Originally Posted by
kegobeer
He's not getting a new key, he's transferring the entire key from the plastic case to a new plastic case: open old key case, remove all parts, open new key case, remove blank key, install all key parts, close new key case. There is no reason that won't work.
There is actually every reason why it won't work. I understand what he is trying to do. But it won't work. It's not the actual board inside that has the code. There is actually a clear crystal/piece of plastic (it's the clear part that lights up red when you push the buttons)that is made for that specific key, for that specific car, for that specific vin.
I obviously can't stop anyone from trying. But I'm just saying it won't work.
Here is how it exactly works...
The key(made to your vin) is embedded with a specific code and a specific algorithm. When you put your key in and turn it the remote sends a signal with that code and algorithm to your ECM, your ECM has it's own algorithm and code. They do the math, if the outcome is the same for both the key and ECM, the info is then sent via can bus to your immobilizer and gauge cluster. They both repeat the process and once that outcome matches your car is then allowed to start. If your key doesn't have the crystal that helps this while process transpire than it will fail. It's one of the many ways it makes it hard for our cars to be stolen.
It's also why when you get a new gauge cluster you need new keys.
Also depending on the immobilizer system you have, 1, 2, or 3 will bring more difficultly.
And it's another reason why you can't access the immobilizer systems to do any adaptations with vag com.
So ultimately you will end up going to the dealer to get it programmed anyways.
But if you replace the parts that I said to replace you avoid lots of headache and money spending.
Just keep the buttons and back.
I have even had a customer do it to his key and it wouldn't program either.
I just hope to help you avoid the annoyance I went through, but save you money as well
