@walky dont get me wrong I love the hell out of my baby but when it's between her and me loosing my job because i'm calling out every week to replace a sensor, its kinda outta my hands. So i've been looking at imprezas, vw gti, focus/fista st, or an A3, but idk it will probably have the same thing, i hear them electronics are like the audi curse. What do yall think of the line up? maybe i missed something or is it worth just keep on throwing money at my a4 b6.
@Mister I have gotten a scan forgot to get it emailed to my self going to put it up tomorrow. I had like a hundred codes come up, probably because it hasn't been scanned in years. as for the reset i meant that thing you can do with your key where you turn it to the second position twice and start on the third.
@vinny Why do you say that? I mean yeah the leather nice interior, the devilishly sexy body, and probably one of the best if not the best community inst really going to be matched but as a compensation you get better mpg due to the boxer engine, best awd, and slight off-road/rally capabilities.
And here's an update, I read a trick somewhere online, that with a half turn of the key i can move he shifter, move it right between the neutral and drive start it up and let it drop into drive. That worked, i took it into TIP and drove steady 60 and the way home, from time to time the car would downshift to 4th, for like no reason, quite often actually, about 30-40 times in 20 mile drive. later as i was messing with fuses i discovered that a) no matter what i do the "put your foot on the break" light is not lighting up at all, and b) if i take the fuse number 31 out the shifter works again. the fuse num 31 is the "Reversing lights, gear lever gate, el, mirror" idk what that means, but hopefully one of you might'ev heard of it. So doing that let me do driving in d/r/s/TIP without much problems. Sometimes as i would be driving slowly all of the lights (p/r/n/d/s) on the dash would get selected at the same time, so i would just restart the engine and everything would be fine again. Thanks to that, I took the car to a mechanic that I found thanks to Audizine, (once again you ppl prove how awesome you are) he scanned the codes and got like a huge list of stuff, the break light sensor, the solenoid and i think even the pcu gave some sort of errors among a huge list of other stuff. And she has only 82,xxx miles on it. Now he said that this could be due to the drained battery, that was totally drained for some unknown reason the morning that the problem started but either way the plan of attack would look something like replace the break light sensor, if that dont help then the solenoid, and then the pcu and so on. Now that's somewhere between 200-2000 in repairs. So my thought's are instead of possibly investing one forth of the car's value into repairs that might fix or might not fix the issue, that i cry myself to sleep, say goodbye to my beauty, and part ways.
So idk how about newer Audi platforms, maybe the b7/8 has those problems fixed but i havent heard anything like that? I know that just like women, there isn't a car out there that wont give you headaches every now and than, so I'm open to suggestions.
