Results 1 to 21 of 21
    Veteran Member Four Rings BlazinB5's Avatar
    Nov 12 2010
    Stillwater, MN
    Frankenturbo Exhaust Manifold - Any FT guys using the STOCK Exhaust Manifold?
    I've heard that it's a total bitch to install the Frankenturbo exhaust manifold due to the larger runners restricting access to the nuts for tightening. So I was wondering, is the FT manifold really necessary to use with the frankenturbo setup? I personally would rather avoid the trouble of installing if it's really that much of a pain, but if it's worth installing, I'll definitely do it. So for those of you that are running the Frankenturbo F21L, what do you think?
    2001 Allroad 2.7T
    2000 A6 4.2 (parted out)
    2003 A4 1.8T (sold)
    2002 A4 1.8T (sold)
    2001 A4 1.8T (sold)
    2001 A4 2.8 (sold)
    Senior Member Two Rings Lysergik's Avatar
    Jan 23 2014
    Quote Originally Posted by BlazinB5 View Post
    I used the FT manifold, but I didn't install it. The nuts are nearly impossible to access without some special socket or wrench, I am not sure how they were able to get it on.. But after about a year they are still tight, I used nickel alloy nuts with split type washers, not the oval shaped factory copper ones (dealer wanted $4 each plus $1 each for the washers!) and they are holding up great. You don't want to reuse your original nuts and washers.
    And yes, it is worth installing.
    F21 // 550cc // Motoza Tuned // 034 HFC // Tectonics Cat-Back // ER FMIC // ER Custom TIP // Red Tops // Forge 007 // Bosch 040
    Veteran Member Four Rings Knives1010's Avatar
    Mar 17 2014
    2006 Dodge Charger SE, 96 K2500 Suburban
    Tacoma, Wa
    I don't have an FT so take my statement lightly but I've read several times that you actually get a better spool with an OEM manifold, but I don't know what kind of ill affects are associated with that.
    Oscar "The Grouch": Is now dead thanks to a drunk driver RIP
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Quote Originally Posted by Knives1010 View Post
    Smaller runners = quicker spool but loss of top end flow.
    2019 SQ5 Prestige
    Veteran Member Four Rings DiertyEuroSpec's Avatar
    Aug 21 2009
    Fairfield County, CT
    I've always heard FT owners recommending going with the FT manifold, also I believe it is ceramic coated?? Could be wrong but that would reduce engine bay temps which would be a godsend! Just make sure you borrow a wrench or make your own creation as it is a VERY tight install.
    2003 A4 1.8T Quattro | 18" BBS CH | KW V3 | FT F21 Mixed Flow | MOTOZA | RA4 Stage 1 w/SMFW | Milltek | Uni HFC/3'' DP Combo | 3'' TIP w/MAF | 550cc | TR1.8 FMIC | USP F/R | H-Sport F/R Sway | APR Snub | RS4 Motor Mounts | Stern Trans Mount | Skid Plate | Solid Tie Rod Ends | Short Shifter | Euro Shift Knob | VMR Boost Gauge | S4 F/R Brakes | Tyrolsport Stiffening Kit | ECS S.S. Lines | Hawk HPS Pads | 034 PCV
    Nov 12 2010
    Stillwater, MN
    Quote Originally Posted by Lysergik View Post
    Yea, I'm going to need locking nuts of some sort, whether they be copper or nickel alloy, and definitely no reusing of anything
    the main thing i'm after is the lower EGT's, especially with the ceramic coating that i'll have put on it. it just doesn't look that fun to install.
    Quote Originally Posted by texasboy21 View Post
    this
    Quote Originally Posted by DiertyEuroSpec View Post
    ceramic coating is an option, but yea i'll be going with that option for sure. the test pipe is also supposed to reduce engine bay temps too, so my car is going to be pretty happy soon. a guy from my facebook group (Audi B6 Owners Group) recommended using a swivel socket with medium extension, so that's going to be my first option for getting at those bolts in the tight area.
    2001 Allroad 2.7T
    2003 A4 1.8T (sold)
    2002 A4 1.8T (sold)
    2001 A4 1.8T (sold)
    2001 A4 2.8 (sold)
    Feb 17 2004
    Liberty Hill, TX
    even with 10mm copper nuts (which I recommend), you'll need a ground-down box end wrench with a 90° bend at the head to get at most of the nuts. A swivel-socket, even 1/4" drive, isn't going to get the job done. BTDT
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Senior Member Two Rings 00passat's Avatar
    Jul 31 2012
    2005 Gmc sierra 2500hd 6.6 dirtymax
    Lancaster,ca
    I installed the frankenturbo manifold using the stock 12 or 13mm nuts and washers , No leaks 2 years later. If I recall correctly I used a 1/4 swivel socket and a wrench , took around 20-30mins to get it on and tighten it up.
    2014 S4 Dsg B&O , Sports Diff , Audi Side Assist, Carbon fiber Trim, Valentine One Hardwired ,Ecs tuning silicone inlet,Supercharger badges, 183mm fluidampr, epl dp , aem water meth, jhm test pipes, jhm high flow catted downpipes.
    Veteran Member Three Rings vjborelli's Avatar
    Apr 18 2012
    Boston, MA
    I just installed my F21L and manifold on Sunday. I used a regular 12mm wrench. To make things a little quicker with tightening, I used my dremmel to grind down a little bit of each side of the wrench to clear the manifold for a bit more rotation with each pass. Wasn't overly hard, just takes a bit of patience.
    ST Performance Coilover Suspension, 18" VMR 702 Wheels, Unitronic HFC & 3" DP, BKR7EIX plugs, 2.0 TFSI Coil Packs, FrankenTurbo F21L, JE Pistons, IE Rods, ClutchMasters FX350 Clutch, ClutchMasters FW-027-SF Flywheel, Custom Tuning
    Nov 12 2010
    Stillwater, MN
    Quote Originally Posted by Matt Devo View Post
    Damn, well it's not too hard to get make that 90 degree bend is it? It's interesting that frankenturbo wouldn't provide a solution for this.
    Quote Originally Posted by 00passat View Post
    It seems like it's hit and miss for some people. They must've done some minor changes to the manifold over time.
    Quote Originally Posted by vjborelli View Post
    Awesome, thanks for the pic. Did you use the provided studs/bolts that came with the kit? I'm guessing that the only thing I need to order outside of the kit (hardware wise) is the copper locking nuts?
    2001 Allroad 2.7T
    2003 A4 1.8T (sold)
    2002 A4 1.8T (sold)
    2001 A4 1.8T (sold)
    2001 A4 2.8 (sold)
    Apr 18 2012
    Boston, MA
    I used the 12mm copper nuts that ECS lists for $0.99 except for the four corner nuts that are 13mm copper nuts. I used the OEM washers from my stock manifold. One thing I will recommend, is to install, first as you are sliding the manifold onto the studs, the washer/nut on the manifold stud that sits right behind the rear turbo bolt mount (top row, third from the right IIRC). Otherwise you won't be able to get the nut onto the stud because of very low clearance.
    As for the Turbo bolts, I'm not sure what comes with the kit. I bought this F21L from a friend that had it on the car for about 500 miles and totaled the car. My turbo is held in by the stuff I removed from his set. They are cryo treated studs with an unknown type of nut.
    Sent from my Nexus 5 using Tapatalk
    Nov 12 2010
    Stillwater, MN
    Sweet, thanks for the heads up. Any little piece of advice will matter once I order up. I've been real busy with school, so I haven't had the time to pull the trigger, yet
    2001 Allroad 2.7T
    2003 A4 1.8T (sold)
    2002 A4 1.8T (sold)
    2001 A4 1.8T (sold)
    2001 A4 2.8 (sold)
    Senior Member Two Rings tomsgtr's Avatar
    Aug 06 2013
    San Jose, CA
    B8.5 A4 BOSS500 , B8.5 S4 DP+
    Aug 26 2005
    I don't own a frankenturbo setup but I play one on TV.....:>/
    The stock OE manifold will work better on the street. The downside is slightly reduced flow capacity on the top end. Unless you drive your car at 5000> RPM most of the time, the slightly reduced flow capacity at high RPMs is a non issue as practical matter. Alternatively, the BEX stock manifold flows a little better on the top end compared to the AMB stock OE manifold, without being a pain to install or remove.
    Vorsprung durch Technik
    Registered User Four Rings Doug@FrankenTurbo's Avatar
    Oct 19 2009
    Gary Fisher Sugar 2+, Trek HiFi 29er
    Portlandish
    Actually, the downsides are the dangerously high exhaust gas temperatures we saw in product development when testing on the stock manifold. The stock manifold is NOT appropriate for use at the power levels being run with our turbochargers. This is why we make our difficult-to-install exhaust manifold a mandatory part of the turbo kit.
    It's also worth pointing out that we're aware of increasing competitors coming onto the market with low-priced "bare" hybrid turbos. On a price basis they're cheaper because they don't include a proper manifold -- or even an inlet pipe to fit their turbos. Well, none of those products takes into account the damaging effects of EGTs above your engines' rated temperatures. We do. That's why we have worked to develop a complete hardware solution, and have spent years since that time building tuning partnerships that will ensure a final product that is fast & fun, while reliable and safe.
    So: PLEASE install the manifold you bought with your turbo. We wouldn't require it if we didn't believe so strongly about its purpose.
    Anyone with questions is welcome to contact us.
    Thx
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    My suggestion you won't like. Get a quality turbo. I've installed a few b6 frankenturbo kits. The manifold is the worst thing I've ever seen. I've seen $60 ebay manifolds that look higher quality. Its a total PITA to get around the runners and tighten all the nuts. It can be done, but then again your turbo will probably blow within 10k miles if you are pushing it and you'll have to pull it off, so why not just get a good setup that will be on there for the lifetime of the car?
    Correct, you will get faster spool out of a manifold with less volume, but you've also got to take into consideration EGT's. Doug says they saw over the top EGT's, could have also been from fueling, honestly it doesn't look like the design on the manifold had much consideration, just an overinflation of the original manifold, similar to what they do with their compressor charts.
    You can get it ceramic coated, pretty sure it comes bare.
    Aug 26 2005
    Quote Originally Posted by Doug@FrankenTurbo View Post
    Thx
    The excessive temps experienced in product development needs qualification. Specifically, what RPM and load point did the exhaust temps exceed the acceptable maximum with the OE manifold? Was that development done on a street mule or a test cell dyno? As you know, EGT depends on several variables that are interdependent, not in order of importance, like air mass flow rate, boost pressure/pressure ratio, ignition timing advance angle, Air/fuel ratio or Lambda, valve timing and lift, specific load, IATs and other factors. The OE manifold will provide a fatter torque curve on the lower end of the rev range most useful on the street, and the peak EGTs occurring are the result of the tune implemented with a certain exhaust manifold, will be different to the tuning parameters used with a larger exhaust manifold runner flow cross section/mass flow capacity. Of course, the tune needs to be appropriate for the hardware installed with the associated torque achievement target at the RPM load point desired. Regardless, the informative comments you posted provides important information and is helpful here.
    Established Member Two Rings volkswagensRus's Avatar
    Nov 19 2015
    Buffalo, NY
    Thx
    So you say the stock exhaust manifold is not good for modded 1.8t's, but what about the stock exhaust? If I'm reading this properly then stock exhaust + good downpipe + good tubular exhaust manifold should be fine?
    2001 Audi A4 Hibiscus Red Pearl Metallic , quattro, 5spd, Symphony stereo, winter package, 3" 034 catless DP, 2.2" exhaust, white snub nose mount.
    For Sale: 1x oval Borla muffler + piping. 1x rectangular Borla muffler + piping. 1x B5 A4 cat+o2 sensor + wiring.
    FOR SALE: 2 catalytic convertors (one w/ both o2 sensors), Audi B5-a4 cat-back exhaust Borla muffler+resonater
    Aug 21 2009
    Iam running my OE manifold becuase it makes install 10X easier while figureing out this oil leak that Ive had since install of the test F21l mixed flow. Ive went through all fittings etc now just waiting to gave something to run while it goes off to doug's tech for diagnosis
    Sent from my LGL33L using Tapatalk
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    I( have been running the F21L hybrid turbo kit for almost a year now. I'm totally satisfied with the kit. With the right tools I spent no more than an hour installing the FT exhaust manifold. At the same time I installed the kit I added a 034 high flow cat. In the past six months I replaced the OEM downpipe with a TT 2.5 downpipe. From the downpipe back I have a Borla that has been on for years.
    Been a lot of fun
    Senior Member Two Rings Rus_ninja's Avatar
    Nov 30 2013
    Was not too hard to install, do it right the first time.
