , they not strong as FSI long coils , most 1.8 guys upgreating to fsi coils , and using toureg coil adapters , most powerfull coils red coils 06E 905 115 E out Audi r8 or vw toureg , with toureg adapters they fit perfect in 2.7 , dont waste your $$$ on any other coils then red coils , i work for vw dealer where is APR product is of the shelf , after flashing ECM on 2.0 fsi cars they come back with in 1000 k , with misfires , we reinstallining red r8 coils , so any costumer that getting APR product we recomend an r8 coils , so spend money ones get right parts
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    yeah i get what your saying tasin its just we have bel valve covers and they dont have the bolt holes for the toureg adapters
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    you could just swap valve covers to make it easy.
    For what it is worth, my AWM 1.8t didn't use bolt down coils. When I switched to the red top FSI coils, I just took the rubbers off the stock coils and put them on the FSI coils. They fit snuggly. It looks like that BEL valve cover would be the same deal. No need to waste money on coil adapters. Sure, they stick out a bit more than stock coils, but I haven't had a single issue since I swapped the rubbers around. Not a great pic of what is going on, but you get the idea.
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Jul 14 2014
    richmond va
    I think with BEL covers you my get away with using adapters , try local dealer talk to thim get one short one from 1.8t and long one from r8 see how they fit , after wise just return thim ,
