Hi all,
As it says in the title my 2.0 TFSI 11 plate has some problems that are a real concern for me.
Firstly, the oil consumption problem.
I'm currently going through 1L of oil every 300/400 miles. I've been looking through the forums and many have said it could be the PCV, stems or replacement Piston rings. I've had the PCV replaced and there are no signs or symptoms of blue smoke, engine drinking the coolant etc there is nothing to suggest anything else other than the PCV, I've booked my car in to the local Audi dealer for an oil consumption test but at £190 just for the test i'm trying to get the problem solved myself before i get my bank account robbed blind by Audi.. Can anyone help and give me some suggestions as to what my next move should be?
Unfortunately my Audi has given me more problems, this time cylinder misfires.
around a week ago i was driving home i put my foot down and felt like the engine was tripping, jumping for a few seconds then ran okay then around 5 miles down the road it went into limp mode and the EPC and engine warning light started flashing (and also sometimes just static) on the dash, i took it to the garage it showed that cylinder 2 misfired, possible electrical/mechanical fault detected, got all the sparks replaced as they were all quite worn and had a little bit of oil on them, got the faults cleared and all seemed good then a couple days later it went back into limp mode and the same fault seemed to have occurred but this time cylinder 3 and 4 misfired and now the car is back into limp mode and the garage seem to be at a loss as to what the problem can be. suggested replacing ignition coils??? and could this be linked to my oil consumption problem?
Any help is appreciated.
Craig
