Results 1 to 11 of 11
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    bel valve covers on apb.
    did a fair bit of searching and haven't found a definitive answer.
    i have a bel laying around, it has push down coils, can i use them on my apb so i dont need coil adapters (i plan on doing the 2.0 conversion)
    some say yes some say the bel coils are longer than the 2.0 coils meaning i would still need an adapter.
    also are the bel coils any different from the 2.0s if they are the same i would just use them anyway.
    Mine - Silver 01.5 S4 stage 2 - st - apr - ssac - apikol
    Wife - Imola 00 S4 stage 2 - st - ssac - podi - usp - 034
    Ours - Silver 92 S4 custom coilovers - 3 inch exhaust - ak motorsports
    Indigo Pearl 92 Coupe
    White 07 Q7
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    Look up the coil part numbers and compare.
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    Quote Originally Posted by audacity View Post
    Pretty sure the BEL push down coils are the short version like 1.8T coils.
    Veteran Member Three Rings Dr.d's Avatar
    Jun 20 2012
    2001 S4, 2024 Model 3
    Vancouver, WA
    Quote Originally Posted by NOTORIOUS VR View Post
    X2
    I was planning on doing this myself but then I found out about that. Iirc, I found a thread where someone with an apb allroad did an icm delete using the normal coils then put on bel valve covers and the coils were way too long. In the same thread he had the part number for the shorter coils.
    Veteran Member Three Rings okkim's Avatar
    Dec 07 2004
    Finland
    Yes, BEL coils are shorter. This fits with the BEL valve cover: http://www.finjector.com/verkkokaupp...e-p-101179-42/
    Jul 14 2014
    richmond va
    Audi r8 coils , vw toureg plastic coil adapters 3 $ a pice fit perfect on apb valve covers
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    Quote Originally Posted by tasin View Post
    money isnt the issue, id rather not have adapters if there is a better solution.
    White 07 Q7
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    may have stumbled upon a thread with some info. anyone ever do this with success?
    06E905115E
    is a shorter version of the fsi's i guess ill have to buy one and test fit.
    White 07 Q7
    Oct 28 2012
    near chicago
    I have an 04 bel. I did the conversion. 2.0 coils are longer but will still work and fit. They just stick up a little higher. Main issue is that the weather seal is not made and it is possible for debris to fall or collect beside the stem near the top of the plug. I learned this first hand when I had a coolant leak and it dripped down there. It shorted the coil and caused a misfire.
    Jan 29 2009
    Stick with the APB VC + either Hitachi coils or get adapter plates from ECS/034/etc and use the TFSI coils then.
    Jul 14 2014
    richmond va
    All 1.8 t have a short coil packs
    But they not as good as long new version ,
