Results 1 to 4 of 4
    Sep 02 2007
    2004 B6 S4 - 2004 T1 Touareg 4.2
    Salisbury Maryland
    Identify Knock Sensor Location
    Looking at buying a B6 S4 with one fault found when when you scan it with Vag-Com. When the code is cleared the car pulls hard, but the code comes back shortly after it's cleared. The code is as follows.
    1 Fault Found:
    16711 - Knock Sensor 1 (G61)
    P0327 - 002 - Signal too Low
    Now it's easy enough to assume that you replace the knock sensor, but i've also been told the it's possible the intake manifold can pinch the cable if it's been removed before. Regardless of that, i've had a hard time identifying which knock sensor to replace. Is there anyone that could help identify each of the knock sensors so I know which one to order? I've searched high and low and have been unable to find any diagram that's actually worth anything. Again thanks for the help!
    Senior Member Two Rings viridia's Avatar
    Apr 13 2011
    ham best meat
    Knock Sensor 1 (G61) and Knock Sensor 2 (G66) are for bank 1 (cylinders 1-4, passenger side). The connectors are in front of the engine under the "V8 4.2" shroud; there's a black and blue connector for both the right side and the left side (four knock sensors total).
    I'd disconnect one at a time and ensure you see on your vagcom "Knock Sensor 1 - Open or Short Circuit" to be absolutely sure.
    Right side sensors are:
    Black 079905376C right rear 345mm
    Blue 079905377G right front 185mm
    Given the lengths, it *should* be blue.
    87 4k, 90 f350, 91 v8, 93 v8, 04 s4, 0a3 transmission
    Sep 02 2007
    Salisbury Maryland
    Great thank you for the quick response! I'll give this a shot.
    Active Member One Ring daniel3535's Avatar
    Sep 14 2012
    Tellico Plains, TN
    Any resolution on this? I have the exact same problem currently on my 04' s4. It previously had an Injector Cylinder 2 (N31): Circuit Malfunction P0202 No Signal/Communication - Intermittent, but I swapped the injector on that cylinder to #1 and now I'm getting the P0327 code for some reason.
