Results 1 to 27 of 27
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    aftermarket tunes, what timing a/f are you seeing
    i figured since more and more people are joining these forums and there are a couple different tunes out there we should try and have a public post to show what we all see for actual timing while logging via vcds
    epl stage 2
    roc euro intake
    apr exhaust
    93 octane
    18* timing just before redline with no knock/timing pull
    .80 lambda on average
    epl stage 2
    roc euro intake
    awe exhaust
    93 oct 50/50 meth injection tune
    21* timing just before redline, no knock or timing pull
    if you feel anything else should be included please do so , with hardware being equal between cars timing and air fuel should give a good indicator or what tunes make the most power and how aggressive they are.
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Veteran Member Four Rings audistealth's Avatar
    Mar 04 2012
    2012 Audi S4, 2017 Explorer Sport
    Well, this forum loves DA and ambient temperature...
    /// 2012 S4
    RocEuro Intake | AWE/GIAC Stage 2 | 19" Titanium Rotor Wheels 10mm H&R spacers | RS5 BBK & ECS 2pc front/rear wave rotors | Renn RS-51 19x8.5 20.5lbs | JHM LW/HD Pulley | MMI 3G+ rev. G and controls retrofit | vagcom stuff | Jokerz ported coated supercharger | KW V1
    Mid-Atlantic Forum (MD/DC/VA)
    Oct 16 2012
    pa
    Quote Originally Posted by audistealth View Post
    that isnt something that can be logged, we could put iats, but at that point might as well put the full log up
    Mar 04 2012
    Quote Originally Posted by saxon View Post
    DA, there are apps for that. Temperature should be a widget on a remotely modern phone. Or, read it out of the display between the gauges.
    Active Member Four Rings SwankPeRFection's Avatar
    Aug 05 2013
    N/A
    That's a little bit funny because you need current ambient temp to calculate DA, so posting both is really pointless. If people are interested in DA, that's all you need to post and yes, there are free apps for that. I love the one I posted the other day. Press one button and presto. GPS lookup and everything.
    Veteran Member Four Rings skiracerblah's Avatar
    Jan 03 2011
    Evo X MR : 290whp, 313 lbs/torque @ 24psi; Evo IX : 383whp, 383 lbs/torque @ 28psi E85
    San Fernando Valley, CA
    Here's AFR taken at the tailpipe from the Dynapak dyno. 13.5 at WOT pretty lean compared to regular fuel injection courtesy of direct fuel injection... Note, this is bone stock...
    Sorry for newbie questions, this is my 1st Audi
    Current: Phantom Black '2011 S4 S-Tronic Premium Plus, Sports Rear Diff, JL Audio subwoofer upgrade, Milltek Resonated Exhaust
    Old cars:
    Evo X MR-Touring stock, but tuned by RRE: 290whp, 313 lbs/torque @ 24psi 91 octane
    Evo IX tuned by RRE: 383whp, 383 lbs/torque @ 28psi E85 ethanol fuel
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Quote Originally Posted by skiracerblah View Post
    Thats not pretty lean. Thats just a little on the lean side. 14.7:1 is considered perfect a/f ratio for what everyone looks to achieve. So 13.5:1 isn't that bad. Nothing to worry about.
    But if he's running at WOT on that tune with the 02 reading .80 thats a little on the rich side and no issues. I would see if he's still running that when maxing out the rpm in whatever gear he's in at the time and if its still the same at high rpm.
    Veteran Member Four Rings Vogz's Avatar
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Quote Originally Posted by chaos2984 View Post
    14.7:1 isn't "considered" a perfect gasoline air/fuel ratio. Being stoichiometric, it IS a perfect AFR only from a scientific standpoint. It's not an AFR that ANYONE targets when tuning a forced induction vehicle at WOT. Some factory FI engines run AFRs in the 13s at WOT, but none run anywhere near stoich. Aftermarket tuning typically runs richer for an added margin of detonation protection at higher dynamic compression ratios.
    I don't think skiracer was worried about his stock AFR. He was simply explaining the reason it is leaner than one would normally see on an FI vehicle is due to direct injection.
    SOLD - 2011 S4 Sprint Blue 6MT Ti - GIAC Stage 2 - Sachs XTend clutch - AWE exhaust - Bilstein B12 suspension - strat short shifter
    [email protected] 1.85 60' (stock)
    [email protected] 1.74 60' (stage 2 - 93 octane)
    [email protected] 1.71 60' (stage 2 - 104 octane)
    2020 Tesla Model 3 Performance
    2003 Porsche 911 Turbo - SpeedTech, Cobb, Bilstein, H&R and TPC goodies
    11.69@123mph 1.82 60' (RWD on street tires)
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    Quote Originally Posted by Vogz View Post
    This is the first I am hearing of this, do you have a source to back this up? I thought most aftermarket tunes run a bit leaner.
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Jul 08 2010
    tucson
    danbury
    Hence why you see a bit better gas mileage after a tune
    [CENTER]Scott
    2011 S4
    Jul 17 2010
    996 Turbo
    Batavia, IL
    Quote Originally Posted by mr shickadance View Post
    I'm not talking about box tunes for the B8 S4 specifically. I'm talking about aftermarket tuning in general on forced induction vehicles. You increase dynamic compression and you richen the WOT AFR for detonation protection. It's a rule that people that tune cars follow. I followed it tuning my 350Z. There's info all over the tuning section of car forums.
    Also:
    http://aeromotiveinc.com/advanced-ti...fuel-pressure/
    http://www.autospeed.com/cms/article.html?&A=1595
    I've seen zero increase in steady state mileage since I had GIACs software installed FWIW. But that has zero to do with the AFR at WOT. At cruise the ECU is in closed loop mode using the O2 sensors to fine tune AFRs. At WOT the ECU reverts to the fueling map and small corrections are made based on temperature sensors, knock sensors, etc.
    Jan 14 2009
    pasadena md
    ok buddy thats y manifacturers teach taht in their classes that 14.7:1 is what they try to run under normal conditions unless the car had fuel savings capabilities on the hwy or whatnot. But during normal drivng the ecm fuel map is trying to achieve a 14.7:1 ratio.
    Jul 17 2010
    996 Turbo
    Batavia, IL
    What does closed loop "cruising" AFR have to do with WOT AFR? I'll give you a hint, nothing! This thread is about WOT AFRs, not "cruise set at 55" AFR.
    Jan 03 2011
    Here's a tune i had on my Evo in 2007 of bone stock vs. tuned (aftermarket injectors, fuel pump, exhaust, boost controller, 100 octane unleaded)
    If you see the stock AFR, it runs stupid rich hitting the 10's and Evo's are famous for running uber rich at the factory. You'll notice the tuned AFR is slightly higher across the board, especially with the 100 octane where you can get a little more aggressive with AFR's. This is why an Evo responds so positively with tuning. Ya its an Evo, but same principal applies to other cars... IF any car runs 14.7:1 at WOT, your engine will BLOW guaranteed.........
    Old cars:
    Jul 28 2014
    WI
    If your car still has it's cats A/F will be leaner at the tailpipe, best to get your wideband reading before the cats.
    Jun 10 2014
    Texas
    Scott, direct injection changes the game a bit... but Vogz is generally correct.
    Most forced induction non-DI cars' afr are in the 11's at WOT. NA is typically 12's.
    Direct injection allows one a much leaner mixture, but it's still generally in the 12's/13's at wide open. I believe that's where Cobb had my old twin turbo BMW running.
    Jan 14 2009
    pasadena md
    Yea your right it has nothing to do with closed loop but guy was saying he was running really lean and i was just stating he wasnt is all. But yes the ecm has to spray more fuel and sooner before TDC because of engine speed and ignition timing at WOT as it aproaches rev limit.
    Oct 16 2012
    pa
    really.... if the car ran 14.7 at wot it would detonate/blow up
    14.7:1 is stoich, which is really only ideal for emissions
    13.5:1 stock is actually pretty lean for wot, but can be achieved due to the efficiency of Direct injection
    most tuners still believe that 12:1 is an ideal a/f ratio for forced induction
    does anyone log these cars on this forum or just think their cars are perfect and make the hp shown on tuners websites?
    Aug 05 2013
    N/A
    14.7:1 is NOT what you want to achieve at WOT under full load. Not even close. It needs to be richer than that. Traditionally 12:1 was considered about as lean as you'd want to go for forced induction engines and even that was pushing it in some instances. DI has supposedly changed that a bit.
    Aug 05 2013
    N/A
    Ya, in closed loop, not open loop.
    Jan 14 2009
    pasadena md
    Quote Originally Posted by SwankPeRFection View Post
    I never said that 14.7:1 was what you wanted at WOT. I just stated thats what was considered perfect under ideal conditions. But with that 13.5 he got be probably really running around 12.9 with DI apposed to MPFI I over looked that he was under WOT. But yea you want on the rich side because what i stated above
    Oct 16 2012
    pa
    Since I can't post on that forum I'll reply here. Nice to see people have nothing better to do but talk about me :)
    Yes 14.7:1 will absolutely blow your motor at wot. .. Maybe you should research .... :)
    Yes I'm still stoke about flash from home, what other tune out there cab you flash between a standard stage 2 file and a custom meth tune? have you ran faster than 12.7 yet with a superior tune than what I have?
    According to ar my tune is junk yet I've ran faster than most with the apr/giac tunes (and they conpliment you saying you should be able to reach 12.3 in good weather)
    Epl may not have the fastest car out there but in my limited number of runs it seems to be faster than most, we will see what it does in low da this fall
    Mar 04 2012
    Where is that product release, or is it not done? Nothing wrong with holding back for QC, but it did seem like it was close to ready at one point...
    Jan 14 2014
    Bryan/C.S./Houston TX
    @Saxon they know everything............
    Oct 16 2012
    pa
    Not to change subjects, but currently you can do flash from home. Tony is working on a solution to allow port flash from home. The hard part is security so others don't steal his flash/way of flashing. This is the reason that apr/giac have there networks. Unfortunately dealers aren't always reliable and it's inconvenient to the customer.
    If you want a remote/meth/e85 tune it can all be done but you just need to have the first flash done by Tony which I believe he port flashes using his car and doesn't even bench flash at all
    If your looking for cheap, it's not cheap. Pulley can be bought anywhere but the flashing cable is $300 and custom tunes are $500
    Mar 04 2012
    I'll keep my reply to myself, to keep from further derailment. Maybe Tony could have his own thread for his own voice here?
    Oct 16 2012
    pa
    That would be great, last I talked to him he was to busy tuning alpha porsches and heffner twin turbo r8's that the forums aren't a priority
