Results 1 to 13 of 13
    Feb 18 2008
    MK4 Single 6speed
    Earth
    Passenger window rolls back down 2" automatically help
    Stumped on why this is happening just parked the s4 and while I roll up both front windows the passenger side rolls all the way up and then comes back down 2 inches wtf?
    I tried holding the passenger window switch up and then turning off the car immediate but it still rolls back down 2" automatically please advise as I don't want it to rain and then I'm screwed or get the car broken into
    Ps - 06 S4 if that helps
    Jan 29 2010
    north ga
    window regulator is starting to get out-of-whack. It'll likely only get worse from here as that metal cable inside starts to turn into a birdsnest
    The motor is fighting the regulator to get the window up. When it meets enough resistance (like a hand in the window) it will roll back down a bit.
    My advice is to get that window up and leave it there. Once you do, order a new window regulator.
    Established Member Two Rings jimichunga's Avatar
    Sep 13 2012
    SF
    Window regulator design is literally the dumbest thing on this car.
    Sent from my Nexus 7 using Tapatalk
    Feb 18 2008
    MK4 Single 6speed
    Earth
    weird today went back in the car and now it rolls up fine WTF? should i still replace it?
    Veteran Member Four Rings B-Time's Avatar
    May 03 2009
    East
    That's pinch protection kicking in. Only happens to me when it's very hot outside.
    Senior Member Three Rings prfktgntlmn's Avatar
    Sep 24 2011
    2017%20gmc%20canyon%20sle%20
    Atlanta
    Quote Originally Posted by B-Time View Post
    This. Same has happened to me as well. After a couple more tries it stayed up.
    2007 Audi RS4 Phantom Black/Black Premium
    Senior Member Three Rings Tinpusher's Avatar
    Sep 27 2009
    Caledon, ON. Canada
    Sometimes when the window sticks to the rubber on the way up near the top, usually on hot days, mine will do this too. As the window goes up gently push the window outwards to reduce the friction and it should stay up.
    Feb 18 2008
    MK4 Single 6speed
    Earth
    that explains it has been hot and muggy out RI has been 90degrees
    Feb 18 2014
    Arizona
    I've had the same issue before and the same frustrations lol. I did manage to find a way to get it to stop, not sure if i remember correctly but i think the trick is to remove the key completely before it rolls back down. you have to be quick, if you just turn the key to the off position without removing it fast enough then it won't work
    Veteran Member Four Rings quattroism25's Avatar
    Jun 04 2007
    Exiled in Utah
    Happens when it's really hot out. It's especially annoying when I'm trying to roll up the windows as rain starts pouring down. I notice that if I open the driver door as I'm shutting the car off it won't do that. Since all power to the windows shut off once the door is opened
    Daytona Grey S7
    MORO BLUE JHM modded V8 Sold
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Abt AS400 clone, 13 Allroad/RS5 swap
    SoCal, but not the nice part
    I wanted to bump this for having the same issue after replacing driver's and passenger regulators. I also get a short grinding or similar noise when I lower my driver's window completely. Any thoughts on the grinding?
    -Tim
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    My driverside does that, turn the car off then restart and it doesn't do it anymore.
    Nov 30 2014
    Dallas, TX
    My driver's side does it too, try "walking" the window in, roll it up until you're very near the top and then roll it up all the way, this usually works for me. If it doesn't try increasing the gap in the top part of the window sill, like with your keys or just with your fingers, because doing so offsets the pinch protection.
    In the long run, it looks like you may be developing window regulator problems. I've had 4 crap out on me so much so that I've now purchased a back-up window regulator from FCP Euro just in case the one I have on there craps out again. FCP Euro gives a lifetime warranty on all of it's parts and they're pretty reasonably priced I think.
