This isn't going to be some all out build with a crazy budget. Just going to try and make it a clean and effective setup for under 4k total (minus some parts i had already)
Starting with a 2000 audi s4 with 96k miles on it - put the full 3" dp ssac stuff on it. full timing belt kit ,a wide band and greddy boost gauge,lowered and refinished some wheels , no they are not black
Plans
Engine
starting with a BEL -BF block pretty basic rebuild and will be using the rpm rods
-bel engine $400 - received
-Rods $408 - received
-engine parts for rebuild and full timing belt kit - $940 - received
-034 block off and oil return kit -$74 - received
-total $1822
Drive-train
-Stasis built trans - installed
-Fx300 - installed
-Fidanza Flywheel - installed
Total - $Free
Turbo
-BW s360 .91 - $629 - received
-Precision 39mm Waste-gate - $240
-Bov? - $250
-Total - $1119
Manifold/Turbo pipes
- 2.8 manifolds from ebay- $55 - received
- Flanges (034) - $150
-material for up-pipe ,dp and related stuff like gaskets,lines and fittings - $400 - received
-- up-pipe and dp materials ($323 so far used ace stainless supplies and Columbia River Mandrel Bending)
-Total - $605
Fueling
-i have a set of 80lb Siemens already - $free
-walbro 450 - $138 - received
-total - $138
- some machine shop work - chemical clean,hone,check and polish crank,balance rods and hone wrist pin ends.check rod clearances (did on his own - i was going to like crank) and balance full crank assembly - ill be pulling apart heads and gasket matching intake and polishing exhaust runners and re lapping valves) $580 - updated page 2
- inter cooler and pipes - no clue yet .
Treadstone TR10C Intercooler 666HP $274 - received
-total so far is $4180
Parts to sell
-bel engine came with a apr bi-pipe and 2 evolution diverter valves - Hoping for around $400
-rs4 accordian hose -$ 40
-Auto trans $100 ?
-total $590 -$690 -$150 = $440-550
Pics - when i picked it up
Got it into the shop yesterday and started tear down
Hopefully by the end of the year this will be running in the car and not blow up :)
