Page 1 of 29 12311 ... LastLast
Results 1 to 40 of 1158
    Sep 14 2006
    OEM Q5 Brembo Brake Upgrade Review
    I've been getting quite a few PM's asking about my OEM BBK upgrade so I thought I'd include some info in this thread.
    I actually purchased these in March, but I barely had a chance to install these because I've been so busy with work, school, new hobby (modding Honda Ruckus') and a baby on the way. I don't track the car, but I do take spirited drives through canyons so I wanted something that not only looks great, but also performs well. If these calipers are good enough for a heavy Q5 3.0T Diesel’s that is towing a few tons, it's good enough for my avant.
    Also, I looked into the TTRS brakes already and unfortunately I was told that they wouldn't bolt onto the B8 platform. Then I looked at the RS5 brake setup, but it was too pricey for what I wanted.
    Pros:
    *Rotor size- 345mm vs. our stock 320mm
    *Lightweight- Not only are the larger caliper much lighter than our small stock calipers, the larger rotors are lighter than the stock rotors too.
    *Fixed 4 piston vs. our stock floating single piston
    *Cooling capabilities- I drove my car as hard as I could today and I never experienced brake fade like I did on my stock setup. Probably due to being 2 piece and drilled/slotted.
    *Changing brake pads takes less than 5 minutes after removing the wheel (Not kidding)
    *They look amazing
    Cons:
    *none
    So after taking it for a long hard drive, I'm really happy with the upgrade. You don't really notice you have a BBK until you really push it, and the best part is stopping hard over and over again without losing any confidence.
    Parts:
    Calipers: Cheapest place I found were Bernardi parts and ECS tuning
    8R0615107E
    8R0615108E
    Rotors:
    Lightweight 2 piece ECS drilled/slotted rotors
    http://www.ecstuning.com/Audi-Q5--3....ors/ES2602983/
    Brake Fluid:
    Pentosin Super DOT 4 Brake Fluid
    Brake Pads:
    Stoptech posi-quiet ceramics
    Paint:
    1 can of hi-temp primer
    1 can of Rustoleum key lime pain
    1 can of hi-temp clear coat
    Brembo decals are from eBay
    Before:
    After:
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    Veteran Member Three Rings TheHeiko's Avatar
    May 24 2012
    I can attest these look amazing. I saw them in person last weekend. The only problem is that I now want to do the same mod but just changed out my front brake pads and rotors. (Thanks Thomas for the rotors and Jaysen for the no-5-minute front pad/rotor change.)
    Veteran Member Four Rings ed@mtl's Avatar
    Mar 19 2004
    Montreal (that's in Canada)
    nice. where did you get the brake pads from?
    '17 S3 Mod: JB4 - Past cars: '14 Allroad - '10 Q5 3.2 - '07 A4 Avant 2.0T - '98 A4 2.8
    Sep 14 2006
    Quote Originally Posted by TheHeiko View Post
    Haha no prob. Can't wait to see your avant lowered!
    Quote Originally Posted by ed@mtl View Post
    Car part kings. I think they were ~$40
    http://www.carpartkings.com/catalog/...y/1/id/657251/
    Last edited by TCHUN003; 08-30-2014 at 05:33 AM. Reason: pads are from car part kings, not parts geek
    -Thomas
    Current: /S3
    Registered User Four Rings Need4Speed's Avatar
    Jul 25 2013
    Glendale/CA
    Good Review and they look good on the car as well.
    Apr 22 2014
    2018 Q5, 2018 X1
    Sacramento
    Man those look good! Nice write up and pics, sounds like a great mod for the price considering the full BBK costs 2-3 times as much.
    2018 Q5 Tech Premium Plus
    2011 A4 JHM K04-R : JH MOTORSPORTS TUNED : CTS : 034 : ECS TUNING : SNOW PERFORMANCE
    Veteran Member Four Rings Frinkferta's Avatar
    Aug 27 2012
    Earth
    Looks amazing! I am going to do this mod when my rotors need replacing!....So a very long time from now haha
    Feb 13 2004
    Silicon Valley, CA
    Nice I was planning on this for the fall. Did you buy the ECS kit that comes with calipers, rotors, ss lines, but no pads, or did you buy it all separate? Looks like separate, but just wanted to confirm.
    Kevin - Moderator, Audizine
    Veteran Member Four Rings kwbdc's Avatar
    Mar 29 2012
    2006 Mazdaspeed6 RIP
    Seattle/WA/United States
    Nice set up! I'm putting the RS4 brakes on the rear painted to match the front Brembos. I'm wondering if I should put Brembo decals on the rear or leave them without since i'm not sure if RS4 are brembo or not.
    2012 Audi A4 Premium +MT, Quattro, Xpel bra, SLine BBS CI-R 20x8.5 ET 32
    Mods: APR HFC/DP, APR K04, Bilstein PSS10 Coilovers, Okada Coilpacks, AWE Boost Gauge, Eurocode SSK, OSIR CF Spoiler, APR Carbonio Intake, AWE Exhaust, OSIR CF valence, ÜSS Adjustable Stabilizer set, Alu Kreuz, RS4 grille, Fluidampr,Apikol differential, folding mirrors,Brembo GT BBK, Deval CF splitter,ECS skid plate, RS4 rear brakes, Snow performance Stage3
    Sep 14 2006
    Thanks guys and Kevin, I bought everything separately. I didn't go with SS lines after doing some research.
    -Thomas
    Current: /S3
    Senior Member Three Rings Mina08's Avatar
    Apr 30 2014
    Classic Mini, and lots of bikes
    Sweden
    Sounds like a great set up.
    2011 2.0 TFSI S-Line Avant/S-Tronic/Quattro/Quartz Grey/19"OEM RS5 Rotors/
    CFBSWheel/VCDS+Mods/XCL+Mirracast/LED/R8Coils/3.0FMIC/K&NFilters
    Aug 03 2013
    Renton, wa
    Wow those look great, I've been patiently waiting for this post from you ever since I first heard about this kit. When it comes time for brake replacement, I know what I'll be going with
    '22 X3M - Stock...for now
    '14 S4 P+ DSG 034 Stage 2+ ECU/TCU 57.7/190, AWE Touring, MercRacing, AWE S-Flo, Stoptech STR-60 - Gone but not forgotten
    '14 A4 S-Line Sport Package 6MT - Totaled
    '12 Tiguan SEL 4MO.
    '03 Mustang Cobra "Stock"
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    Great work! Finally!
    Can you post up some pics without the effects? Just nice nice clean shots. No Bokeh no antique.
    Again, great work! I have been waiting for this day.
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    Any idea how this would work on a B7?
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Quote Originally Posted by vvenom800tt View Post
    B7 upright/hub is different. I'd suggest the 350mm 18Z/Cayenne 6-piston upgrade, it performs better, bolts up like stock and is cheaper than this.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Dec 04 2011
    Kansas City, KS
    Quote Originally Posted by LINDW4LL View Post
    Im aware of the Cayenne upgrade, but if this would be a better option with rotor selection then it might be more appealing.
    But the Q5 caliper will not bolt up to the B7 spindle at all?
    Dec 10 2011
    CLT | MKE
    No doubt this is a fantastic upgrade over stock, but if you're going through the effort to upgrade, why not go with the 380x36mm SQ5 setup? Pricing is almost exactly the same. Only downside is heavier rotors, but obvously the braking will be far superior.
    Rotors: http://www.ecstuning.com/Audi-SQ5--3...ors/ES2162817/
    Calipers: http://www.ecstuning.com/Audi-SQ5--3...aking/Caliper/
    -Hayden
    Dec 10 2011
    CLT | MKE
    Just kidding I was wrong, you just use the B7 rotor. PM incoming.
    -Hayden
    Dec 04 2011
    Kansas City, KS
    I though i had read somewhere that the B8 S4 caliper bolts right up, so if this bolts up to the B8 S4 then it should bolt up to the B7. But the caliper compatible with the smaller rotor from the B7?
    Dec 10 2011
    CLT | MKE
    The B7 S4 rotor is 345mm, same as B8, just a different offset. B7 S4 rotors + Q5 calipers should work perfectly.
    -Hayden
    Dec 04 2011
    Kansas City, KS
    Thank you for the information. Appreciate it.
    Veteran Member Four Rings jbradle7's Avatar
    Jan 09 2010
    GX460; MK7.5 GTI; WK2 Grand Cherokee; 73 Triumph TR5T
    St. Louis
    Nice work Thomas!
    Jan 10 2012
    Republic of Boulder
    Thanks for your review and all the "spoon-fed" information you provided. I'm super glad you're happy with this upgrade and definitely going to consider this when my brakes need replacing. They look badass!
    Good luck with all of your obligations and hobbies, and congratulations on your upcoming baby!
    PREVIOUS:
    1991 Audi 200TQ Avant
    2001 Audi S4 Avant
    2009 Audi A4 Avant (click)
    2014 Audi allroad
    Veteran Member Four Rings poweredbyaudi7's Avatar
    Dec 19 2006
    996TT
    San Antonio, TX
    Digging it!
    '14 A4 Q6MT / APR KO4 / AWE / HRE / H&R / 034 Motorsports / P3cars / JHM
    Sep 14 2006
    BTW guys, if you want to do the upgrade, you need 2013+ Q5 3.0T calipers. MY 2012 and earlier had different brakes. Also, 2013 2.0T's use 320mm rotors, so again, you'll NEED the 2013+ 3.0T ones.
    Acutually, I don't think the SQ5 setup would be superior. I looked at that option for a while when I was purchasing too, but the only real advantage was the size, but that was also a drawback. The rotors/calipers are actually heavier (defeats the purpose of a BBK) and there aren't many rotor options. These Q5 brembo's paired with the ecs 2piece rotors dissipate heat really well and the stopping power makes me forget that my avant is so heavy. The SQ5 calipers also look bigger, but that's only to accommodate the larger rotors. Lastly, the brake pad changes aren't nearly as easy as the Q5 Brembo's...these are all some of the reasons I chose this setup over the SQ5.
    BTW here's a better list of rotor options on the Q5 3.0T:
    ECS 2 piece rotors:
    JHM 2 piece slotted:
    http://jhmotorsports.com/shop/catalo...=21_56_273_307
    ECS drilled slotted Geomet $190 for a pair:
    http://www.ecstuning.com/Audi-Q5--3....ors/ES2189931/
    Oh and LINDW4LL, I had no idea that B8 calipers were interchangeable with the B7's. That's good info to know for the future!
    A4 Centaur, I'll snap regular pics in the afternoon
    -Thomas
    Current: /S3
    May 28 2013
    IL
    Do you think it's possible to fit 17 inch wheels over these?
    May 01 2011
    Ottawa, ON, Canada
    They fit over my 17" aftermarket (reps). I believe the wheels are 17x7.5 38et
    http://i1028.photobucket.com/albums/...psfd87a62e.jpg
    2010 A4 2.0TFSI Premium+ S-Line with: APR S3 K04, APR TBE, Q5 (Brembo) front/S5 rear calipers & rotors, APS+, Podi Boost Gauge, FMIC (3.0TDI), Hill Hold Assist, Auto High-Beam Assist, AFS Headlight, TTRS flat-bottom multi-function steering wheel, GFB DV+, Bilstein B8 Struts/Shocks, Alu Kreuz, Apikol diff mount, folding exterior mirrors
    Sep 14 2006
    Quote Originally Posted by G2toG3 View Post
    Just depends on the design of the wheel. They didn't fit over my 18" enkei racing wheels so I had to get rid of those.
    -Thomas
    Current: /S3
    Dec 19 2006
    996TT
    San Antonio, TX
    What wheels are you running now? Was it the wheel size that was the issue or the offset?
    Mar 05 2009
    Earth
    Great upgrade. Speaking from experience I can agree that the Q5 3.0T brakes are pretty darn goods for stockers on a CUV/SUV. It would be an excellent upgrade for the ~500lbs lighter A4.
    However, regarding your comment about using them on a 2 tonne trailer (BTW, the Q5 is capable up much more ), stopping that much weight without excellent electric trailer brakes would be insane and cook them (the Q5 brakes) in an instant....they aren't that good :)
    Veteran Member Four Rings pwdrskr's Avatar
    Aug 21 2010
    Carlsbad, CA
    OP: What are your plans for th rears?
    '19RS5 Coupe: Prestige, Daytona Grey, Blk Interior, Carbon Pkg, Driver Pkgs, APR+/TCU/Intake, CETE AVC, ABT Coils, Vossen EVO-1R 20x10et20
    '22RS6: Glacier White, Blk/Gray Interior, Blk Optics, Exec, Driver Pkgs, Sport Exhaust, APR+, Akrapovič Exhaust, CETE AVC/ASC, Vossen GNS-1 22x10.5 et7, Stealth wrapped Piano Black Interior
    Jan 10 2012
    Republic of Boulder
    Quote Originally Posted by pwdrskr View Post
    You're probably going to leave them stock, right? I've got Porsche big reds on my '91 200 TQA and it stops on a dime with no fidgeting, even through the twisties.
    PREVIOUS:
    2001 Audi S4 Avant
    2014 Audi allroad
    Sep 14 2006
    Quote Originally Posted by poweredbyaudi7 View Post
    They were 18x9.5 et40. It was the thickness of the wheel face and the wheel design.
    I'm going to leave them stock.
    A4 Centaur here you go:
    -Thomas
    Current: /S3
    Jun 05 2009
    Scottsdale Arizona
    Friggen SWEET!!! Love the color!
    Veteran Member Four Rings dennisA4's Avatar
    Jan 13 2006
    Houston
    Thanks very much for this review!
    My next two mods are this and exhaust.
    Just been trying to figure out which to do first.
    Since Awe still doesn't have a non-oem s-line valance option, I may do this first.
    2014 A4 Prestige Quattro Tip
    Glacier White | S-Line Interior | Sport Package | Window Shades | 35% FormulaOne Tint | V1 Hardwired
    S4 Aluminum Pedals | 19x9.5 Avante Garde M590 | KW V1 Coilovers | AWE Dual Exhaust | ECS Luft-Technik Intake | Unitronic Stage 1+
    Jan 13 2006
    Houston
    Hey another question for ya...
    Did you install these yourself? If so, how difficult was it? Are there any good tutorials to follow?
    I would assume the hardest part is bleeding the lines.
    Sep 14 2006
    Pretty freaking easy to install. Only PITB was bleeding it because I think I got a little bit of air in the master cyllinder :/
    Ended up getting a motiv power bleeder which I wish I used from the start. I bled passenger rear>driver rear>passenger front>driver front. The brembo's have 2 bleeder valves, bleed the outter valve first, and then the inner. Take the car for a spin and stop on a dime.
    -Thomas
    Current: /S3
    Veteran Member Four Rings KFizz's Avatar
    Dec 27 2009
    Edmonton/Alberta
    I really want to do this
    Kyle
    2014 a4 Allroad /// Ibis, Unpainted Lowers (True AR)
    Veteran Member Three Rings Sedan Guy's Avatar
    Mar 10 2005
    Amani War Bear and a Chocobo
    Orange County, CA
    Thanks for the writeup and great looking setup Tchun003. Added to my want list
    2013 Audi allroad thread | RS5 4.2L V8 conversion by Pacific German
    Instagram: ilevel_audi, ilevel_wagon
    Jan 13 2006
    Houston
    Great, and I just found the ECS how-to video on using that motiv power bleeder.
    Definitely worth the cost for that if it saves hundreds on having someone else do the install.
    And sorry, another question for you!
    What made you decide on those pads?
    Quiet, low dust and good initial bite are my top requirements.
    I don't track the car and we don't have canyons. My car gets it's abuse during my long commutes fighting other a*hole commuters. lol
