Results 1 to 19 of 19
    Veteran Member Four Rings chrissurfr's Avatar
    Apr 26 2005
    Houston
    BBS spline lug bolts?
    Hey guys,
    I'm looking to get BBS CH R wheels for my car instead of the BC Forged - you know, keep it simple. However, I would like to make the small details counts.
    Are the usable on our cars?
    http://europeanautosource.com/bbs-ra...t-kit-red.html
    I have a feeling the answer is no.....
    What else is available that is similar?
    Chris
    2017 Cement Grey TRD Pro 4runner
    2014 Suzuka Grey RS5 >:)
    • AWE Track Exhaust with center muffler straight piped
    • H&R Street Coilovers
    • BBS CH R - Gold with red caps
    • eCode headlights
    • Eventuri intake
    • JHM Stage 2 ECU/TCU
    • other things I forgot about
    Veteran Member Three Rings Octothorpe's Avatar
    Aug 25 2013
    Greenwich, CT
    Well, Audis use bolts, not nuts, so you are correct, they won't work.
    You *could* do a conversion (I'm considering it), but I don't know what disadvantages it brings (one major advantage is the ability to easily take off and replace the wheel without a *!$%# guide bolt).
    Apr 26 2005
    Houston
    Quote Originally Posted by Octothorpe View Post
    I see that these are bolts vs. nuts, bummer. To finish off the look of the wheel properly, I think I'll give this a shot though. It's the little details that count, right?
    Now, what is involved in a conversion? I see Audi bolts are 14x1.5 and these nuts (deez nutz) are 12x1.5 thread pitch.
    • eCode headlights
    • Eventuri intake
    Apr 26 2005
    Houston
    • eCode headlights
    • Eventuri intake
    Veteran Member Four Rings Sgibb16's Avatar
    Jul 02 2012
    2012 A5 & 2002 Passat Wagon
    Fredericksburg, VA
    @mxrz and @nyspeedracer have done the conversion to studs
    2012 A5 P+ | Sports Package | 6MT | 35% Tint
    REVO Stage II | AWE Quad Exhaust | 034 HFC | E-Codes | FK Silverline Coils | JHM Short Throw Shifter | Eurocode HFIC Pipe | Roc Euro Intake
    TR8 Intercooler | CTS Silicone Hose Kit & Turbo Outlet | CR-15 Strut Brace | Alu Kreuz | S-line Front & Rear Bumper Conversion
    Sep 28 2010
    NW NC / DE
    I should hear back from my BBS connect about these tomorrow. You can certainly do the conversion, but I'm not familiar. I would imagine you could get a thick "decal" kinda like a center cap to pop of the bolts heads? I would be really bugged if I could not get the logos to match, but I guess they might if you started them out in the same position.
    Stage 2 Banner Advertiser Four Rings Jimminez@Nemesis's Avatar
    May 16 2007
    2020 Q7, 2021 RS6 Avant
    Ottawa CA / DE USA
    You would need to get conversion studs that convert the M14x1.5 to the smaller M12x1.5 and then you can use these. Once you've gone to M12x1.5 you've opened up your selection to lug nuts as most tuner lugs are M12x1.5.
    I ordered some Project Kics R40 Iconix I plan on swapping on to my F31.
    Oh and those BBS ones are made by McGard and cost a fraction for the same without the BBS logo.
    Apr 26 2005
    Houston
    Thanks, guys.
    I found studs here. (no homo)
    http://www.amazon.com/20pc-14x1-5-12.../dp/B00JTSY7NK
    Are those long enough Mops?
    • eCode headlights
    • Eventuri intake
    Apr 26 2005
    Houston
    Thanks...I've been googling like crazy all afternoon to figure it out. I can't help but laugh at the McGard nuts. Ermagherdd.....
    Quote Originally Posted by Jimminez View Post
    • eCode headlights
    • Eventuri intake
    Apr 26 2005
    Houston
    Has anyone done the conversion? It seems like it could be a weak point...no?
    • eCode headlights
    • Eventuri intake
    Apr 26 2005
    Houston
    Looks like these can be had in thread pitch 14x1.5 so no shrinking down to 12mm needed. That makes me feel a little better about ordering studs.
    http://www.mackin-ind.com/portfolio/monster-lug/
    Are these the right seat type for BBS wheels?
    • eCode headlights
    • Eventuri intake
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by chrissurfr View Post
    Looks to be, but mxrz would be the only one I know to 100% confirm, and show you what you need.
    Apr 26 2005
    Houston
    ^ lol that won't work. Pretty sure he blocked me a while back.
    • eCode headlights
    • Eventuri intake
    Jul 02 2012
    Fredericksburg, VA
    RJ should be able to help too if he shows up...
    Sep 28 2010
    NW NC / DE
    LOL, I was not sure how you would feel about my reply anyways.
    Jul 02 2012
    Fredericksburg, VA
    Apr 26 2005
    Houston
    I'm always down for an honest reply....no hurt feelings.
    • eCode headlights
    • Eventuri intake
    Jul 02 2012
    Fredericksburg, VA
    Jun 21 2008
    NYC | ATX
    If you're looking for a conversion kit, I have one...
    I been meaning to install it, but it didn't look right on my current wheel setup.
    Let me know if you're interested, it was never installed.
