Results 1 to 40 of 48
    Senior Member Three Rings Albertk's Avatar
    Dec 08 2010
    Audi A4 3.0, Specialized Lanster
    Hanover, New Hampshire
    Hankook Ventus V2 concept2 or S1 noble2
    I know the S1 noble2 is a good tire, but Hankooks just come out with the new V2 concept2.
    Anyone have any experience with the V2 concept2?
    I'm looking to buy a set of 4, and am coming from running the discontinued eagle gts.
    Nov 11 2010
    Rochester, MN
    This is not 100% close to what you're looking at, but this summer I replaced my Avant's 17" Eagle GT's with a set of Hankook Ventus V12 EVO K110's, and they feel very similar. In fact, I think the Ventus are even quieter.
    19" B8 S5 Peelers
    Dec 08 2010
    Quote Originally Posted by SlickFix View Post
    Nice, but I'm looking for all season tires. I've been told that Hankooks make good tires.
    Ventus V2 Concept2
    S1 Noble2
    Jun 27 2011
    Have you checked out the reviews and tests at TireRack? i would do that. Try to filter out the results to german cars or just Audis to get some better reviews.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Veteran Member Three Rings NathanGrayW's Avatar
    May 17 2014
    Akron
    I had a pair of Hankook concept 2's that were on the back of my car. I can't really comment on them however, they were getting old and needed replaced soon anyways. I got a hole in one that couldn't be repaired, so I replaced them.
    I put a pair of Continental DWS on the rear and I like them more than the Hankook's that were on there.
    They definitely have more grip than the old tires, but that is probably due to the older tires.
    I do know that for the Continental DWS vs Hankook noble2 it's a trade off for slightly better snow performance, or slightly better summer performance.
    I went for slightly better snow.
    Those were the two tires I was looking into buying.
    I'll be getting another pair of continentals before winter for the front.
    2004 A4 Ultrasport 6MT "Almost-Brilliant" Black
    APR 1+
    Veteran Member Three Rings rich045's Avatar
    Jul 13 2013
    Queens, NY
    why would you only change the rears?
    May 17 2014
    Akron
    Quote Originally Posted by rich045 View Post
    My rear passenger, and spare tire were both bad. (tire went flat, went to put spare on and it was bad as well.) Never checked when I bought the car a few months ago...
    When you replace tires in pairs, the best tires should go on the back. Because understeer is a lot easier to control than oversteer.
    And I don't have any extra $300 for the front.
    APR 1+
    Jun 27 2011
    Quote Originally Posted by NathanGrayW View Post
    Uhhhh, You never replace tires in "pairs" on a quattro car.
    -CP
    2017 Q7 3.0t
    May 17 2014
    Akron
    Tires have to be within 5% rolling diameter for a quattro system. I am well within that spec.
    APR 1+
    Dec 08 2010
    The noble2's have great reviews on tirerack. Surprisingly ranked higher in overall than the DSW's, though not nearly as popular Check this out.
    The concept2's are pretty new so not too much feedback on the tires yet-- especially for snow performance.
    Good point-- snow performance is important, but quattro does such a good job in the snow anyway that I'm not too worried.
    I need 4 new tires and can't decide if I want to pay extra for ultra high performance all season tires over just "high performance" all season tires. As I understand it, the latter offers better all around performance while sacrificing summer performance, AND they're also cheaper. Seems like a better option to me. Can anyone weigh in on this?
    May 17 2014
    Akron
    Quote Originally Posted by Albertk View Post
    AWD is awesome for going forward, but doesn't do anything for stopping.
    Thought I'd throw that out there.
    APR 1+
    Jun 27 2011
    Are the tires new front and rear? Are the amounts of wear comparable?
    Because that doesn't really sound like they are....
    -CP
    2017 Q7 3.0t
    Dec 08 2010
    That's a very good point.
    May 17 2014
    Akron
    235 in the front, 225 in the rear.
    Probably 5/32 in front, and 10/32 in rear.
    You can run 235, and 225 together no problem. My front tires being worn is only helping.
    APR 1+
    Dec 08 2010
    I think both of you guys are right here. You can run with slightly different diameters, but you are putting an unnecessary strain on the differentials/awd system. The best case scenario would be to have all 4 tires identical, but that never happens because of uneven wear anyway.
    Edit: Actually nevermind. I misunderstood you Nathan. You probably don't want to be running two different tread patterns. Its probably not the best for your drivetrain.
    Jun 27 2011
    Seems legit......
    -CP
    2017 Q7 3.0t
    May 17 2014
    Akron
    What does tread pattern matter? The only thing Quattro cares about is tire diameter.
    Audi manual even specifies you can change per axle.
    APR 1+
    May 17 2014
    Akron
    Seems legit......
    I am well within rolling diameter specs for a Quattro.
    APR 1+
    Dec 08 2010
    It's only what I've read. Never tried it myself.
    May 17 2014
    Akron
    Its only for handling. If you want the best performance, you want all 4 wheels to react the same.
    I'll be getting matching tires for the front before winter.
    You could have 4 different tread patterns, and as long as they're the same diameter your diffs could care less.
    APR 1+
    Veteran Member Four Rings evo_ski's Avatar
    Mar 15 2010
    Bothell
    Different tread patterns will help confuse the hell out of the ABS system especially in poor weather.
    Costco 92 Octane Gas - MANN Air Filter - 235/35/19 Tires w/ 36 PSI (cold) Tire Pressure - Grey Plastic Valve Stem Caps - 0° Front Toe - Rotella T6 5W-40 - 2 OEM B6 Keys - 18x8" Spare - Coin & Pen Filled Center Console - Rain-X on all 8 windows & Napa Cold Temp Washer Fluid - Bosch Wiper Blades (Valeo wipers suck big time!) - S4 Trunk Latch - Craftsman Tire Pump w/ Automatic PSI Shutoff - Belly Pan Delete (Weight Savings) - 3D Printed Rear Warning Triangle latch - 174,000 Miles & Counting
    May 17 2014
    Akron
    Quote Originally Posted by evo_ski View Post
    Fair enough, I'll be getting matching tires anyways when it's time for bad weather anyways.
    If I destroy my car it's my fault. But I am WELL within spec that Audi recommends.
    APR 1+
    Established Member Two Rings Ji99a's Avatar
    Jun 18 2014
    BC, Canada
    You are but it is highly recommended on all AWD vehicles to have the same size and tread pattern.
    03 A4 1.8t Quattro
    FMIC, CAI, Borla Exhaust, Vogtland Coilover, H Sport Swaybars
    (Some of this stuff was the previous owner so I'm trying to figure out what he used )
    May 17 2014
    Akron
    Quote Originally Posted by Ji99a View Post
    I agree. And I never stated otherwise.
    APR 1+
    Veteran Member Four Rings PreciseD's Avatar
    Feb 05 2014
    The Quattro system only allows for 4/32 difference between 2 axles and 2/32 if on the same axle. This is direct from Audi.
    ----- My EFR 7670 Build Thread ----- "The thing about quotes on the internet is you can not confirm their validity" - Abraham Lincoln -----
    Jun 27 2011
    Uh huh.
    I get it. Tires are expensive. I struggled along for a while with mismatched tires. My car hated me for it. The handling was shit and the rear diff clicked badly. It took a little bit to save up enough to get 4 new tires but it made a massive amount of difference in how the car handled and drove compared to the 1st set of mismatched Yokohamas, and then the shitty Sunew junk that I got for free from a friend.
    The difference being I KNEW that this was bad and didn't try to justify it to myself pretending it was within spec.
    -CP
    2017 Q7 3.0t
    May 17 2014
    Akron
    Uh huh.
    I never disagreed that it was recommended to run all identical tires. Not quite sure where you think I said it wasn't recommended...
    I'm not trying to start an argument
    I said it's not required as long as you with 5%. Granted, a lot of people say 3%...
    There is a 1.24% difference between a 225/40/18 and a 235/40/18.
    Worst case scenario I am at a 1.24% difference. However, my front tires are worn. Which will make the difference even smaller.
    Here are a couple of threads I found.
    Click -- this guy is running 225/40's with 255/35's. Go yell at him.
    Click
    Now to be clear. I NEVER said it was the best thing to do. But it's not "Required" to run all 'Identical' tires.
    APR 1+
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    This is a stupid argument. I am the biggest critic of people running staggered wheels/tires on quattro, but 3% is spec. He is well within that specification and is doing no harm to his vehicle.
    Yes I think it's goofy that he's running mismatched tires, but I know he knows that.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    May 17 2014
    Akron
    Quote Originally Posted by LINDW4LL View Post
    I wouldn't be doing it if I had an other option. It came up unexpected, and I found a great on these.
    APR 1+
    Dec 10 2011
    CLT | MKE
    Yeah I completely understand. I just think it's funny how everyone was attacking you. Yeah, it's janky but it's not doing damage to your car in any way whatsoever.
    -Hayden
    Jun 27 2011
    It IS in fact causing undue wear on the diffs. Saying it's "not doing damage to your car in any way whatsoever" is also untrue.
    You guys know how the torsen AWD systems work right? sure its not a lot, and its within the tolerances, but you're still causing unnecessary wear. My point is don't delude yourself about it being totally fine. It will cause a worn diff down the road if you maintain the messed up circumferences.
    -CP
    2017 Q7 3.0t
    May 17 2014
    Akron
    Thanks, it definitely looks jank.
    People just hear things, and they don't go through the trouble of actually looking up the information themselves. There is a TON of information on this topic, and it all comes down to the same thing. Stay with 3%, 5 max.
    APR 1+
    May 17 2014
    Akron
    No one has 4 tires that are all identically the same diameter.
    Seeing as Audi designed the system, and allows for 3-5% difference, I'll listen to Audi and say it's fine.
    So unless you're a German scientist that works for Audi...
    I would also make sure you guys keep your tires all at the exact same PSI, as well. Don't want to cause any extra strain.
    APR 1+
    Mar 15 2010
    Bothell
    Nobody's tire are the same diameter.
    The what now?
    Jun 27 2011
    You stick with your way, I'll stick with mine. I'm 99% confident I know whose diffs will last longer........
    -CP
    2017 Q7 3.0t
    Jun 18 2014
    BC, Canada
    And nobody's tires are the same diameter? really? That's why you rotate them regularly is to keep them within .002% of each other
    03 A4 1.8t Quattro
    May 17 2014
    Akron
    Go get your tires measured. I doubt they're within .002%
    APR 1+
    Mar 15 2010
    Bothell
    I would bet my tires are within 1/16 of each other or less.
    Dec 10 2011
    CLT | MKE
    Sure, technically having 0% difference will cause less wear than 1.5% difference. But that extra wear would never be measurable because it's so minor. It's like saying that running a 5mm lower offset wheel than stock will put excess wear on your wheel bearings. It's true, but the extra wear will never be noticed.
    Did you know you can tow Torsen cars with two wheels on the ground for up to 50 miles? How much damage do you think that does to the diffs, relatively?
    -Hayden
    May 17 2014
    Akron
    I won't argue with that, but saying .001% is ridiculous.
    Also, I never said you should do it either. I didn't have a choice.
    You guys act like it's going to destroy the car. It's not, Audi specifically states a specification to be within. As long a you're within their spec, you're fine.
    APR 1+
