Results 1 to 29 of 29
    Established Member Two Rings cdh9400t's Avatar
    Feb 06 2014
    Ohio
    Best brake options for daily driver
    I'm due for brakes. fronts pads are low, and rotors are original with 76k miles on them. Rears have good pad and same rotor wear as fronts, but squeel real bad. I have been looking at ECS and audi, but I am not sure what to go with. It is a daily driver, but i also have a little fun every now and then. I like the Audi rotors, which I believe are Brembo, and I like the Audi pad stopping power, but hate the dust. I can clean my rims drive one day and they are covered again. Any opinions would be great.
    Deactivated Four Rings
    Aug 30 2013
    2014 Toyota Highlander Limited, 1999 Mercury Grand Marquis GS-HPP
    Panama City Beach, FL
    No need to upgrade the rotors or calipers, really, unless you are heavily modified and going to the track a lot. Just get a low dust pad. I bought Hawk Performance pads, and the dust is pretty low. There are a ton of options out there, and quite a few threads on the subject, too.
    Mar 24 2013
    Oakdale, CT
    El cheapo rotors, Hawk HPS pads, and stainless lines with a good fluid flush.
    -Adam
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Ceramic pads are your best option. Hawk seems to be the popular favorite. Best rotors for the least amount of money are ABT from eBay. No point in upgrading rotors unless they need to be replaced though.
    2021 Audi S4, P34 Intake
    Feb 06 2014
    Ohio
    I am really leaning toward stock rotors, but really wasn't sure on pads. I have seen ebc yellow stuff pads, but havnt seen much on them.
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by kegobeer View Post
    Best bang for the buck
    Aug 14 2014
    1987 Alfa Romeo Quadrifoglio, Jeep 2.0 Wrangler Sport, 1979 P200E Vespa , 2005 Triumph Bonneville
    was wondering the same thing...next thing to do... also, do you guys recomend not removing the calipers if you just need pads replaced (saw it in another thread) or removing them to replace?
    Feb 06 2014
    Ohio
    I don't know I have read a lot of people don't like the hawk hps pads. Not much initial bite. What about akebonos
    Veteran Member Four Rings Biged243's Avatar
    Mar 27 2013
    Vr6 gti
    Metro Detroit Michigan
    I believe the akebonos a lot of people get a clank out of them. At 75k+ mile it would be good to replace both rotor and pads! most likely the rotors have some type of groves in them so it will wear the pads quicker. Also I think you saw people talking about the caliper carrier (bracket).
    What ever makes sense go with the opposite and you got it
    Veteran Member Four Rings rongeur's Avatar
    Jun 04 2011
    Clayton, CA
    This 100%. Centric rotors are great affordable rotor and are used as the source blanks (i have been told) for many premium companies. I picked up some centric performance rotors for about 140 for all four. Hawk HPS pad, SS lines and some ATE type 200 fluid and you will be set. Oem rotors are super soft and notch easy.
    2008 A4 2.0T Quattro 6MT S-Line QGM
    Stage 3 JHM TD05H-R on a fully built motor
    Build Thread
    Veteran Member Four Rings Mister W's Avatar
    Jan 29 2011
    2017 Mitsubishi Outlander GT
    Otterburn Park, QC
    I have centric disc and cant say bad thing about them. But i have stop tech pad and they seem to leave some brake dust deposit on the disc and give me vibrations innfront when braking . I might check for harder compound pads.
    Owning an Audi is like having a hot girlfriend that's mentally unstable
    2013 Allroad sport pkg, 19" gold Radi8 r8s5, B8 Sline suspension, AEM air filter, more to come...
    Veteran Member Four Rings Andrew149's Avatar
    Apr 19 2009
    Modesto/CA
    Quote Originally Posted by Mister W View Post
    Vibrations would be from a wrapped rotor.
    2008 Audi A4 2.0t S-Line 6mt
    2012 Audi A6 3.0t
    2019 GTi 2.0t 6 speed
    2013 Touareg VR6
    Senior Member Three Rings dbens's Avatar
    Jun 07 2011
    Montreal
    I have ebc red stuff on the front and green stuff on the rears. after about 2 weeks i barely have any brake dust plus theyre quiet and good initial bite same as oem
    2007 B7 A4 QG TI S-Line / Debadged / 35% front & 20% back tint/Evomsit stage 1 flash/ Neuspeed Springs / Emilgevor interior led kit / Hoen Xenon matched fog lights
    Senior Member Three Rings Jhad's Avatar
    Aug 03 2012
    '11 Touareg
    SEPA
    hawk pads and either oem/zimmerman/adams rotors, ss lines, and super blue fluid.
    Nov 15 2011
    Montreal | I sell in USD
    Zimmerman rotors and TRW pads are the best oemish combo imo. Bit more expensive than going Centric or Ebay but worth it.
    Quote Originally Posted by Andrew149 View Post
    He said it, hes getting vibration from brake pad deposit on the disc.
    Good read
    Quote Originally Posted by Jhad View Post
    I think you fellow americans dont have access to ATE super blue anymore, I might be wrong though.
    *****I sell in USD*****
    Aug 03 2012
    '11 Touareg
    SEPA
    Quote Originally Posted by Axis View Post
    good catch. yeah, looks like they banned it last year... because its blue lol. I still have enough for 2 flushes. I think that we can still find it online, but its 'illegal' to use on the street.
    Nov 15 2011
    Cheaper for me to buy ATE from my parts store than oem brake fluid. I could send you some with some kinder surprise eggs :)
    Aug 03 2012
    '11 Touareg
    SEPA
    awesome... now if only I could get my milk in bag form too
    Senior Member Three Rings typeslone's Avatar
    May 09 2011
    06 A4Q 2.0T, 91 GTI VR6 Drag car
    North Jersey
    I run Zimmerman blanks with hawk hps pads and a Tyrol stiffening kit. I love the setup, I think it stops 1000 times better than my old setup of textar pads, Tyrol stiffening kit and Zimmerman cross drilled rotors.
    91 GTI VR6 - all motor madness 12.62@106mph and dropping.....
    06 A4Q 2.0T - Revo Stg2/APR HPFP/034 HFC/TT Downpipe/EuropaParts Exhaust/Eibach Springs/Bilstein Sport dampers/RS4 Rear Swaybar/Fluidampr/RS4 engine mounts
    10 WRX hatchback - Torqued performance Stg1/Perrin/Whiteline/Enkei BR7/The wifes daily is faster than mine!
    Caste Systems Performance
    Lugtronic
    Veteran Member Four Rings 4rings5stars's Avatar
    Jul 31 2011
    I'm gonna be doing my fronts at the end of the month. I didn't see any standard ABT rotors on ebay, but Amazon has the Raybestos 980499R for $48 each w/free shipping.
    Any solid reason to go with the Hawk pads over the Akebonos?
    The fleet
    2000 S4 EPL tuned Stage 3 -- Silver/Panda -- Latest fun project
    2002 S4 Avant 6spd -- Nogaro/Silver -- Long term rehab project
    2012 A8L -- Night Blue Pearl/Nougat
    2013 VW Touareg VR6 Lux -- Flint Grey/Black
    2001 BMW 540iA Sport -- Steel Blue/Grey
    2001 BMW 750iL -- Night Blue/Ivory
    2004 Jaguar XJ8 -- British Racing Green/Tan
    2005.5 A4 Avant 6spd -- Quartz/Black -- Sold
    Senior Member Two Rings projectb7avant's Avatar
    Apr 09 2013
    Ilion New York
    I'm running black Zink Hart rotors and akebono pads. No issues at all
    A4 B7 Quattro Avant 2.0t tip - mild daily build for now (gathering parts)
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    Buy premium centric rotors on rockauto. like $60 each. Cheap rotors will warp quicker since they have a lower carbon content. Stoptech street pads are great as well
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Veteran Member Three Rings swaggerwagon's Avatar
    Sep 28 2012
    NC
    Akebono Euro Ceramics are good ones...That's what I'm rolling on
    B8.5 3.0T/ B5.5 1.8T
    Oct 31 2011
    B8.5 S4, B9.5 SQ5, MK4 Jetta
    Redmond, WA
    Centric high carbon rotors + Stoptech pads. Im pleased with the setup so far!
    "if I wanted magic phallus shaped objects that didn't make me go any faster, I would just hit the gay club downtown, no need to spend $400." - Mec
    S4 Build
    Dec 04 2011
    Kansas City, KS
    Quote Originally Posted by AKO View Post
    X2, exactly what im running.
    Veteran Member Three Rings audihere06's Avatar
    Nov 11 2013
    Charlotte NC
    I am about to do Akebono pads with Meyle coated rotors. Total from ECS is $400 for all 4. Akebono has a harder initial bite and can withstand the heat of a track day as well. Brakes are not an area you want to skimp on. If you are changing the material of the pads you need to replace the rotors. If you drive hard and want high performance pads, get a good set of rotors to match.
    Veteran Member Three Rings mcbuck's Avatar
    Mar 21 2010
    '19 Jeep Wrangler Unlimited Rubicon, '16 Grand Cherokee, '12 328 cab
    Charlotte-ish
    Just curious if anyone has used the powerstop rotors and pads - http://www.rockauto.com/catalog/more...849&cc=1432022
    RockAuto has the kit for 315
    Looking at these, stainless lines and a good fluid flush
    BUCK
    2011 A4 quattro, 2.0T, A/T, Deep Sea Blue Pearl (my son's car, but guess who gets to work on it?)
    GONE 2013 RS5 Daytona Grey Pearl, X-pipe, 20% tint, Arc Audio/Alpine, interior/backup LED, 034 RSB, H&R sport, V-FF 103, 285/30 DWS06, Girodisc, Hawk
    GONE - B7 A4 quattro, 2.0T, 6MT, 250K....dropped, tuned, and everything else
    Nov 11 2013
    Charlotte NC
    I just installed akebonos with meyle rotors and the total from ecs was $360 +shipping. Also I flushed the fluid. So far the akebonos feel amazingly smooth, they are exactly what you want on a luxury car but they also are made for high performance. No dust that I have seen yet which is great because titanium wheels are a pain in the ass to keep clean with oem pads. Be sure to check the back side of the rotors because they are usually far worse. The meyle rotors are top quality, I am pretty sure they make the drilled and slotted rotors for ecs so they have the geomet coating. While breaking my new setup in the other day i was trying to make them fade and couldn't.
    May 20 2014
    e92
    Quote Originally Posted by mcbuck View Post
    Don't know about the rotors but powerstop (ceramic) pads are junk. I threw them away after a month in my other car. No bite and no feel at all.
