Results 1 to 28 of 28
    Oct 06 2013
    B5 S4 Nogaro Blue 6sp, Mk1 Audi TT Q, R32 Nissian Skyline GTS T
    Australia
    Thermostat change without doing timing belt?
    Hi guys,
    My thermostat must be stuck open as my car is running cold, taking ages to heat up and dropping temp with the heater on etc.
    Is it possible to change it without doing the timing belt? This was done about 8000km ago and I dont want to do it again for a thermostat.
    Any suggestions would be greatly appreciated
    Veteran Member Four Rings erykv1's Avatar
    Jul 01 2014
    'murca
    you will have to remove the belt to get to the waterpump. you dont have to replace the belt if you think its still good.
    May 16 2008
    WA
    This is why its best to take care of those hard to get to items when doing the timing belt, such as the thermostat and water pump. Otherwise, you'll be doing it twice.
    Now if you did, and your new thermostat failed within 8K km then that is some crummy luck.
    Oct 06 2013
    Australia
    Thanks for the reply, by waterpump you mean thermostat housing? The service book has timing belt and waterpump replaced, but not thermostat. Of course at the time Im sure it wasn't an issue
    Oct 06 2013
    Australia
    Quote Originally Posted by getslideways View Post
    Yes it sucks, it was before I bought the car. I would have done it as a preventative measure for sure
    Veteran Member Three Rings Taloras's Avatar
    Jan 19 2011
    PDX
    Quote Originally Posted by crazyazz View Post
    Compare the path of the timing belt below
    with the location of the thermostat and water pump, below (centered)
    They're UNDER the belt. Simultaneous replacement is advised because there's no extra work involved, given you already have to take the timing belt off to get at the thermostat and water pump.
    Also, our cars have a plastic thermostat housing that doesn't last more than a few years. It's HIGHLY recommended to replace it while the thermostat is out, either with a brand-new plastic one or one of the aluminum ones.
    Oct 06 2013
    Australia
    Quote Originally Posted by Taloras View Post
    Thanks mate, I will source an aluminum unit. So I will also need the locking bar if I take the belt off correct?
    Also no possible way to half remove the belt and slip the housing out and back in I take it?
    Jan 19 2011
    PDX
    I mean, you COULD, but considering you'll have to take the thing off anyway and you can get a Continental belt for $30 http://www.rmeuropean.com/Part-Numbe..._1FAEF62B.aspx, you might as well. Really. Seriously. Do it. For the 6-8 hours to take things apart this much and put it back together again, do it.
    You don't NEED the bar, but it's a pain to do it without. I think you can rent it for like $40 from JHM or somewhere.
    Oct 06 2013
    Australia
    thanks for the info, so I dont need a new tensioner etc?
    Jul 01 2014
    'murca
    if youre confident with the parts used on the last timing belt change, you can reuse them. you can definitely time the engine without the bar, but its useful to have for sure. You can always mark the pulleys once they are at TDC with a paint marker.
    Aug 06 2008
    Canadia
    I did, its completely doable.
    crank the engine over by hand while pulling the belt towards you, it will shift about half way off the sprokets, giving you enough room to remove the thermostat housing.
    have fun :)
    the B5 S4 is like the mafia... there is only one way out!
    Oct 06 2013
    Australia
    Quote Originally Posted by MacDaddy View Post
    have fun :)
    Excellent, thanks man
    Oct 27 2011
    TOYS
    Philly Suburbs
    My original plastic thermostat housing has been fine now for 105K. I have heard of people "upgrading" to the metal version, but I rarely hear people complaining about the plastic housing being an issue.
    Veteran Member Three Rings BlkBullitt's Avatar
    Feb 06 2009
    2007 Q7
    Cleveland, OH
    have fun :)
    +1, I've done this as well. It's somewhat of a pain to get the housing in/out, but is very doable.
    2002 Audi S4 Brilliant Black Avant 6MT[/b]
    B5 A4 / S4 Headlight and HID Thread | B5 A4 / S4 Center Console Thread
    Active Member Four Rings
    Nov 12 2013
    '01 S4 Tip '91 200 20VTQA, '01 A6 2.7TA, VW Rabbit GTI truck.
    SanHo, CA
    I've had two plastic housings fail or I guess you could say wear out. I would never do a timing belt job and leave a plastic housing in there no matter the mileage. It's too much of a pain in the ass to replace for the hunnert buck savings.
    Jan 19 2011
    PDX
    Quote Originally Posted by rdcyclist View Post
    Mine was in pretty poor shape when it came out @110k, probably because the PO appears to have sacrificed his soul to the devil (mixed coolants). Even if you're not gonna spend $150 for an aluminum one, at least get a new plastic one for $50.
    ECS has a nice kit with t-stat, housing, and o-ring for $65. http://www.ecstuning.com/ES2771457/
    Oct 06 2013
    Australia
    When did the metal housing appear? My car is a 2000 Euro spec as Im from Australia, could I already have the metal unit?
    Aug 06 2008
    Canadia
    i do't think the B5 S4 ever had a plastic thermostat housing.
    mine is a 2000 (sept 1999 build) and its metal.
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    The plastic housings often time get corroded and start crumbling causing leaks. We're seeing it more and more now that the cars are starting to age. I'd definitely look into a minimum of replacing it with a new plastic one, or the metal one.
    Metal Thermostat Housing
    Oct 06 2013
    Australia
    Forgot to update the thread :P I was able to change the thermostat by cranking the engine with one hand and pulling on the timing belt with the other, I removed it enough to slide the housing past to get at the thermostat
    While I had the front in the service position I replaced my poor looking serpentine belt and installed an apikol snub mount
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    What a pain in the ass.
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    And what a stupid place to put a thermostat haha
    00' Laser red S4 RS6 hybrids e85
    02' Corvette ZO6 383 TT 1012whp 990wtq
    02' Tundra
    SOLD 93' AWD Talon 523whp 486wtq
    Oct 06 2013
    Australia
    I reckon , it was a pain in the ass at least I did the snub and serpentine belt to make it more worth while
    Active Member One Ring pilla's Avatar
    Mar 10 2016
    England, UK
    Thanks for the confirmation this can be done without removing the timing belt and thanks for the picture. Im going to attempt a t stat change myself now.
    98 B5 S4 Nogaro
    Veteran Member Four Rings m_haiser's Avatar
    Apr 24 2011
    2012 A6 Prestige, 1998 Jeep Cherokee XJ
    Central Willamette Valley
    totally possible, did it on a 2.8 without removing the timing belt
    It's to the point where all the problems just run together in a spider web of disappointment and mush.
    -CELison
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    There is no point in doing one
    without the other unless you
    did it yourself recently or have
    service records it was done recently.
    If you have to a leaking water pump
    or thermostat you replace the timing
    belt and ancillaries. If you’re doing the
    belt and ancillaries you also do the water
    pump and thermostat.
    I rarely make exceptions to that rule.
    Jan 10 2017
    French Creek
    Lol, Im the same way. I dont put that much work into something just to get back to square 1
    Tried to adjust the shocks (raise the car) for a long trip to Toronto, but the collars were seized.
    I even took them out so I could better get medieval on them and they wouldnt budge.
    I was so pissed off at that point, after all that work and getting nowhere, that I ended up with fancy motor, trans, and rear end mounts, and a turbo back.
    No fkn way Im putting in that much work and coming out even, or empty handed
    Mar 10 2016
    England, UK
    Quote Originally Posted by landfill View Post
    My timing belt was done about 10k ago and they did not do the t-stat while they were in there, (previous owner) or if they did, its failed. But pulling the pipes and front end off to gain access to the timing belt area is an easy enough job i suppose.
    98 B5 S4 Nogaro
