Results 1 to 12 of 12
    Feb 15 2007
    Scratch on roof rail... what to do?
    Hey guys,
    I've noticed a scratch on the driver's rail and was wondering what could be done to fix this. Dealer wants 5 hours to remove headliner and all associated pillars and parts. I don't want this done.... It can't be polished because there is a coating that makes the semi-polished look. Need tips/ideas!
    2007 Audi RS4 - Daytona Grey - Original Owner
    1957 MG MGA 1800 - Austin Healey Spruce Green
    2020 Mercedes-Benz GLC 63 AMG - designo Cardinal Red
    2024 Tesla Model 3 Dual Motor - Stealth Grey
    Veteran Member Four Rings spijun's Avatar
    Oct 10 2010
    Audi Q5 2.0TFSI S tronic
    Sarajevo, BiH
    Yes, try with polishing because it is made ​​of aluminum
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    I assume the dealer is quoting on replacing the part, or do they have some magic repair formula?
    I've heard rumors of really high quality repair work, but I've never actually seen it. My best efforts have minimized such damage, but to the best of my knowledge and ability there's no way to repair.
    I have had luck with abrasive polishing. Definitely a coating there, but it's quite thick, and leveling the area around the scratch can minimize it. (I wish I knew more about the coating - I'm guessing it's either a galvanized or some sort of polarized, but I've never even been able to learn what it is, let alone how it's applied.)
    If you're up for experimentation, I have had reasonable luck with polishing, taping, scuffing (0000 steel wool is fine), and then painting with a couple of thick coats of Wurth wheel paint. Surprisingly, the bright silver and clear end up being a pretty decent match, and they do a nice job of filling. Your call whether to follow up a few days later with a fine abrasive polish....probably not necessary if you were very thorough in taping.
    I've heard semi-good things about these guys:
    http://www.yourautotrim.com/semdye.html
    As you'd guess, the downside is whether the durability is there, but if applied carefully, and with a good clear on top, I'd suspect adhesion would be fine. The only other option I've found is wrapping in a vinyl film. Of course, to be done well, you've got the same amount of labor involved to pull the piece.
    Good luck. Looks like the scratch is on top? Hopefully that makes it harder to peek at?
    --Jerry || 2020 SQ7 Pr, GW/Black/BO (His); 2018 S5 Cab Pr, Daytona/Red (Hers)
    Suspension || H&R Springs - 29001-3; Bilstein B8 Dampers - 24-145985 (F) & 24-145992 (R)
    Wheels & Tires || BBS CI-R - CIR 0501 BPO, 20x10 ET25 Satin Black; Continental DWS06 275/40
    ...Formerly: '16 SQ5 '13 Q53.0T '12 Q5 3.2 '08&'06 A4 Avant 3.2.
    Feb 15 2007
    Thanks for the help. I bought the car last Monday and by the time they prepped the car, it was dark. The dealer is will to pull the headliner and replace the rail for free. However, I don't want the headliner to be pulled on a brand new car. It's on top, but I'm tall (6ft) and it's at eye level for me. My wife doesn't mind it, but it's a new car and I want it new. I'll never have a rack on it though
    Established Member Two Rings Yoshimura's Avatar
    Nov 25 2012
    Montreal
    Plasti dip them black?
    2018 S5 Sportback Technik - Sport Differential / Adaptative Suspension
    Feb 15 2007
    Quote Originally Posted by Yoshimura View Post
    negative. Like the bling
    Nov 11 2010
    2019 RS5 Sportback
    WI
    I'm not understanding why you would rather have a repaired rail over a new one. I think you would notice that repair unless the whole rail was redone or covered in vinyl/plasti dip
    @mlaakness
    2014 SQ5 Premium Plus | Phantom Black | Black Nappa | B&O | Nav | 21" Wheels | Side Assist
    Previous - 2019 RS 5 Sportback, 2018 S5 Sportback Prestige, 2014 S4 Prestige, 2013 S4 Prestige, 2009 A4 3.2 V6 Prestige
    Feb 15 2007
    I would notice a stretched and ill fitting headliner that rattles if they were to replace the the rail with a new one. The whole headliner and various pillars and other parts have to come off. I'm sure the tech doing it isn't going to make sure every little clip is properly placed and seated. Also, it's a tan headliner and I'm sure it's going to get hand prints all over it. That is why I'm looking for ways/ ideas on how to repair it.
    Feb 15 2007
    The scratch has been fixed! The body shop used some special polish ($300 an oz) and the scratch came out without discoloring the surroundings. They wouldn't tell me who made the polish or what it was called. Anyway, thanks for the ideas guys
    Oct 10 2010
    Sarajevo, BiH
    That's what I said at the beginning
    Nov 11 2010
    2019 RS5 Sportback
    WI
    Quote Originally Posted by zachf88 View Post
    Understandable. Everyone's dealers are different so my perspective comes from one that is very meticulous which makes me not worry about replacements.
    Glad you got it fixed.
    @mlaakness
    Oct 10 2010
    Sarajevo, BiH
    Quote Originally Posted by laakness View Post
    I would never did
    It's a job that requires at least two days and this is just one part
    – Fold down backrests (rear).
    – Move front seat backrests to 45° position.
    – Remove A-pillar trim (top) → Chapter.
    – Remove B-pillar trim (top) → Chapter.
    – Remove C-pillar trim → Chapter.
    – Remove roof end trim → Chapter.
    – Remove D-pillar trim → Chapter.
    – Remove retainers for load guard → Chapter.
    – Remove sun visors → Chapter.
    – Remove interior light/reading light (front) →Electrical system; Rep. gr.96.
    – Remove centre bracket for sun visor → Chapter.
    – Remove roof grab handles → Chapter
    – Removing and installing roof rail
    Of course always there are great chances that something was not done properly, that you have strange noises and rattling
