Results 1 to 14 of 14
    Aug 29 2014
    Atlanta GA
    Question Any tips on what to look for when buying a b6?
    I'm in the market for a audi a4 b6 and since buying cars is not my expertise i need some guidance. I have found a couple of B6's in my price range(4-5k) ,but i have been reluctant to call because they seem like to good of a deal.Any way if you guys can give me some tips on what to look for and what to avoid it would be most appreciated!(btw i want a 5 or 6 speed manual )
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    4-5k certainly isn't too good of a deal, IMO. I almost bought an '03 1.8 5MT with new clutch, timing belt etc... and 129,000 miles for $2,500 last week. Good deals are out there, but ~ $4,000 seems to be about average, at least around here.
    Make sure timing belt service was done, and see if the car has been well maintained in general. Past maintenance is key in how reliable the car will be for you in the future, and thus I would avoid cars that the owners know little about, service-wise. Other than that, the 1.8T is pretty reliable and if anything goes wrong it is pretty cheap to fix compared to other engines.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Mar 05 2013
    CA
    Quote Originally Posted by AdrianM18 View Post
    Veteran Member Four Rings forevraudi's Avatar
    Sep 01 2008
    San Diego, CA
    Avoid CVT (continually variable transmission). If you go for an automatic, make sure its a quattro so it won't have a CVT. my 2 cents
    edit: just read you want a manual. well, still. avoid CVT!
    Senior Member Two Rings Lysergik's Avatar
    Jan 23 2014
    Buy from a private seller only, no used car lots!
    Pick one that has the lowest miles, least cosmetic interior/exterior issues, e.g. check for broken/missing, scratched, dented pieces and parts, etc. these little things are expensive to replace and will become an eyesore after a while.
    Find one completely stock, this is the MOST important part. No aftermarket CD players, speakers, gauges, body kits, or headlights (unless of course this is what you're after). You want one completely unmolested. Especially when it comes to wiring. These cars have become very affordable now days. The kids are getting ahold of them and filling them up with aftermarket Chinese garbage from Walmart and Autozone. These once $35k + cars are being hacked up with backyard mechanic skills for what looks cool. Poor electrical connectors and connections, this causes resistance in the wiring and potentially numerous other issues which is a nightmare to track down. Leaving out bolts because they are hard to reach or put back in, which is just lazy, and may cause vibrations and rattles throughout the car and you'll never know what bolts/screws are missing.
    Also, you cant always trust receipts. If you plan on keeping the car for a long time, do the timing belt, it is the most crucial maintenance, regardless if someone tells you it has been done already, it will provide you with piece of mind. However, I am fortunate to know a mechanic that owns a shop who installed my timing belt kit for $300, even though the person I bought it from said he did it already. Turns out he was telling the truth, regardless I still feel better it was redone with the parts I wanted to use, metal propeller water pump, Kevlar belt, and genuine Audi tensioner.
    F21 // 550cc // Motoza Tuned // 034 HFC // Tectonics Cat-Back // ER FMIC // ER Custom TIP // Red Tops // Forge 007 // Bosch 040
    Mar 02 2014
    Tiptronic for auto, or go 6 speed manual. 1.8T are most liked but if you're not planning to upgrade the turbo at any time then I would be careful. Oil seals tend to go bad on the stock turbos at around 100k miles and then you have real problems. A 3.0 V6 will give you less liabilities but lacks the performance and room for mods/upgrades the 1.8T has so do your research to figure out what you want to do. Also make sure to find out the last time the timing belt was changed.
    I would also add the B6 is an aging model these days and unless you're buying one with brand new everything, be prepared for those wear and tear replacements. For example the coolant flange loves to pop on these cars (blame Audi for making vital components out of cheap plastic) and the typical Audi/VW electrical issues. Best of luck.
    Veteran Member Four Rings DiertyEuroSpec's Avatar
    Aug 21 2009
    Fairfield County, CT
    If you fell comfortable paying a high price for one with a solid maintenance history PM me
    But all kidding aside deff get one that has maintenance history that can be confirmed, the farther back the better. Otherwise be ready to pull out the pocket book for all the repairs that have gone by the wayside.
    2003 A4 1.8T Quattro | 18" BBS CH | KW V3 | FT F21 Mixed Flow | MOTOZA | RA4 Stage 1 w/SMFW | Milltek | Uni HFC/3'' DP Combo | 3'' TIP w/MAF | 550cc | TR1.8 FMIC | USP F/R | H-Sport F/R Sway | APR Snub | RS4 Motor Mounts | Stern Trans Mount | Skid Plate | Solid Tie Rod Ends | Short Shifter | Euro Shift Knob | VMR Boost Gauge | S4 F/R Brakes | Tyrolsport Stiffening Kit | ECS S.S. Lines | Hawk HPS Pads | 034 PCV
    Veteran Member Three Rings RRF985's Avatar
    Apr 12 2014
    Atlanta, GA
    Quote Originally Posted by Lysergik View Post
    Solid advice. This was my mistake. I paid way too much for my car and have had to put too much into it for the price I paid, but I love it.
    2017 VW GTI 6MT Autobahn
    2012 A6 3.0T P+ | Oolong | Black | Black Headliner | Sport | Side Assist | Cold Weather (sold)
    Aug 29 2014
    Atlanta GA
    Thanks guys i will keep looking for the right one, but all the b6's 02-04 seem to have 150k +. I have only found a couple of decent cars that meet my requirements ,but they are ridiculously over priced .Also one more thing i live in the south and rarely get bad weather ,yet i have Quarto as one of my requirements would it be a big deal loosing it ?
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    Brown coolant = skip.
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
    Veteran Member Four Rings Knives1010's Avatar
    Mar 17 2014
    2006 Dodge Charger SE, 96 K2500 Suburban
    Tacoma, Wa
    If you like driving fast through corners I would say yes. Also FWD = So if you like to and then I would advise keeping the quattro as a requirement.
    Oscar "The Grouch": Is now dead thanks to a drunk driver RIP
    Jan 23 2014
    Quattro is Audi's trademark, literally. Without it you'd shorting yourself, as it is one of the main reasons people buy these cars.
    Mar 02 2014
    These are Audis my friend. At time of sale they were over $30k brand new. If you want a nice B6 with good mileage, good maintenance and no immediate problems it's going to take time and some luck. Most B6 A4 owners don't sell cheap otherwise.
    Veteran Member Four Rings PreciseD's Avatar
    Feb 05 2014
    I hope you realize you are buying a $35k plus car and it will require maintenance of that caliber $$$$. This is not a $3-5k car to maintain. If you don't have the money for repairs (and there will be many if you buy a "cheap" high mileage car that some kid "bro'd out") then you better look into something else.
    ----- My EFR 7670 Build Thread ----- "The thing about quotes on the internet is you can not confirm their validity" - Abraham Lincoln -----
