Results 1 to 26 of 26
    Sep 11 2014
    Kansas City
    Which timing belt kit to buy?
    I am brand new to Audi's and changing timing belts. It looks like ECS tuning is a sponsor so, are they where everyone purchase their kits? Or does anyone recommend a kit from another site?
    I have found several right-ups about changing it but, I haven't seen anyone talk about any special tools to remove/replace the timing belt and tensioner. Is there any tool that would make it easier? Do they make a jig that holds all the pulleys in place while you change the belt?
    thanks in advance!
    Veteran Member Four Rings xhackerekx's Avatar
    Jul 23 2007
    10S6C6_12Q7TDI_A4B6 3.0_VNL730
    Scranton , PA / Poland UE
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    The content is much more important than who it is purchased from. There is a current thread regarding one of the kit ECS sells. They are using an inferior Geba brand water pump that is failing prematurely. I say go with all OEM parts.
    2019 SQ5 Prestige
    Veteran Member Four Rings FromS60toB61.8t's Avatar
    Aug 26 2007
    07 Fahrenheit GTi, 09 S8, 17 GSW S 4-Motion, 19 S4 Black Optics
    use ECS as a reference for part numbers and buy oem parts
    19' Glacier S4 Black Optics
    Jun 18 2009
    98 civic hatchback
    Chambersburg, PA
    I got the one from blau parts and water pump failed after 8 months. go OEM.
    Mar 14 2010
    Q7 3.0T & 911 C4S
    Wyoming
    I'm planning on going with the europaparts kit.
    Daniel J
    @gtg_drives
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    i got mine from integrated engineering, it came with my rod install kit :)
    the belt is a continental brand , have to double check the brand of the water pump.
    often times, companies like ECS and others, try to make package kits with everything needed, and they use cheaper parts to save you money. but no corners should be cut on such critical items for our engines.
    Audi Club Bay Area
    Veteran Member Four Rings DiertyEuroSpec's Avatar
    Aug 21 2009
    Fairfield County, CT
    Quote Originally Posted by asinclado View Post
    Wow I was under the impression Blauparts was an OE supplier. They offer the Graf water pump... any other feedback on these as this was the kit I was planning on going with to replace my ECS kit.
    2003 A4 1.8T Quattro | 18" BBS CH | KW V3 | FT F21 Mixed Flow | MOTOZA | RA4 Stage 1 w/SMFW | Milltek | Uni HFC/3'' DP Combo | 3'' TIP w/MAF | 550cc | TR1.8 FMIC | USP F/R | H-Sport F/R Sway | APR Snub | RS4 Motor Mounts | Stern Trans Mount | Skid Plate | Solid Tie Rod Ends | Short Shifter | Euro Shift Knob | VMR Boost Gauge | S4 F/R Brakes | Tyrolsport Stiffening Kit | ECS S.S. Lines | Hawk HPS Pads | 034 PCV
    Veteran Member Four Rings PreciseD's Avatar
    Feb 05 2014
    Just in case anyone wanted to know I just confirmed with IE that they are using Hepu water pumps.
    ----- My EFR 7670 Build Thread ----- "The thing about quotes on the internet is you can not confirm their validity" - Abraham Lincoln -----
    Sep 11 2014
    Kansas City
    The kit I got from Blauparts has a Graf waterpump and a Gates belt. But, the tensioner has China stamped on it. I called them about it and they said that it was made in China but made to Audi specs. They also said that a lot of car companies are having parts made in China and they even the parts from the dealership have China stamped on them. Anyone know if this is true?
    Aug 26 2005
    Quote Originally Posted by sbp82290 View Post
    Unless the Chinese parts are made by Audi in China or an actual Chinese Audi OEM, you don't really know what you are getting despite the claim the parts are made to Audi specs.
    Gates makes or sources all of the parts needed to do a timing belt job, and the belts are the best available anywhere. The other parts are either made in the US, Mexico or Germany.
    Vorsprung durch Technik
    Sep 11 2014
    Kansas City
    Im trying to figure out if i should just use the parts in the kit or buy oem. Blauparts wants a 20% restocking fee.
    Veteran Member Three Rings msharifi's Avatar
    Aug 13 2008
    Orange County Cali
    Did you order "Audi A4 Timing Belt Kit - 2002-05 w/ 4 Cylinder 1.8L Engine (2003-06 Cabriolet) - Gen II - Enhanced" I'm about to order and it says Litens parts are they made in China?
    Gen II BLAU® Audi A4 Timing Belt Kit For 1.8T I4 Engines
    BLAU® INA Pre-assembled Base Kit Includes:
    1 'INA Gates' Timing Belt
    1 'Litens' Timing Belt Tensioner
    1 'Litens' Timing Belt Tensioner Idler w/Bracket
    1 'INA' Timing Belt Service Interval Sticker
    Enhanced+ Additions:
    1 'Graf' Water Pump w/ Metal Impeller and Gasket
    3 Water Pump Bolts
    1 'Flennor Gates' Serpentine Belt
    4 Serpentine Belt Pulley Bolts
    1 Viton Front Crank Seal
    1 Viton Camshaft Seal
    1 Thread Locking Compounds
    1 Anti Seize Compound
    Blauparts Detailed Step-by-Step Audi A4 1.8T Timing Belt Instructions
    Numerous pages and over 30 images of detailed step-by-step guidelines, including front bumper removal.
    Veteran Member Four Rings Willënskraft's Avatar
    Oct 14 2011
    2002 Audi A4 1.8TQ, 2007 Audi A4 2.0TQ
    Norcross, GA
    Intstalled the Blauparts timing belt kit back in March and it's holding up pretty good. Although, an update on their instructions with colored pictures would be great.
    "Beep beeeep bloop boop" - R2D2
    Veteran Member Four Rings blitz2190's Avatar
    Jul 31 2014
    2004 A4 1.8T Quattro, 2.7T swap Stage 3 APR 6 speed
    NH
    my blauparts kit is running fine after 40k miles so far.
    Never argue with an idiot, they'll bring you down to their level and beat you with experience.
    2.7T Swap Wiring Guide (Psst this is a link)
    New Build In progress built 2.7 STK 2004 B6 A4- Thread and pic to come
    Veteran Member Four Rings jonan's Avatar
    Nov 25 2006
    2X B7 RS4 - STG III B6 A4 (gone, but still in the family) - Mini R56 S - '15 Macan S - 997.1
    Austin, TX
    last time i changed my belt i used the water pump with a metal impeller...failed after 30k miles and started leaking coolant...went with the OEM pump with the non-metal impeller this go around...
    Want my guns??? ΜΟΛΩΝ ΛΑΒΕ!!!
    B6 Mods:
    Fully Built Motor w/ GT2860RS and all supporting mods : My Build Thread
    RS4 Mods (sprint):
    RNS-e MKII : ECS SS : JHM Spacers : Deflapped IM : UM Tune : KW V3s : Tubi Rumore : Hotchkiss F&R SBs : 034 Diff Inserts : Phil Special Headlights w/ STI Lenses : 10 Layers : Spare 07BNS (#masterrace) : Apikol Diff & Trans Mount
    Oct 14 2011
    Norcross, GA
    Quote Originally Posted by jonan View Post
    Which brand was the metal impeller and how long has the OEM holding?
    Nov 25 2006
    Austin, TX
    not sure, it was the metal pump include in the MJM auto haus plus kit.
    http://www.mjmautohaus.com/catalog/product_info.php?cPath=6169_6170_6187_6190_6729_91 71&info=OEM_VAG_06B109119F.AMBE.KIT3_Timing_Belt_K it_"PLUS"_Early_Models&products_id=2166
    OEM been holding up strong, plus if the impeller breaks the pump will simply stop working instead of destroy my motor with metals bits and pieces..
    B6 Mods:
    RS4 Mods (sprint):
    Aug 13 2008
    Orange County Cali
    My timing belt kit when I first changed it at 80K came with GABA and only lasted 25k miles before it was changed with the Metal one. I think GABA water pump goes bad really quickly unless they have improved it. Graf or Hepa I heard great.
    Oct 02 2006
    Wadsworth,OH
    I'm due for another timing belt service and I will be going with a Genuine Audi water pump and the solid tensioner from IE with the B7 roller tensioner.
    I've put almost 100K on the last Genuine Audi plastic impeller water pump so to me it's a no brainer to go with another one.
    Jason
    Jan 10 2013
    03 A4 Avant 1.8TQ
    South San Francisco, CA
    LOL I thought the recommendation was that the metal impeller was better than plastic....anyways, mine was replaced with a Graf back in January (guessing about 10k miles ago at the most) and its still fine *knock on wood*
    Registered User Four Rings chris@fifteen52's Avatar
    Oct 04 2012
    Everywhere
    I used the Blau Parts kit at 100k and at 175 and will probably get another one next month at 250k when I change everything again.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by chris@fifteen52 View Post
    Are you using the hydraulic damper or the Litens spring loaded pulley damper?
    Oct 04 2012
    Everywhere
    Oct 02 2006
    Wadsworth,OH
    Quote Originally Posted by WB650 View Post
    Metal impellers are good in theory, but if for whatever reason something gets lodged in the impeller it can cause it to jam up the cog that drives it. Possibly trash your engine because the belt would skip. At least if something jams up the plastic impeller it hypothetically would break apart and hopefully not cause an issue with the belt.
    Your vehicle has sensors that will tell you way before your car starts to really overheat if there is insufficient coolant flow and the temp starts to rise. The dash warning light comes on as soon as the needle hits the first notch past normal. Hopefully giving you enough notice to get to the side of the road and shut it down.
    It's all personal preference. I've heard good things from metal impeller water pumps as well. Some may not like the idea of plastic particles in the cooling system if the impeller breaks.
    Jason
    Jan 10 2013
    03 A4 Avant 1.8TQ
    That makes sense, my water pump with the plastic impeller failed on me earlier this year while in a drive thru. Was able to get out and pull over just in time as it was reaching Hot. Now it's the metal one in there
    //Auto Union Bay Area : NCAC Member : Motoza Stage 1
