Results 1 to 15 of 15
    Feb 17 2014
    Pittsburgh, PA
    Relocating the diverter valve
    Hi All. I want to move my diverter valve down lower closer to the inter cooler piping instead of the TIP so its easier to service. I have rhino ramps so it would be easier for me to just have it a bit lower. What I need to figure out is what size hose I need and I will also need an elbow piece so I would need to know what size diameter elbow to get also. I plan to have the diverter valve closer to the T fitting and the elbow piece would go in the TIP. Then all I need is some straight silicone hose to connect the elbow to the diverter. Any info would be awesome.
    Feb 17 2014
    Pittsburgh, PA
    I forgot to mention. I have a 1.8T A4 quattro if that makes any difference.
    Dec 19 2007
    York, PA
    isnt the default position right near the IC piping?
    i have a FMIC...so i cant remember tbh.
    Veteran Member Four Rings ShogunR32's Avatar
    Aug 22 2004
    1" hose for the diverter.
    USP CLUB MEMBER #7
    Previous Audis:Big Turbo 2005 Black Audi A4 USP 6-speed sedan/2008 Blue Audi A4 6 speed sedan/2004 OEM+ Arctic White Audi A4 Avant/2001 Red Audi TT 225Q.
    Current: 2004 BMP Vw R32
    Feb 17 2014
    Pittsburgh, PA
    Mine is mounted in the TIP and a hose is connecting it to the T fitting on the IC piping.
    Feb 17 2014
    Pittsburgh, PA
    Quote Originally Posted by GTRchop88 View Post
    Are you sure?? I thought it would be a metric size?
    Dec 19 2007
    York, PA
    1" = 25mm
    it doesnt matter
    Oct 27 2005
    Central Texas
    This sounds about right when I did my customer front mount. Hose ID is about 1" and for any joints the OD needs to be 1". I would pop it out, or take your stock one, and go to a hardware store and confirm. I used radiator hose.
    Senior Member Two Rings KR_A4's Avatar
    Aug 10 2010
    Toronto, ON
    Why don't you move it above your intake pipe so can service it even easier?
    Currently in the middle of restoration for storage.
    APR II+, Forge TIP, Forge splitter, Miltek non res, AWE intercooler, Boxter Brembo BBK, Koni SS coilovers, 034 F+R upper adj control arms + Density lower control arms + full mounts.
    Veteran Member Four Rings gmudan's Avatar
    May 03 2009
    A4%20B6/B8
    Arizona
    I believe there was a dv relocation kit for 150$ ish.
    Feb 17 2014
    Pittsburgh, PA
    Quote Originally Posted by KR_A4 View Post
    cause I have a diverter valve..not a blow off valve. As much as I would love to hear that woosh sound even louder I'm not willing to drop any cash on a bov just yet.
    Aug 10 2010
    Toronto, ON
    Quote Originally Posted by virgoavant View Post
    I'm running a Forge splitter. Still a diverter valve. Only vents a portion of the recirculated air.
    You can run a standard diverted valve the exact same way.
    I'm just throwing the option out there.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    The splitters vent metered air to the atmosphere, creating a same boost leak, so technically it is (partly) a BOV. It appears the TIP cannot be rotated with the stock airbox.
    2019 SQ5 Prestige
    Aug 26 2005
    The DV is usually moved to be as close as possible to the throttle body. The reason for this is to minimize the delay recirculating boost pressure back up at the closed throttle valve during gear shifts. Another benifit is by recirculating cooled charge air that has passed through the intercooler, so the recirculated charge air released to the compressor inlet is cooled from the intercooler, instead of recirculating hot pre intercooler air into the compressor inlet.
    Vorsprung durch Technik
    Veteran Member Four Rings RENOxDECEPTION's Avatar
    Nov 04 2012
    2000 B5 A4 1.8TQM, 2000 B5 A4 1.8TQM
    Reno
    Sub'd
    2000 Audi A4 B5 1.8TQM AEB/06A
    1998 Audi A4 B5 4.2QM (Thread)
    2000 Audi A4 B5 1.8TQM K24 Turbo, AEB Wideband
