This is a continuation of http://www.audizine.com/forum/showth...-Bad-Reservoir.
I have since had the head tested (ok), and have completely redone the head gasket job. Just for the hell of it I tried felpro bolts and gaskets, I have not noticed a difference from the Victor.
At this point the car throws no codes and seems to drive nicely, but I have noticed coolant coming from the reservoir from the pressure release valve in the neck of the reservoir. (Cap has been replaced) This only happens when the engine is under load, idling will not produce the symptom.
When draining the tank to check for anything odd, I noticed a decent amount of silt-like material in the coolant. It was sandy and a bit reddish. Could this be indicative of a blocked passage of some type? Could this cause the system to overpressurize? Air in the system?
I am confused, as the head gasket was replaced twice, ran great each time, but has the same issue with the coolant system becoming overpressured.
-Anyone have any experience with this?
