I've got an '06 A4 that had an oil pressure problem on the highway that ended up with a bang before I could pull over.
Dealer said "give us $7k to replace the head", and that turned into me buying a used engine (06 BPG) that I installed, and then found out it had a bad valve.
Recycling yard replaced the BPG engine with a BWT engine.
My question, can I use the BWT wiring harness with my BPG ECU (my understanding is that the imobilizer will not be happy with a different ECU)
Thank you for any help.
-Eric
