Results 1 to 31 of 31
    Veteran Member Three Rings JB616's Avatar
    Oct 13 2010
    Pittsburgh, PA
    Steering Wheel Squeaking
    I would like to know if anyone else is experiencing this problem...
    My car went to the shop on Friday to fix a very annoying squeaking sound from the steering column. The noise would happen at any time I turned the wheel, in any direction. It did not matter if I was in just a very slight turn or a full lock-to-lock turn. This is the second time my car went to the shop for the same noise. On the first trip the dealership told me they lubricated right where the steering wheel mounts to the shaft in the steering column and performed TSB-37-13-09 for the steering unit. The sound went away for about two weeks and then came back, even worse. I took the car back Friday and the paperwork states that they lubricated the steering shaft at the firewall grommet and performed a recall for the steering column but no information about that is given. The sound went away for 1 day and yesterday it came back yet again. Do I have to live with this issue or does anyone have a recommendation if I can lubricate an area of the steering system instead of continuing with failed dealer attempts?
    2014 SQ5
    Account Terminated Four Rings
    Mar 11 2014
    Dallas/TX
    Quote Originally Posted by JB616 View Post
    Long going issue with C7's. I have had that issue. Easiest solution - adjust the position of your steering wheel a tad bit higher or lower than the current. It should calm the noises down.
    Veteran Member Four Rings Xtek's Avatar
    Jun 09 2013
    I had this issue with my 2013 A6 and 3 visits to the dealership and they couldn't seem to fix it even though there was a TSB for it.
    - Chad
    2014 S6 Estoril Blue - APR Stage 1, AWE Exhaust
    I have USB HEX+CAN VAG-COM cable, if you need mods let me know.
    Veteran Member Three Rings lv2000's Avatar
    Dec 04 2004
    Current. 2018 s6 prestige Past-997 turbo/ Audi S7 /13 A6 /b8 s4 /b8.5 s4 /b6 s4
    Las Vegas
    Mine did it on my s7 as we'll but not on the a6. There is a tsb now my car had column replaced and that didn't fix it the actual fix is a special silicone spray they spray around. Column boot going to engine bay since that it's not made a noise it's been 7 months now. Or just adjust column up like other people said
    Apr 28 2014
    Hong Kong
    I had the same issue and i just got the car back this morning for its second lubrication. I had the car for about 7 months/15,000km when it first happened. The dealer lubricated it and commented that I had set the steering quite low although it was in the middle of the range. It felt like it was rubbing against something but it almost went away completely since the first lube and came back approximately 10 days later although it was much more mild the second time around. This morning at the dealer it was completely fixed but i suspect it will come back in a week or two.
    Junior Member Two Rings 3miked's Avatar
    Oct 06 2014
    95 talon tsi
    St. Louis
    Quote Originally Posted by lv2000 View Post
    Mine is doing it bad in the morning. What does tsb stand for? Is that a recall?
    Senior Member Three Rings Pip's Avatar
    Aug 31 2010
    Singapore
    Quote Originally Posted by 3miked View Post
    Technical Service Bulletin (Directive from Audi HQ)
    Usually to update software or change components (eg. S6/7 Fuel Line replacement)
    2013-Current
    AUDI S6 C7 | 4.0L TFSI | Quattro | S-Tronic | Phantom Black
    S6 Air Suspension | Lowered 17mm | K&N E-1983 Air Filter | VOLK G25 20 x 8.5j et 36 | PSS 255/35 R20
    Eurocode ÜSS Stabilizer Bar | Eurocode ÜSS Billet Aluminium End Links
    Jun 09 2013
    I had this problem with my C7 A6 and they were never able to remedy it. :\
    - Chad
    Oct 06 2014
    95 talon tsi
    St. Louis
    Quote Originally Posted by Pip View Post
    Thanks Pip, I when ahead and adjusted the wheel a little and it went away. But I should be able to put the damn steering wheel wherever I want! An $85k dollar car should be flawless for years in my opinion.
    Oct 06 2014
    95 talon tsi
    St. Louis
    Quote Originally Posted by Xtek View Post
    My A6 did it too. Hey what's up with the Vag-com? What does that do?
    Sep 06 2013
    My steering has a bump feeling to it. And it happens at center. So it's a pain to keep it in a straight line when it happens. It's not always though. I do hear a "whine" when I park and turn the wheel fast. I have stage 2 on my a6. So I'm procrastinating taking her in. Is the steering wheel a non issue on the s6?
    2013 A6. Prestige/Innovation/20" wheels/LEDs
    Jun 09 2013
    It allows you to do some mods to your car. I've disabled the front amber lights that are always on in the US. I've also enabled lap timer (which has a built in boost gauge and shift light). I can roll down and up my windows with my key fob, etc.
    - Chad
    Jun 09 2013
    Quote Originally Posted by dnbdamian View Post
    A6 started getting the problem after about 8 months, have had the S6 for 7 so we'll see. But not yet.
    - Chad
    Oct 06 2014
    95 talon tsi
    St. Louis
    It allows you to do some mods to your car. I've disablyed the front amber lights that are always on in the US. I've also enabled lap timer (which has a built in boost gauge and shift light). I can roll down and up my windows with my key fob, etc.
    Yeah that is cool! I just read up on all the mods that can be done. I would definitely like to get ahold of one of those unfortunately nobody around here has an S6 much less a vag-com. How much did you pay for that?
    Oct 13 2010
    Pittsburgh, PA
    http://store.ross-tech.com/shop/VCHUC.html
    Should be the one for you :)
    My squeak is back. Raised the wheel up and it helped, for awhile. Thinking of popping the steering wheel off following the instructions given when you buy the special order wheels and see if I can lubricate anything in the area of the squeak. Also have a really odd rattle sound coming from the dash cluster area too.
    Sent from my iPhone
    2014 SQ5
    Oct 06 2014
    95 talon tsi
    St. Louis
    Sent from my iPhone
    Thanks! 350$ ouch. Yeah I just traded my a6 for s6 and it has the same damn squeak. I raised up column a little bit and it went away but I like it all the way down so I'll eventually take it to audi and make them take care of it. I read someone had audi end up replacing the whole steering shaft. It that's the permanent fix I'll make em do it.
    Veteran Member Three Rings Nabizzy's Avatar
    Mar 26 2014
    Toyota Tundra TRD Pro
    Houston, tx
    My RS7 does this too, so I guess its something across the entire line. I will try the raise wheel thing.
    "It's a funny thing about life; if you refuse to accept anything but the best, you very often get it."
    - W. Somerset Maugham
    Senior Member Three Rings BrianV's Avatar
    Aug 09 2012
    2013 S6 Prestige - LED, 20s, Drivers Assistance
    Austin, TX
    My car with 27K miles (Sold in May 2013) just started doing this last night. Interestingly the weather had just gotten quite warm here over this weekend. I emailed my Audi dealer to see what they want to do.
    FWIW, I did move the wheel column a bit and it didn't make any significant difference. For those interested, this is similar to the sound I have, granted mine isn't quite as bad:
    https://www.youtube.com/watch?v=KGYG1gKHP-c
    It seems this affects a variety of Audi's and not necessarily just the C7 family.
    2013 Audi S6 (Ibis White) - Prestige, Driver Assistance Package, Full LED Headlights, 20" Wheels
    2016 Acura MDX (Graphite Luster) - SH-AWD, Advance
    Dec 09 2007
    2012 A7 / 2007 RS4 Misano Red
    North Bergen
    Just dropped off the car for the same issue. Will see what they do to remedy this. This is not acceptable in my eyes. I actually dealt with it for a number of weeks. Hoping it would just stop.
    2013 Audi S7 Estoril Blue 2.0
    2016 Porsche Macan Jet Black
    2012 Audi A7 Moonlight Blue
    2007 Audi RS4 Misano Red
    2010 Audi TTS Misano Red
    2008 BMW M5 Sapphire Black
    2009 MB C63 Alpine White
    2000 Audi B5 S4 Laser Red
    May 07 2014
    Texas
    With the change of temps (or coincidence) I'm hearing my column squeak when I first turn on the car and the wheel auto-lowers to my preset. There's no squeaking turning the wheel...only when I tilt (electronic tilt)
    Quote Originally Posted by cheezItt View Post
    Aug 09 2012
    Austin, TX
    Quote Originally Posted by PBPhantom View Post
    I suspect your problem is different. I've heard of actual steering wheel column motors getting noisy/slow/etc. I think our noise is more in the ring gear and actual steering wheel turning mechanism.
    My car goes in on Friday, I'll report back.
    Senior Member Three Rings CoJoe's Avatar
    Apr 29 2012
    Boulder, CO
    Same issue. Adjusting the tilt a little did make it less noticeable. Still annoying. Had this on my RS5 also, dealer ended up replacing the electro steering unit thingy. Never happened again after that. Haven't had the S7 looked at. Just did a tune right before this started up, wanna have a little time before bringing it in. I'll just turn the music up for now;)
    2013 S7 Glacier, GIAC ECU+TCU, Chicco Car Seats, DoubleBob Stroller
    2013 RS5 Daytona [Sold]
    Sep 28 2009
    suburb
    I've go this now. Can I spray some lube into it? It's so dang annoying!
    Audi S7 stage 3 w/srm turbos
    Audi B8 S5 stage 3 w/apr supercharger
    Audi SQ7
    Audi Q5 3.0 EPL stage 2 single pulley (gone)
    Audi Allroad 2.7 stage 3 (gone)
    Audi B5 S4 stage 3 (regrettably gone)
    Audi B8 S5 (gone)
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by flyfishing View Post
    Wow, what a resurrection....
    Good for you for searching first. :)
    I had this on my old B5 S4 and now on my SQ5.
    S4 needed lube on the universal joint of the steering shaft, down by your feet.
    On the SQ5 I lubricated the steering shaft area at the firewall grommet and that has worked so far.
    Both times using spray lithium grease. (Same can as matter of fact....10 years later....lol)
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Sep 28 2009
    suburb
    Did you remove any trim to lube it or just stuck in the thin straw and spray :)
    (that's what she said?)
    Audi SQ7
    Audi B8 S5 (gone)
    Jul 30 2013
    Colorado
    Mine does it, I just turn up the stereo
    Aug 06 2014
    NJ->CO
    no trim removal
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Sep 28 2009
    suburb
    yes that was the answer! The steering shaft near the firewall. I put head down there to hear the squeal and when I put my finger and pushed down on the grommet, the noise went away. lubed with with lithium grease a couple times and boom noise is gone.
    Audi SQ7
    Audi B8 S5 (gone)
    Oct 24 2019
    2006 CLS 63 AMG
    Santa Monica
    Fixed it for me thanks I was getting annoyed I just picked up a 2016 A6 3.0 and that noise started today out of nowhere. She’s going in tomorrow for a few recalls I’ll have them check out this little
    Issue as well.
    Quote Originally Posted by agent47 View Post
    Apr 19 2016
    tc/mn
    Mine had that problem. Dealer lubed it like 3 times per the tsb, but it kept coming back in a couple of weeks. They finally gave in and just replaced the steering column and it's been fine ever since.
    16 S7: APR, CETE, VS Forged
    13 A6 3.0T: EPL, Vorsteiner [gone]
    13 S5 Cabrio [gone]
    Veteran Member Three Rings mike0819's Avatar
    Oct 29 2016
    nz
    Hi can you please help me, how do I lub the steering shaft for audi s7?
    Do I put wd40, and where is it located?
    Quote Originally Posted by gk1 View Post
    no trim removal
    Sent from my EVR-AL00 using Audizine mobile app
